how do i know?
nsr_rory
PostPosted: 16:56 - 06 May 2007    Post subject: how do i know? Reply with quote
on my nsr thats not running if you put it into gear and try to push it the rear wheel is completley locked up wether u push it back or forwards. does this mean the top end has seized ? is there a way to find out wether its a top end seizure or bottom or even both ?
Jamie S
PostPosted: 00:11 - 07 May 2007    Post subject: Reply with quote
Could be eaither , your best bet is to strip the whole engine down.
MaybeGuy
PostPosted: 00:18 - 07 May 2007    Post subject: Reply with quote
if its seized, take off the left hand side engine cover and try turning the alternator flywheel, if it wont move, then its seized.
MaybeGuy
PostPosted: 17:47 - 08 May 2007    Post subject: Reply with quote
i think your best bet if it is seized is to either strip it as jamie suggested, or to fill the bike with oil, and chuck a load of oil in the cylinder, take off the top cover (not sure what its called, but the valves are under there) and chck a load of oil in there, concentrating mainly on the cam chain.
then, try the flywheel again, make it turn a bit, leave for a while, turn again and so on.
Jamie S
PostPosted: 19:23 - 08 May 2007    Post subject: Reply with quote
mattsprattuk wrote:
i take off the top cover (not sure what its called, but the valves are under there)
Rocker cover/cam cover Wink
What makes you think it is sized by the way ?
Explain what happened.
MaybeGuy
PostPosted: 19:31 - 08 May 2007    Post subject: Reply with quote
i think he means the bike wont move at all like most will when they are in gear.
the fact that the gearbox works, and when its in neutral it rolls would suggest if anything is seized, it would only be the top end.
PostPosted: 19:32 - 08 May 2007    Post subject: Reply with quote
NSR's are 2t, so no valves, cams, or cam chain. Cool
Jamie S
PostPosted: 19:34 - 08 May 2007    Post subject: Reply with quote
Ah rite , well why doesn't he try the electric/kick starter with the tappet cover off and see if he can see the cam move , if it doesn't it is a bottom end seizure.
EDIT: I have just seen above post, ignore what I said. ^
PostPosted: 19:37 - 08 May 2007    Post subject: Reply with quote
It's a 2t, no cams.
Jamie S
PostPosted: 19:38 - 08 May 2007    Post subject: Reply with quote
I know that now after reading your post that was almost the same time as mine.
The last post was made 19 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 65.34 Kb
