Javascript problem PLEASE HELP
andrew
Mister Road Rage
PostPosted: 17:36 - 19 Apr 2007    Post subject: Javascript problem PLEASE HELP Reply with quote
I am really stuck and would really apreciate some help. I've been given the task of making a flat webpage for a client at work, the problem i'm having is they want some ads on the site and have supplied ad tags in Javascript. Unfortunatley i've never touched javascript. I'm guessing the random number generator goes into the head of the code but where do i put the other parts of the code? I've made a <div> that will hold the banner, will the remaining code sit in there?
The code is below....
*** Code ***
RANDOM NUMBER GENERATOR - Use only once per page between the head commands
<script language="Javascript">
var axel = Math.random() + "";
var ord = axel * 1000000000000000000;
</script>
a.pop.tmus/achemy-skyscraper 160x600
<SCRIPT LANGUAGE="JavaScript">
document.write('<SCR'+'IPT LANGUAGE="JavaScript1.1" SRC="a_rather_long_url;tile=1;dcopt=ist;sz=160x600;ord= ' + ord + '?" ><\/SCRIPT>');
</SCRIPT>
<SCRIPT>
if ((!document.images && navigator.userAgent.indexOf("Mozilla/2.") >= 0) || navigator.userAgent.indexOf("WebTV")>= 0) {
document.write('<A HREF="a_rather_long_url;tile=1;sz=160x600;ord=' + ord + '?" TARGET="_blank">');
document.write('<IMG SRC="a_rather_long_url;tile=1;sz=160x600;ord=' + ord + '?" WIDTH="160" HEIGHT="600" BORDER="0" ALT=""></A>');
</SCRIPT>
<NOSCRIPT>
<A HREF="a_rather_long_url;tile=1;sz=160x600;ord=123456789? " TARGET="_blank">
<IMG SRC="a_rather_long_url;tile=1;sz=160x600;ord=123456789? " WIDTH="160" HEIGHT="600" BORDER="0" ALT=""></A>
</NOSCRIPT>
Dom
PostPosted: 17:59 - 19 Apr 2007    Post subject: Reply with quote
The other part of the code appears to be what prints out the banner/ad itself, so you'd be right.
Photos and that
bob-a-job
PostPosted: 18:02 - 19 Apr 2007    Post subject: Reply with quote
Indeed - I concur!
andrew
Mister Road Rage
PostPosted: 19:33 - 19 Apr 2007    Post subject: Reply with quote
The thing is, when i insert the code into the banner <div> it isn't a clickable link when it should be. If i place all the code between the <script> tags into the head and the <noscript> bit of the code into the div, and remove the <noscript> tags then it is clickable. Surely the company who gave me the code wouldn't be giving out code that would need to be edited like this.
Any ideas?
Dom
PostPosted: 21:05 - 19 Apr 2007    Post subject: Reply with quote
Firstly you shouldn't need a containing div, so you might as well ditch that to be sure it's not the problem.
Secondly if your removing the noscript tag 'fixes' it then is there a chance it's an odd behaviour from your own browser? (Have you tested in several?)
As you say, auto-generated code directly from the ad company should be perfect, so it's certainly strange. Though in truth that ad code does look a bit of a mess, quite why they need to go generating random numbers I've no idea.
Photos and that
andrew
Mister Road Rage
PostPosted: 21:21 - 19 Apr 2007    Post subject: Reply with quote
Well it's going into a <div> so that i can posistion the banner. Someone else told me the code was a mess but wouldn't tell me why so i'm a bit stuck to be honest.
Could the number generator change the banner depending on what nubmer is generated when the javascript is loaded?
Dom
PostPosted: 08:48 - 20 Apr 2007    Post subject: Reply with quote
That appears to be what it's doing. The variable's called 'ord' and they've got it peppered around all over the place.
Tbh you may be best of asking this at a more techy forum. Although I implement a fair bit of JS I don't write much and tbh I'm not sure what the problem is here.
As a rule noscript content should only appear where scripting is disabled, so for it to effect what's going on when scripting's enabled is very weird.
Try Sitepoint.com/forums.
Photos and that
TheShaggyDA
Repost Police
PostPosted: 09:57 - 20 Apr 2007    Post subject: Reply with quote
The random number is being used to generate a unique url, so that it will always fetch the banner rather than attempt to use a cached copy.
In the NOSCRIPT area, it's just hardcoded to "123456789?", so they won't get as many hits from that.
PostPosted: 10:54 - 20 Apr 2007    Post subject: Reply with quote
Can you try lobbing it between SPAN tags instead?
andrew
Mister Road Rage
PostPosted: 12:25 - 20 Apr 2007    Post subject: Reply with quote
I've tried that but the ad still isn't displaying...i've attached the entire page code below. Embarassed
<HTML>
<HEAD>
<Link rel="stylesheet" type="text/css" href="stylesheet.css">
<TITLE>Blah</TITLE>
</script>
document.write('<SCR'+'IPT LANGUAGE="JavaScript1.1" SRC="a rather long url;dcopt=ist;sz=160x600;ord=' + ord + '?" ><\/SCRIPT>');
</SCRIPT>
</HEAD>
<BODY>
<?php include "common_elements.html"; ?>
<div class="home_holder"><?php include "home_links.html"; ?></div>
<span class="skyscraper">
<SCRIPT>
document.write('<A HREF="a rather long url;tile=1;sz=160x600;ord=' + ord + '?" TARGET="_blank">');
document.write('<IMG SRC="a rather long url;tile=1;sz=160x600;ord=' + ord + '?" WIDTH="160" HEIGHT="600" BORDER="0" ALT=""></A>');
</SCRIPT>
<NOSCRIPT>
<A HREF="a rather long url;tile=1;sz=160x600;ord=123456789?" TARGET="_blank">
<IMG SRC="a rather long url;tile=1;sz=160x600;ord=123456789?" WIDTH="160" HEIGHT="600" BORDER="0" ALT=""></A>
</NOSCRIPT>
</span>
<div class="banner">This is where the banner sits</div>
</BODY>
</HTML>
Dom
PostPosted: 12:29 - 20 Apr 2007    Post subject: Reply with quote
To be 100% sure, you have only submit the URL with 'a rather long url' for the sake of BCF right?
Can you just post the full URLs so we can test it?
Photos and that
andrew
Mister Road Rage
PostPosted: 12:52 - 20 Apr 2007    Post subject: Reply with quote
Yes, would you mind if i pm'd you the actual urls?
I hope it's not something i'm doing wrong, i feel like a bit of an idiot. Very Happy
PostPosted: 12:56 - 20 Apr 2007    Post subject: Reply with quote
Can you PM them to me as well.
andrew
Mister Road Rage
PostPosted: 13:07 - 20 Apr 2007    Post subject: Reply with quote
Done.
PostPosted: 13:33 - 20 Apr 2007    Post subject: Reply with quote
The if statement where it decides whether to put out the link does not equate to true on my machine, the displays are not executed.
andrew
Mister Road Rage
PostPosted: 13:43 - 20 Apr 2007    Post subject: Reply with quote
So what that code is doing is not displaying the ad codes because the user agent isn't mozilla??
PostPosted: 13:49 - 20 Apr 2007    Post subject: Reply with quote
For me "navigator.userAgent.indexOf("Mozilla/2.")" returns -1 (navigator.useragent is "Opera/9.01 (Windows NT 5.1; U; en)"), so basically I think what it is checking for is a bit screwy.
The last post was made 19 years, 187 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 97.67 Kb
