nsr
DBZ
PostPosted: 11:20 - 01 May 2007    Post subject: nsr Reply with quote
help please, i have an nsr 02 reg which frequently dies on me, and refuses to start again for some time, i have changed spark plug and checked air filter, it also leaves puddle of fuel on floor when left standing with fuel tap set to off, i have cleaned carb but am new to this so would be glad of some advice.[/b]
Minty
PostPosted: 12:02 - 01 May 2007    Post subject: Reply with quote
Need more info.
To start - it sounds like the carb floats are sticking.
Do you cut the engine, then turn the fuel off?
My fingers smell of your mum.
fuzz
PostPosted: 12:29 - 01 May 2007    Post subject: Reply with quote
Sounds to me like your overflow pipe is split. If the carb is leaking fuel and then wont start for a while, it is probably because the float bowl is being emptied, and it takes a while for it to refill. I had a similar problem - the chain had worn through the overflow pipe and had effectively turned it into a drain pipe.
https://www.nsr125.com/schem13.jpg
Part number 30
Minty
PostPosted: 13:00 - 01 May 2007    Post subject: Reply with quote
Hmmmmm,
My last NSR had no overflow pipe for >6 months. Not needed unless the carb overflows and thus directs the flow of fuel towards the floor.
What is causing the carb to empty itself in the first place?
Sticky floats is still my bet with an outside chance that the float pin/seat is worn, but shouldnt be on a relatively new bike.
alains
PostPosted: 13:50 - 01 May 2007    Post subject: Reply with quote
the problem is well known , your petrol level in the float chamber is not correct . the fuel valve seat on a small piece of stainless metal . this piece is fixed on the floats . when the level go up the fuel valve go up and lock the fuel entry . the level in the float chamber must be 24mm+-1 . if it's too low your engine will die when accelerating , if it's too high you will have an overflow and a stuffing engine . i reconize it's not easy to set it but do it by small touch . i've tried to show how it is and hope this help
DBZ
PostPosted: 08:28 - 02 May 2007    Post subject: thanks Reply with quote
thanks too all, i will attempt to follow instructions, the overflow pipe isn't split so far as i can see, i dont have problems starting from cold only after bike is warm and has died for no reason, so does this point to something else?
Jamie S
PostPosted: 14:31 - 02 May 2007    Post subject: Re: thanks Reply with quote
Whats probably happening is it is using a carb full of petrol and then dieing on you because the float level is set wrong.
Carb full = about a miles worth of petrol.
DBZ
PostPosted: 09:43 - 04 May 2007    Post subject: nsr Reply with quote
thanks to all for pics, i have cleaned carb again and needle valve, hopefully put it back together right!! well it started and didnt cut out on me once had a good hours run seem to accelerate better, but it still has fuel dripping from breather pipe, not much, enough to cover two pound coin overnight, not a puddle like previous, so is this normal or should i still be worried.
Minty
PostPosted: 11:29 - 04 May 2007    Post subject: Reply with quote
Glad it is a lot better. Sounds like the float height is still a snatch out and when the bike is tipped onto the side stand you are getting a slight overspill.
I know it is a pain to keep stripping the carb but use Alains tips for getting the best float height.
DBZ
PostPosted: 08:47 - 08 May 2007    Post subject: many thanks Reply with quote
i have stripped carb again, checked all breathers, cleaned everything i can get too, so far no drip!!! it rides lovely X
thanks again to you all for the help. DBZ
The last post was made 19 years, 65 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 3.79 - MySQL Queries: 13 - Page Size: 61.96 Kb
