Ped Problems
rik220
PostPosted: 18:02 - 26 Apr 2007    Post subject: Ped Problems Reply with quote
My x8r-x is having problems. It used to do 52 (indicated) on a flat and now it does 46 and it starts to spit/splutter and just generally misbehave at this speed. I also havnt got the same lift, although sometimes i get lift, only when its cold or you have stoped it 5mins and start it again, although the lift then quickly disappears. I tryed another plug, although not new and it made no difference.
What could it be?
Honda x8r. Aprilia Rs50
Honda CR85
Renault Clio 1.2
befdelta7
PostPosted: 18:35 - 26 Apr 2007    Post subject: Reply with quote
first of all try a NEW plug.
then check the electronic choke isnt sticking(wire that goes into the carb).
also clean the airfilter element.
then report back.
out of intrest, do you have a derestricted C.D.I or restricted?
i use to own one of thoes 6years ago, f*cker to fully derestrict. so many restrictions on them, gave up in the end and sold it. still got the original derestricted C.D.I kicking about never got round to throwing it lol.
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
numpty
PostPosted: 20:41 - 26 Apr 2007    Post subject: Reply with quote
have you found it any slower up hills? If so then its most likely you're clutch rollers are worn. Inquire at the dealer about getting some lighter rollers - they arent much money - should make it faster and better up hills Smile
Current bike: CBR600F-Y
rik220
PostPosted: 11:14 - 28 Apr 2007    Post subject: Reply with quote
Got new plug, no difference. Cleaned air filter, no difference.
I see this wire for the choke that you are taking about, what will I do with it?
Honda CR85
Renault Clio 1.2
befdelta7
PostPosted: 22:56 - 28 Apr 2007    Post subject: Reply with quote
unscrew the 2 small screws, slide off the little half circle clip then pull out the black automatic choke unit which the wires go into. clean out the inside of the carb where the automatic choke unit came out of, clean the choke unit its self(you'll know what part i mean when you see it, has from memory a spring around it i think)
as said before get your-self lighter rollers they are around a tenner for 6(which is how many you need) check the condition of the rubber drive belt too, from memory when i owned the X8R-S the performance suddenly decreased, found the problem to be a very worn drive belt.
hope this helps, report back.
P.S there is 8 restrictions on the X8R try taking a look at https://taffspeed.co.uk/page43.html for a run through of the derestrictions and how to deal with them.
rik220
PostPosted: 16:33 - 01 May 2007    Post subject: Reply with quote
Mechanic says its flooding.
So my question is what is it i will do when i take the carb apart?
Would be as simple a thing as the float sticking?
Honda CR85
Renault Clio 1.2
numpty
PostPosted: 21:43 - 01 May 2007    Post subject: Reply with quote
Its most likely to be the float that has stuck open but it could be the choke that is sticking (providing it has an auto-choke).
rik220
PostPosted: 19:04 - 03 May 2007    Post subject: Reply with quote
Had the autochoke out.
It was clean and seemed to be working fine.
Still bad acceleration and top end.
What else now?
Honda CR85
Renault Clio 1.2
numpty
PostPosted: 23:06 - 03 May 2007    Post subject: Reply with quote
Are you 100% positive its flooding. Ped dealerships have a nasty habit of taking people for a ride as they mainly get new riders who have no clue. Swapping to some lighter rollers normally helps. Mine went at 5000 miles ony my old ped and it slowed accelleration, top end and made it go about 2mph up hills. It varies between bikes though.
rik220
PostPosted: 23:11 - 03 May 2007    Post subject: Reply with quote
No point in lighter rollers. They are 6gram and that is 2.5g lighter than standard.
Its just it goes normal once you start it, but this only lasts for the 1st time you start off, next time you start off its dead. Whether its cold or not it will splutter at 46mph and wont go full speed.
Honda CR85
Renault Clio 1.2
numpty
PostPosted: 23:22 - 03 May 2007    Post subject: Reply with quote
have you had a look at the condition of your air filter? If its all covered in crud then it won't be letting enough air through for the fuel to burn fully.
rik220
PostPosted: 23:24 - 03 May 2007    Post subject: Reply with quote
yea, i got it out and got all the crud off it.
It soo friggin annoying. Cant keep up with my mates now!
Honda CR85
Renault Clio 1.2
numpty
PostPosted: 23:27 - 03 May 2007    Post subject: Reply with quote
haha I know how you feel. Mine started off as the fastest ped out of all of us but it ended up as the slowest - thats aprilia quality for you.
All I can suggest is take it to another dealer to get a second opinion.
The last post was made 19 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 78.12 Kb
