help
v4forlife
PostPosted: 18:26 - 17 Sep 2003    Post subject: help Reply with quote
what gearbox oil is used for thed vfr 400, im very low and have no book
will
www.wilcollinsphoto.co.uk
PostPosted: 18:38 - 17 Sep 2003    Post subject: Reply with quote
Um, you don't have gearbox oil, engine and gearbox oil are one and the same on your bike (its a 4-stroke). The best bet is to drain it all down and put some reasonable quality semi synthetic in there. You may as well change the filter while you're at it too.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 19:21 - 17 Sep 2003    Post subject: Reply with quote
You need to use SAE 10/40w semi synthetic, you can get Castrol GPS from your local halfords(they did have a sale on oils last week).
If you drain it and refill it, it takes 2.5 litres with a oil filter change, and 2.4 litres without an oil filter change. Remember to check this by looking at the lines on the dipstick while the bike is upright.
You're best getting a new oil filter while your at it, don't bother with pattern ones as it isn't worth the risk. Honda ones cost around £8,
Don't use car oil as it contains additives that can make your clutch slip. (In cars that engine oil doesn't lubricate the clutch - it does on bikes).
PostPosted: 21:59 - 17 Sep 2003    Post subject: Reply with quote
To be honest I use a semi synthetic car oil in the 1200 Bandit, the FZ750 and the GPZ500 with no clutch problems at all.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 22:02 - 17 Sep 2003    Post subject: Reply with quote
I knew you'd say that Keith! Smile That's why I said 'can make your clutch slip'. Wink
The last post was made 22 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 43.75 Kb
