Squeeky Brakes
Demonic69
The Pink Rhino
PostPosted: 13:18 - 17 Sep 2003    Post subject: Squeeky Brakes Reply with quote
It's getting really annoying now! They squeek when I slow down, just before stopping, not really at high speeds. Anyone know what can be done? Please don't suggest oil or wd40 or something on the pads/discs, unless you want it applying to your own brakes nex time we meet Very Happy
Back on a Blade. Just feels so right.
Major_Grooves
The Doctor
PostPosted: 13:19 - 17 Sep 2003    Post subject: Reply with quote
Brake cleaning spray - you'll be amazed how much crap you get rid of when you spray that stuff into the brakes.
PsychoHippy
Jammy Git
PostPosted: 13:21 - 17 Sep 2003    Post subject: Reply with quote
Have you tried putting some copper grease on the back of the pads - between the pad and the thin metal plate?
And yes, I am being serious - my Bandit breaks squeeled like a stuck pig untill someone suggested doing this. Shocked
I spend all my money on bikes and beer, the rest I simply waste!
Kris
so what causes squeeky brakes then? Is it stuff on the disc itself?
How are the brake pads, have they still got life in them?
www.prisonplanet.com
Hex
Party Boy
PostPosted: 13:24 - 17 Sep 2003    Post subject: Reply with quote
The squeak is normally caused from the brake pad moving against the piston. Ie when braking the pad actually moves around and rubs agains the piston so squeaks.
This is why the copper grease generally will stop the squeak.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
Jimmy
You let Nige near your bike on Sunday at the roundabout, that'll be the cause.
Whenever Nige gets near to a car, bike or PC it develops an immediate fault, it's clinically called 'The Halfmoon Effect'.
I'm afraid there is no cure. Watch out for rust developing at an astounding rate, this is another side effect. Very Happy
I've confused my intentions with my abilities
PostPosted: 13:28 - 17 Sep 2003    Post subject: Reply with quote
There's a part that comes on the back of some bikes brake pads called an "anti-squeal plate"its just a pressed steel cover with loads of holes in.
Copper grease on the BACK Very Happy of the pads does a similar job, although it might be worth taking the caliper off of the mounts, taking out the pads and spraying it all with brake cleaner. Brush it all out with a stiff ish brush and wipe it over with a dry rag.
Put copper grease on the pad pins and round the pistons obviously being careful not to get any on the pads themselves. (or discs) Then re-assemble.
Not only should this stop the squeal but it might make your brakes feel a bit better too.
If the pads are brand new then they might just need bit of bedding in... this might stop the squealing also...
Demonic69
The Pink Rhino
PostPosted: 13:29 - 17 Sep 2003    Post subject: Reply with quote
LOL, you the guy on the SV? If so, Welcome! If not, Sod off Wink
The pads are brand spanking new. I'll try the copper grease idea thanks. They kinda hum when applied. It's almost musical Very Happy
Jimmy
PostPosted: 13:35 - 17 Sep 2003    Post subject: Reply with quote
I wasn't there on Sunday but Nige was telling what you were doing.
I just know from experience what happens when Nige is around anything mechanical or pc related, it breaks!
Demonic69
The Pink Rhino
PostPosted: 13:42 - 17 Sep 2003    Post subject: Reply with quote
Maybe it was his fault M dropped her bike! it was quite inexplicable Very Happy
So you coming next Sunday?
Cheers MarJay for the help, I'll take a look at that lot.
Jimmy
PostPosted: 13:48 - 17 Sep 2003    Post subject: Reply with quote
Nige has actually ridden M's bike so it probably is his fault in some way.
Yeah I should be there next weekend. Would have gone on Sunday but was at Alton Towers.
Stew
If it's good enough for top race teams...
PostPosted: 14:24 - 17 Sep 2003    Post subject: Reply with quote
Lol@Jimmy (its james with the red ZXR6 from Elvington btw). Laughing
And yeah Marjay is right about some bikes have anti squeal pads, they are mentioned in the haynes manual for my bike but I have never actually seen one (my pads have plenty of copper grease on the backing plate).
"Unlike public school you don't need to have your arse up and your head down to go a long way...."
PostPosted: 14:28 - 17 Sep 2003    Post subject: Reply with quote
It's definately worth adding a dab of copper grease to the pin while you're at it... It can be just this that causes brakes to rub, because there's a little bit of friction stopping them from sliding back.
Korn
Admin
PostPosted: 17:04 - 17 Sep 2003    Post subject: Reply with quote
While we're here - you'll be amazed how much difference regularly cleaning the caliper pistons can make, especially if you ride through crap weather.
3516 Miles, 11 Countries
Major_Grooves
The Doctor
PostPosted: 19:23 - 17 Sep 2003    Post subject: Reply with quote
I may be wrong but I thought there was an issue of RIDE which said you should use copper grease on the pins but use rubber grease on the pistons. I couldn't get hold of rubber grease so i just used copper grease so it probably makes no difference.
Stew
PostPosted: 21:00 - 17 Sep 2003    Post subject: Reply with quote
I think you are right. I read this too and I think it mentioned that copper grease on the pistons can damage the rubber seal that keeps the brake fluid in. Rolling Eyes
PostPosted: 21:36 - 17 Sep 2003    Post subject: Reply with quote
There's a fairly big debate about whether or not this it the case.
This is obviously only in relation to the sides of the pistons.
Many people do/have done it without problems, so I wouldn't worry /too/ much.
PostPosted: 22:09 - 17 Sep 2003    Post subject: Reply with quote
I use copper slip on the backs of the pads. If they still squeak you can try chamfering the leading edge of the pads. I also have used copper grease on the pistons. Rubber grease is probably better, but given the cost of the stuff and the difficulty of buying it I will keep with the copper grease.
The last post was made 22 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.42 - MySQL Queries: 13 - Page Size: 98.9 Kb
