| -Savage- |
 -Savage- World Chat Champion
| willi |
 willi Spanner Monkey
| veeeffarr |
 veeeffarr Super Spammer
| Diggs |
 Diggs World Chat Champion
 Posted: 12:33 - 12 Apr 2007 Post subject: |
A proper fitting bra should do it... ____________________ Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting... |
| CRAZY_BIKER |
 CRAZY_BIKER Guest
| Marci |
 Marci Brolly Dolly
 Posted: 15:34 - 12 Apr 2007 Post subject: |
Sounds like it needs less preload... you got adjusters? ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk |
| feef |
 feef Energiser Bunny
 Posted: 15:44 - 12 Apr 2007 Post subject: |
| Marci wrote: | Sounds like it needs less preload... you got adjusters? |
no way of knowing if it's just preload...
a 'bouncy front end' is such a generic description, it Could be caused equally by preload, rebound or compression damping settings.
not enough damping, and it'll pogo.
too much damping, and it'll bounce because it's rock hard
too little rebound damping, and it'll top out the forks witha clunk and be bouncy
too much rebound, and it can pack down, so there's no travel left and bounce
too much compession, and it won't compress enough, be too firm, and so bounce
too little compression damping and it'll dive too easily, so bounce back up
All depends on the kind of forks, the level of adjustability and what causes the bouncing, also what kind of bouncing it is.
Is it a wallowy bounce? a springy bounce? Are there any noises, knocking coming from the fork?
before identifying ANY suspension issues, tho.. make sure your tyres are in good shape.
a ____________________ Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating |
| MarJay |
 MarJay But it's British!
| feef |
| FreshAL |
 FreshAL Sir Crashalot
| MarJay |
| -Savage- |
| feef |
| FreshAL |
| feef |
 Posted: 12:53 - 13 Apr 2007 Post subject: |
| FreshAL wrote: | | feef wrote: | after 27k miles I'd look at flushing and replacing the fork oil.. maybe even checking the rear shock.
a |
Is it worth increasing the pre-load (& damping if poss.) on the rear?
I still don't completely understand suspension, so this might be a completely rubbish idea. |
preload will stiffen the spring, and make the suspension harder. That won't necessarily fix the bounciness, it might just change HOW it bouncies (rather than wallowing/boingy, it may become hard and harsh)
Also, if the rear is harder, then any upward force on the rear wheel will cause a downward force on the front forks, pivoting about the center of gravity.
There's no real way to 'tune' out the symptoms or effects of poor fork oil, or a knackered rear shock.
best to either ride around it carefully, being aware of the limitations, until it becomes unrideable, or just get it fixed.
Suspension, steering and brakes are the 3 things I don't allow to be less than 100%. I can handle an engine that's down on power, but I still want to be able to stop and go round corners safely.
| MarJay |
| feef |
 Posted: 14:19 - 13 Apr 2007 Post subject: |
| FreshAL |
 Posted: 14:28 - 13 Apr 2007 Post subject: |
Keep it coming, I'm learning here...  |
| Pete. |
 Pete. Super Spammer
 Posted: 16:39 - 13 Apr 2007 Post subject: |
Best thing to do is have the forks apart clean all the gunge and old watery-oil out fit new seals and re-fill with fresh oil.
Then start thinking about making adjustments. ____________________ a.k.a 'Geri'
| feef |
The last post was made 19 years, 3 days ago. Instead of replying here, would creating a new thread be more useful? |
