| G |
 G The Voice of Reason
| Sparks! |
 Sparks! Sir Tart-a-lot
 Posted: 16:52 - 01 May 2007 Post subject: |
WTF you wanna put on it???
Just make a wood frame as well as screwing to the wall, brace it with wood etc, it'll be fine for loads of stuff + standing on!! I'm guessing its for spares/storage of bike bits/general garage stuff etc.. It'd be fine!
Mates done the same thing, barely any support at all yet hes got loadssss of stuff on it no probs.... so if you make a half decent frame it'll be low profile and plenty supportive enough for what you want i'd imagine! ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
| G |
 Posted: 17:03 - 01 May 2007 Post subject: |
A few engines could easily make up 200kg. Add in a load of swing arms, forks etc and we're up to 300kg I reckon, bit more for other stuff then possibility of a couple of people standing on it makes it a realistic maximum of 500kg. Double that to be safe and we've got 1000kg.
I don't want to have a large frame - infact I don't want to have anything underneath the area the bikes will be if it at all possible, thus wanting to use metal rather than wood.
The current shelves and such like in my garage have all had the 'g test' and passed fine - namely me swinging my body weight off them or climbing on them - so I'm quite familiar with making stupidly-over strength shelving .
However, even the pretty big bits of wood I've got for my tyre rack and for the ceiling-height shelves above the garage door do flex a bit. |
| gavin |
 gavin World Chat Champion
 Posted: 17:30 - 01 May 2007 Post subject: |
what are the walls made of? anchor fixings can take a huge load but they wont work in lightweight airated blocks. you'd be better hanging it off the top of the wall if you can.
i think you'll be fine with wood, you should be able to use hangers and joists and the leading edge will support itself. all depends apon the span, but you wont find many steel i beams under 4" and 6x2 timber will be fine if its only storage, even 4x2 if its at close enough centres
if you can post up some pics and a sketch you might get some clearer help, i could even give you a price.  ____________________ 1988 TZR125 : 1990 RD350YPVS/ RGV250 HYBRID : 1982 RD80LC : 1983 RD80LC : 1994 RGV250 : 1991 TZR125 / CR500R HYBRID : 1976 BENELLI 500 QUATTRO : 2006 TRIUMPH 675 |
| G |
 Posted: 17:55 - 01 May 2007 Post subject: |
Walls are 'normal' bricks as far as I know. I'm happy to put supports at the sides if required.
Garage is around 270cm wide.
Took some pics, but can't find the lead for the camera .
Anyway, it'd be supported around the edge at the back of the garage with wood, with a 270cm beam in the middle of the garge.
The bits of 2"x4" wood across the same stretch that I've got at the moment seems to bend a bit with not much weight on it, however they are used horizontally, so should be stronger vertically.
If the consensus is that wood should be as strong for the same height, then I'll happily use that.
I do expect there to be a pretty decent weight of stuff on there at points. |
| daz|n00by |
 daz|n00by The Internet
 Posted: 17:59 - 01 May 2007 Post subject: |
just get a 6inch x 4 inch RSJ also known as i I beam.
will hold any weight you could think of putting on it. ____________________ "Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class.  |
| tonyyzf |
 tonyyzf Brolly Dolly
 Posted: 19:03 - 05 May 2007 Post subject: |
I'm using two 4 metre 8" x 5" RSJ's for supports for a cattle grid, it takes 20 tonne lorries going over it.
I would have thought 4" x 2" wood (on there side) would be ample support for the sort of wieght you're talking about. ____________________ Something dark reddish with two wheels and cagiva written on the side
SS50, CB175, CB250N, CB350, CB750K2, DT250, CB750K1, CB750F1, XS1100, CB750F2, FJ1200, FZR1000, YZF1000, GSXR1000, Cagiva Navigator, Triumph Tiger 1050
https://www.cliqueyclanmcc.co.uk/ |
| G |
| gavin |
| SoND |
 SoND World Chat Champion
| G |
 Posted: 21:31 - 06 May 2007 Post subject: |
My house has got concrete floors I think .
Sorry, by horizontal profile I meant with it 'upright'.
50mm box section sounds good - even an extra couple of inches would be useful, though I can chisel into the wood a bit which could be useful. Edit or did I just read it wrong - though even 80mm would buy a bit of space.
I wonder about using a few smaller RSJs (say 4 lots of 50mm). |
| Zimbo |
 Zimbo World Chat Champion
| G |
| SoND |
| G |
 Posted: 08:27 - 07 May 2007 Post subject: |
I presume the 80x40 you're suggesting is used vertically? (so with the 80 side vertical)
Space really is at a premium and while an extra 40mm isn't /that/ much I'd like to save as much as I can.
The box section appeals because if I was using several bits I could weld in some cross supports more easily than to I frame (for more easily supporting the floor without taking up extra height.).
So I'm now thinking whether wood or metal to use several beams across the length of the garage (2.7m) with some smaller supports for the floor going between these, flush with the top of the main supports.
By specs I meant a list of how much weight specific width/height beams/square sections could take.
And, erm, sorry by Horizontal profile, I actually did /mean/ vertical. Just re-read and seem to have confused myself twice - it definitely was vertical when I was getting odd looks jumping up and down on the wood getting strange looks in Wickes . |
| Zimbo |
| SoND |
| G |
 Posted: 12:17 - 07 May 2007 Post subject: |
Space is a big concern. If I could get away with several strips of 40x40 that'd probably make the most sense.
the welding would just be for the cross-section bits that would be there to add slightly better suport to the floor in comparison to just laying (probably) chipboard across on it's own.
(My welding, mostly, sucks ) |
| Grav |
 Grav World Chat Champion
| Zimbo |
| Grav |
| fredsredhat |
 fredsredhat Traffic Copper
| MarJay |
 MarJay But it's British!
 Posted: 19:15 - 11 May 2007 Post subject: |
G,
If you are really set on the 40x40 box section then a couple of braces from the walls might be an idea in a buttress style.
If you want neat welding then see if you can borrow a MIG welder or even better a TIG welder.
Your arc welder doesn't seem to be very easy to use, and I've done some MIG and TIG welding before so I could have a crack at it if you want. I'm free most of this weekend if you need a hand with anything, but I'm kinda trying to avoid doing heavy lifting because of my wrist.
In addition to what everyone else has said above, I don't think the box section strength is going to be the issue, I think it will be the strength of whatever you use to attach it to the walls that will be the main thing. If you are going to use some box or fence posts or something as pillars then that would be good, but it won't help the space. The points of failure will more than likely be at the corners before the box section gives way, unless as I said you have some sort of pillar arrangement.
If you can cut the box at a good right angle and make the crosspiece sit on a couple of upright pieces of box section, then welding it will be strong. All you have to worry about then is if the crosspiece does bend, it'll pull the uprights away from the wall!
As long as everything is carefully measured, and the box section is attached to the wall strongly, I can see it being OK for the weight. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| MarJay |
| jackw72 |
 jackw72 World Chat Champion
 Posted: 20:39 - 11 May 2007 Post subject: |
wooo Reading  ____________________ 08/11/2007 A2 Passed.
Suzuki GSXR 1000 K3
Rapid Training passed |
The last post was made 18 years, 324 days ago. Instead of replying here, would creating a new thread be more useful? |
