new barrel and piston kit running in miles??help..
dudeskin
PostPosted: 18:28 - 12 Apr 2007    Post subject: new barrel and piston kit running in miles??help.. Reply with quote
hi,
i just had to put a new piston and barrel kit on my yam fs1 (only a 50 unfortunately). but i don't know how many miles i should run it in for before giving it some stick again.
i've heard 500 miles, but thats a lot.
i've also heard 100 miles, but thats not that much.
i'm going for the gentle run in at the moment, i've only got a month untill i can get a bigger bike, and cannot afford to spend more money on a bike im not keeping for long.
any help would be great guys..
cheers for your time
dudeskin
live hard, die young, leave a damn good looking corpse.
Odie
PostPosted: 18:36 - 12 Apr 2007    Post subject: Reply with quote
Speak to the supplier / manufacturer of the kit.
Dischord
PostPosted: 19:03 - 12 Apr 2007    Post subject: Reply with quote
I gave my new set about 5-10miles and then gave it hell, did me 15,000miles ++
the recommended estimates for running in take the piss, just make sure you use plenty of 2 stroke oil and warm the bike up properly for the first 50 miles and then it will be fine!
2012 KTM EXC 250
st3v3
PostPosted: 19:37 - 12 Apr 2007    Post subject: Reply with quote
changing the ring on me 125 soon, was told to run it in for about 300 miles, but that is a lot for changed rings, is it not?
Type_Mo
PostPosted: 19:38 - 12 Apr 2007    Post subject: Reply with quote
i done 1000km when i put a 70 kit on my typhoon. never had 1 single problem with it and i used to cane the hell out of it Laughing Thumbs Up
Odie
PostPosted: 19:51 - 12 Apr 2007    Post subject: Reply with quote
Dont, it weakens the mixture and thus will seize the engine.
Leave it at the stock settings.
RS1Banger
PostPosted: 21:52 - 12 Apr 2007    Post subject: Reply with quote
the last cylinder i re-ringed, i just heat cycled and then thrashed
it was fine (did 85mph, only 75cc )
moonym20
PostPosted: 21:55 - 12 Apr 2007    Post subject: Reply with quote
don't use fully synth oil when your running in!
it will help the clearances tighten up better, you really want to be looking at 300miles or more to get a good job but the whole running in topic is on here loads n loads most of which end in arguments lol Wink
A scientist crossed a skunk with an owl. He's got a bird that smells but doesn't give a hoot Smile
st3v3
PostPosted: 22:12 - 12 Apr 2007    Post subject: Reply with quote
yeah figured, knew not to use fully synth, but can't I just put new rings on/in, then be careful for 250-300 miles and rag it a bit? also what rev range is it best to use, what sped not to exceed etc.. Thanks. Thumbs Up
cestrian
PostPosted: 23:38 - 12 Apr 2007    Post subject: Reply with quote
FFS just don't thrash it for a while. Let it warm up for a few minutes before you 'open the throttle'.
dudeskin
PostPosted: 13:34 - 13 Apr 2007    Post subject: Reply with quote
cheers guys, that gives me a better idea of what to do. im on 120miles now, its taking a long time, damn 50 Sad. shall i give it a bit more every 100 miles or something? it seems to be fine and giving me the impression it can go abit more.
cheers for the help guys
Deckx
PostPosted: 11:48 - 14 Apr 2007    Post subject: Reply with quote
how does it weaken the mixture, Question
when i had 2 strokes i used to mix some with the petrol after changing rings or pistons, made lots of smoke !!
just take easy for first 50 miles and always warm up engine
bish777
PostPosted: 12:04 - 14 Apr 2007    Post subject: Reply with quote
I think he means by adding 2 stroke oil to the fuel in the tank(the old fashion way of mixing the oil).
The oil is mixed by the carb, so if you do this on a autolube bike, the oil will compete with the fuel trying to get through the mainjet-therefore weakening the mix and causing it to be lean and melt things.
GSXR1100J
The last post was made 19 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 77.06 Kb
