Car pulling to the left.
R1stu
Shrek!
PostPosted: 07:27 - 02 May 2007    Post subject: Car pulling to the left. Reply with quote
My car seems to be pulling to the left quite bad. The stearing in wheel is perfectly straight when going straight, but if I let go of it it veers sharply to the left.
I mean let go and its like across 2 lanes in a few seconds!
What could be up? The bloke did say it had a new left suspension arm for the MOT!
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
Skudd
PostPosted: 07:44 - 02 May 2007    Post subject: Re: Car pulling to the left. Reply with quote
sounds like your tracking is way out, could also be your tyre pressures, but with the new suspension I would go for the tracking.
Johnny GSX-R
PostPosted: 08:27 - 02 May 2007    Post subject: Reply with quote
Nearside front brake caliper binding slightly.
If its an old MK1 Mondeo then it could be the front subframe as they were prone to being slightly out of true.
A tyre composition fault will make it wander.
Walloper
PostPosted: 09:44 - 02 May 2007    Post subject: Reply with quote
FORD ! Rolling Eyes
Finglonga
PostPosted: 11:09 - 02 May 2007    Post subject: Re: Car pulling to the left. Reply with quote
Track rod ends are removed to replace them on most cars, so check your tracking as said. Check the tyre wear as if its way out the inside of the tyre may already be mullered.
Andy Sez....
F.Y.Y.F.F.
R1stu
Shrek!
PostPosted: 12:43 - 02 May 2007    Post subject: Reply with quote
Walloper wrote:
FORD ! Rolling Eyes
yep! its a 1994 mark 6 ford escort!
b-f-c
PostPosted: 13:17 - 02 May 2007    Post subject: Reply with quote
Does its direction alter if you accelerate / brake?
If so check the lower suspension arm bush. Circular looking rubber bush thingy with a bolt through it. Seem to remember it should look like a large rubber ball trapped in the suspension arm
Skudd
PostPosted: 15:42 - 02 May 2007    Post subject: Reply with quote
R1stu wrote:
Walloper wrote:
FORD ! Rolling Eyes
You didn't say it was an escort. just burn it and get a car. All the dick heads I have ever known have owned an escort. ( not saying you are one but escorts tended to have attracted the dickheads )
willi
PostPosted: 14:19 - 04 May 2007    Post subject: Reply with quote
You didn't say it was an escort. just burn it and get a car. All the dick heads I have ever known have owned an escort. ( not saying you are one but escorts tended to have attracted the dickheads )[/
Laughing Laughing Laughing Laughing
wat goes around comes around.
Skudd
PostPosted: 16:07 - 05 May 2007    Post subject: Reply with quote
Well have you had the esc......... esco........... escor......... car fixed yet? What was the trouble?
R1stu
Shrek!
PostPosted: 17:17 - 05 May 2007    Post subject: Reply with quote
NO not yet! And im now 17yrold Dick'ead who drives it! Im 27 with 2 kids! Rolling Eyes
Ill get the tracking looked at 1st.
binge
Emo Kiddy
PostPosted: 17:20 - 05 May 2007    Post subject: Reply with quote
It had ONE shock replaced? Confused
Should really replace these in pairs.
Who fitted the spring/shock? You sure they seated the Spring correctly?
Also if ANY hub/suspension/steering rack, Lower arm work is carried out, The wheel alignment should really be checked afterwards anyway.
Pop it into a Kwikfit / ATS / STS and get the tracking checked out. Ask to see the gauges on the car though so they don't just go "Yeh its way out" when it really isnt.
PM me if your unsure on how to read the tracking gauges.
While its up on the ramp, take the opportunity to ask the fitter to check the ball joints, brakes, lower arms and bushes.
Other than that, The one "fairly obvious" thing to check would be tyre pressure. It really can make a difference you have a slightly flat tyre.
Good luck mate.
<|Ben|>
bennett211085
PostPosted: 18:29 - 05 May 2007    Post subject: Reply with quote
My escort van does the same but not as harsh.
The last post was made 18 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 79.8 Kb
