What kind of copper grease to get?
FreshAL
Sir Crashalot
PostPosted: 12:12 - 04 May 2007    Post subject: What kind of copper grease to get? Reply with quote
Hi, (again*)
What's the difference between this copper grease
https://www.bikechatforums.com/files/coppergrease.jpg
and this one?
https://www.bikechatforums.com/files/copper_grease_3in1.jpg
Question
Which one is best?
Going to be using it on general fastners, around electrical contacts, and when fitting brake pads.
*Dunno what I'd do without BCF workshop advice at the moment, you are all lovely people Smile
jimbothe
PostPosted: 12:16 - 04 May 2007    Post subject: Reply with quote
Well the most obvious difference to me is that one is a spray and one is a paste by the looks of it.
I think it's just different manufacturers and different ways to apply.
I have always used the tube version and smeared it on the back of the pads with my fingers Thumbs Up
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
veeeffarr
Isn't one a spray? Razz
I'd just get the solid grease to be honest, apply a little bit to the base of screw threads etc.
A controversial issue is the using of it on torque-critical areas as most torques given in service manuals are for DRY threads unless specificed otherwise.
T
notoriousb.e.n
PostPosted: 12:17 - 04 May 2007    Post subject: Reply with quote
i use the canned stuff myself. its thinner than the tubed, but you can use a straw (like with wd40) to all the fiddly bits. also most times you use copperslip you dont need much, so youd be better getting a can.
Ride the tiger! you can see his stripes but you know he's clean!
Gilera Dna 125, Honda CG125 offs: 2 pulled: 1.
PostPosted: 12:26 - 04 May 2007    Post subject: Reply with quote
One is an aerosol and one is in a tube.
Well you asked. The same as the difference between black paint in a tin and black paint in an aerosol, it's the same stuff, just a different way of applying it.
I'd personally go for the stuff in the tube, spray stuff could get everywhere.
I've got a 500g tub of the stuff, wasn't all that expensive (maybe £5-6) which is enough to last for years.
Walloper
PostPosted: 23:06 - 05 May 2007    Post subject: Reply with quote
Would you not wish to know the copper content/to grease ratio or temperature stability?
Ask the manufacturer.
But one or t' other would be fine for general use.
Use a lube on all fasteners unless stated otherwise. Rolling Eyes
Stainless fastners must be torqued very slowly to help prevent the nickel overheating and galling the threads.
You can get non-copper antisieze too you know. Equally as effective.
PostPosted: 23:51 - 05 May 2007    Post subject: Reply with quote
I've found the sprays aren't that great - go for the one in the tube (or get a tub to last you years Smile ).
PostPosted: 00:11 - 06 May 2007    Post subject: Reply with quote
patternparts or someone sell massive tubs, which last for ages.
I find I usually run out too quickly if I use the tubes, which cost about the same as a tub anyway.
And spray stuff always either runs out of the contents or propellant just as you need it.
Second vote for buying a huge tub! Thumbs Up
The last post was made 19 years, 142 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 57.59 Kb
