Exhaust questions
rod98267
PostPosted: 12:51 - 04 May 2007    Post subject: Exhaust questions Reply with quote
This may be a easy thing to do but I am not sure, I have not worked on bikes much. I have been thinking about getting an exhaust system for my gsx-r600 but when looking at the systems it says that you should remap or rejet your bike. So my question is...
-How do you remap / rejet a bike?
-Is it somewhat simple?
Thank you in advance for the help
Itchy
PostPosted: 13:05 - 04 May 2007    Post subject: Reply with quote
depends on the year, Carb vs injectors
if its Carbs , you need to adjust these screws , which you tighten in fully , then undo a slight bit to alter the mixture , my NTV is done via a GUESS, so is GSXR mick's.
Remapping is sort of just changing the fuel injector map in the ECU ,
to do it properly you need somebody to do it for you with the help of a dyno thingie to get the mixture right, too lean it burns holes in your cylinders, too rich it washes away oil off the bored and wears out the pistols quick.
rod98267
PostPosted: 13:13 - 04 May 2007    Post subject: Reply with quote
It's a 2006 and is injected. So I guess I need to take it into a shop and have in dynoed then if I change the exhaust?
Itchy
PostPosted: 13:26 - 04 May 2007    Post subject: Reply with quote
you say exhaust do you mean just the end can or the full system down pipes collector and all? ,
rod98267
PostPosted: 14:12 - 04 May 2007    Post subject: Reply with quote
I would end up getting the full system most likely. Bad karma... must have a longer post haha.
Itchy
PostPosted: 20:44 - 04 May 2007    Post subject: Reply with quote
Just get it Dyno'd then a FULL stainless system with no extra performance is about
£350 , not including fitting, a performance exhaust system'll cost £500+ and is wasted
if you do not dyno and remap your bike ECU which'll be £50-£110, its a bit like putting
BT45s on a 400 sports bike defeats the point,
The last post was made 19 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 49.35 Kb
