| Demonic69 |
 Demonic69 The Pink Rhino
 Posted: 13:18 - 17 Sep 2003 Post subject: Squeeky Brakes |
It's getting really annoying now! They squeek when I slow down, just before stopping, not really at high speeds. Anyone know what can be done? Please don't suggest oil or wd40 or something on the pads/discs, unless you want it applying to your own brakes nex time we meet  ____________________ Back on a Blade. Just feels so right. |
| Major_Grooves |
 Major_Grooves The Doctor
| PsychoHippy |
 PsychoHippy Jammy Git
 Posted: 13:21 - 17 Sep 2003 Post subject: |
Have you tried putting some copper grease on the back of the pads - between the pad and the thin metal plate?
And yes, I am being serious - my Bandit breaks squeeled like a stuck pig untill someone suggested doing this.  ____________________ I spend all my money on bikes and beer, the rest I simply waste! |
| Kris |
 Kris World Chat Champion
so what causes squeeky brakes then? Is it stuff on the disc itself?
How are the brake pads, have they still got life in them? ____________________ NSR125RR - ZXR750H1 - ZX9R E1 - GSF600S - GSF600SK3 - VFR400-NC30 - SV1000N - ST1100-R - CBR900RR-R - GSF1200SK5 - GSF600SK1 - VFR1200FA - GSXR1000K2 - ZZR1400 D8F
www.prisonplanet.com |
| Hex |
 Hex Party Boy
 Posted: 13:24 - 17 Sep 2003 Post subject: |
The squeak is normally caused from the brake pad moving against the piston. Ie when braking the pad actually moves around and rubs agains the piston so squeaks.
This is why the copper grease generally will stop the squeak. ____________________ The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio |
| Jimmy |
 Jimmy Borekit Bruiser
You let Nige near your bike on Sunday at the roundabout, that'll be the cause.
Whenever Nige gets near to a car, bike or PC it develops an immediate fault, it's clinically called 'The Halfmoon Effect'.
I'm afraid there is no cure. Watch out for rust developing at an astounding rate, this is another side effect.  ____________________ I've confused my intentions with my abilities |
| MarJay |
 MarJay But it's British!
 Posted: 13:28 - 17 Sep 2003 Post subject: |
There's a part that comes on the back of some bikes brake pads called an "anti-squeal plate"its just a pressed steel cover with loads of holes in.
Copper grease on the BACK of the pads does a similar job, although it might be worth taking the caliper off of the mounts, taking out the pads and spraying it all with brake cleaner. Brush it all out with a stiff ish brush and wipe it over with a dry rag.
Put copper grease on the pad pins and round the pistons obviously being careful not to get any on the pads themselves. (or discs) Then re-assemble.
Not only should this stop the squeal but it might make your brakes feel a bit better too.
If the pads are brand new then they might just need bit of bedding in... this might stop the squealing also... ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| Demonic69 |
| Jimmy |
| Demonic69 |
| Jimmy |
| Stew |
 Stew If it's good enough for top race teams...
 Posted: 14:24 - 17 Sep 2003 Post subject: |
Lol@Jimmy (its james with the red ZXR6 from Elvington btw).
And yeah Marjay is right about some bikes have anti squeal pads, they are mentioned in the haynes manual for my bike but I have never actually seen one (my pads have plenty of copper grease on the backing plate). ____________________ "Unlike public school you don't need to have your arse up and your head down to go a long way...." |
| G |
 G The Voice of Reason
| Korn |
 Korn Admin
 Posted: 17:04 - 17 Sep 2003 Post subject: |
While we're here - you'll be amazed how much difference regularly cleaning the caliper pistons can make, especially if you ride through crap weather. ____________________ 3516 Miles, 11 Countries |
| Major_Grooves |
| Stew |
| G |
| Kickstart |
 Kickstart The Oracle
The last post was made 22 years, 249 days ago. Instead of replying here, would creating a new thread be more useful? |
