| demoNSR |
 demoNSR Scooby Slapper
 Posted: 13:56 - 13 Apr 2007 Post subject: What needs doing with jets when de-restricting an NSR125? |
Hello guys. I want to de-restrict my NSR125, but am a little unsure of what needs doing with the jets. Can anybody explain? Sorry if this question has been asked before, i did search and could not find anything.
I know on UK spec bikes, there is a baffle inside the header which needs to be removed, and possibly a bigger front sprocket.
I also want to fit an Arrow or Micron race can, will this go straight on without adjustments?
Cheers  |
| ncrn |
 ncrn World Chat Champion
 Posted: 14:17 - 13 Apr 2007 Post subject: |
Well to de restrict there's a plate behind the carb you need to remove, and a baffel in the exhaust that needs removing, see www.nsr125.com for more on that.
A new exhaust will go straight on, but you need to up-jet the carb for that.
Right up-jetting. For this you need to take the fuel tank off the bike, and the air box. Next you need to take your carb out, you'd have to do this to de-restrict so do it at the same time.
Under the carb there is a yellow bolt, unscrew this and pull the bottom of the carb off.
https://www.bikechatforums.com/download.php?id=45410
That is what you will see. Each of those arrows are the jets you need to replace.
You can get the jets from https://www.racecar.co.uk/dellorto/ The carb in the NSR is a 28PHBH/FD and the jets you need are main 138 , slow (idle) 42 , power 65. I bought them for about £13, turned up the next day.
Basically you just swap the jets by un-screwing the old one and screwing the new one in. Very easy to do. Next you have to cut a hole in the airbox as shown in alains guide https://www.geneva-racing.com/~alains/NSRtips.doc
Hopefully thats enough to help you to get the job done  ____________________ Past: 55 Sym Jet, 91 ZZR250, 03 NSR125R. Present: 97 ER-5.
https://www.nsr125.co.uk - NSR Owners forum. |
| Stav |
 Stav Nova Slayer
 Posted: 14:21 - 13 Apr 2007 Post subject: |
Don't forget if you upjet you also need to set the throttle needle to the second groove from the top or it'll run rich.
This thread should give you chapter and verse and also explains how to set up the carb and oil pump.
https://www.bikechatforums.com/viewtopic.php?t=111118
Good luck!  ____________________ Present> 03 Tuono RSV1000 - Past > 02 Honda NSR125RR > 02 Triumph TT600
Cage> 03 Audi TT |
| ncrn |
| Stav |
 Stav Nova Slayer
 Posted: 14:56 - 13 Apr 2007 Post subject: |
It's all in the post linked above about half way down  ____________________ Present> 03 Tuono RSV1000 - Past > 02 Honda NSR125RR > 02 Triumph TT600
Cage> 03 Audi TT |
| ncrn |
| alains |
 alains World Chat Champion
 Posted: 15:52 - 13 Apr 2007 Post subject: |
your link for jets is wrong https://www.dellorto.co.uk mail to mattew cooper sales@dellorto.co.uk
best are : main 138, slow (idle) 42, power 65 and needle set on the 2nd notch from top ____________________ the worst day fishing is better than the best day working |
| demoNSR |
 Posted: 17:34 - 13 Apr 2007 Post subject: |
Thanks guys, i will print it all off and keep you posted on the results. Have some karma for that
Cheers  |
| demoNSR |
 Posted: 13:25 - 16 Apr 2007 Post subject: |
New jets ordered for carb to de-restrict my bike. Will keep you posted on progress guys.  |
| demoNSR |
 Posted: 16:07 - 18 Apr 2007 Post subject: |
Jets arrived today, only £13.40 inc P&P. Great  |
The last post was made 18 years, 330 days ago. Instead of replying here, would creating a new thread be more useful? |
