nsr stopped running & wont start
richierich32
PostPosted: 22:12 - 26 Apr 2007    Post subject: nsr stopped running & wont start Reply with quote
hi
my 2002 125nsr stopped the other day i had just stopped at a junction and as the revs dropped it just stopped running. i got it home and did the obvious checks - plugs & leads, fuel, 2 stroke, then i checked the airways - all ok i took the reed valve out and my mate thinks they werent seated properly but we turned them round still nothing although they were perhaps not perfect. we tried bumping it and it would run but poorly and it would stall when idling. could this be reeds? any other ideas?
alains
PostPosted: 23:08 - 26 Apr 2007    Post subject: Reply with quote
it's more likely a broken ring , you should go to your nearest garage and have the compression tested
richierich32
PostPosted: 17:53 - 03 May 2007    Post subject: Reply with quote
hi thanks for replying, damn pc hasnt been working.
Wouldnt the bike have seized if it was a ring?
alains
PostPosted: 21:32 - 03 May 2007    Post subject: Reply with quote
when the engine seizes you feel it , generally with a fall down because engine is blocked . mostly when a ring break you have a loss of compression and the mixture pulls back in the engine
The last post was made 19 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 38.33 Kb
