1st gear kick???
paulDJSCOTT
PostPosted: 14:29 - 13 Apr 2007    Post subject: 1st gear kick??? Reply with quote
i've noticed that after starting my bike that when i put it into 1st gear it gives the bike a kick.
sometimes when this happens the engine cuts out and can be a right pain in the arse to get it into 1st n then off.
ive noticed that it helps if i give it some revs while i put it into gear?
i dont know much about bikes but im pretty sure this aint right.
what do you guys think?
G2 ninja 6 .......... green
www.myspace.com/paulscottdj
NSR Mick
PostPosted: 14:32 - 13 Apr 2007    Post subject: Reply with quote
Warped clutch plates, or adjustment.
paulDJSCOTT
PostPosted: 14:43 - 13 Apr 2007    Post subject: Reply with quote
ok say that is the problem how much do you recon it'd cost me to get fixed?
Finglonga
PostPosted: 15:52 - 13 Apr 2007    Post subject: Reply with quote
Is it the first time you put it into gear though in the morning, or every time you put it into first?
Andy Sez....
F.Y.Y.F.F.
PostPosted: 15:54 - 13 Apr 2007    Post subject: Reply with quote
Not a great deal if you do it yourself and its really easy.
Clutches are about the only thing that is supposed to be a lot easier to work on on a motorcycle rather than a car, and they are dead easy.
If you need to replace the clutch plates, you will need to drain the oil and remove the clutch cover so new oil and a clutch cover gasket will be needed. First of all however I'd adjust the clutch cable so the clutch definately disengages fully when you pull the lever. You need to leave a bit of freeplay but a couple of mm at the end of the clutch lever should be fine.
paulDJSCOTT
everytime it goes into first Confused
paulDJSCOTT
PostPosted: 15:59 - 13 Apr 2007    Post subject: Reply with quote
If you need to replace the clutch plates, you will need to drain the oil and remove the clutch cover so new oil and a clutch cover gasket will be needed. First of all however I'd adjust the clutch cable so the clutch definately disengages fully when you pull the lever. You need to leave a bit of freeplay but a couple of mm at the end of the clutch lever should be fine.[/quote]
ok well ive gt the service manual so ill have a shot at it only other thing is my bike is a right pain to get parts for lol
ive noticed that the oil sight glass always looks empty but ive never bothered about it as the oil light doesnt come on. i know it works cos ive seen it on. but im starting to think that this has someting to do with it?!?
cokker
PostPosted: 16:08 - 13 Apr 2007    Post subject: Reply with quote
I have a feeling your bike could do with an oil change and the clutch cable adjusting (as said above).
I get a "little" kick forward selecting first when the bikes first started, im sure the VFR did too if i remember right.
No longer have a bike due to a DVLA/Court royal f**k up.
Trixie
PostPosted: 16:13 - 13 Apr 2007    Post subject: Reply with quote
It's fairly normal to get a bit of a "kick" when you first put the bike into gear, but not every time.
Check your service manual on how to check the oil (if you have a sight glass you'll probably have to warm the engine up first). Check it and top up/change if necessary, and as has been said, check the clutch cable for adjustment.
When was the last time your bike had an oil change?
Dead nobodies in company cars...
paulDJSCOTT
PostPosted: 16:18 - 13 Apr 2007    Post subject: Reply with quote
couldnt tell you only had it about a month.
when it comes to the clutch cable how can i check that it full dissengages the clutch?
sorry if i sound a lil dumb but like i said i dont know a fat alot about bikes (yet)
Trixie
PostPosted: 16:22 - 13 Apr 2007    Post subject: Reply with quote
I would suggest that your first task would be to change the oil and filter. I would also check the plugs, air filter, etc, if you've only had the bike for a month. You just never know how well the previous owner looked after the bike - is there a service history for it?
Have a look at your manual for adjusting the clutch - there will be an adjuster where the cable goes into the lever on the bar.
paulDJSCOTT
PostPosted: 16:27 - 13 Apr 2007    Post subject: Reply with quote
so basically it needs a good servicing. ill have a nosey through the manual i got. i dont know about the service history all i got was the old MOT's
PostPosted: 16:37 - 13 Apr 2007    Post subject: Reply with quote
You can't check directly, but you can adjust all of the freeplay out of the cable by twiddling with the adjusters at either end. Once this is done, put 2mm of freeplay (at the end of the clutch lever) back in the cable, and if you still have the problem you'll need to open 'er up.
bish777
PostPosted: 01:17 - 14 Apr 2007    Post subject: Reply with quote
Old dirty oil can cause this, or oil that is too heavy.
GSXR1100J
The last post was made 19 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 84.97 Kb
