Honda NSR125R oil
biker_moose
PostPosted: 21:04 - 23 Apr 2007    Post subject: Honda NSR125R oil Reply with quote
hi i have a honda nsr125r the engine oil is on the min mark does anyone no how to change it or the damage it can do when running it below the mark :s
moto_psycho
PostPosted: 21:09 - 23 Apr 2007    Post subject: Reply with quote
there should be a cap a little above the glass window
and its gearbox oil, 2 strokes dont have engine oil Very Happy
im not sure what the oil grade it requires is, probably something light like 10w40, wait for someone else to know for sure before putting that in
meant to be restricted... aint Twisted Evil
alains
PostPosted: 23:10 - 23 Apr 2007    Post subject: Reply with quote
i think you are talking about gearbox oil . it's a long bolt underneath on the left side see pict . total amount of 10-40w is 0.7L
demoNSR
PostPosted: 23:49 - 23 Apr 2007    Post subject: Reply with quote
Here is an excerpt from the official manual. It states to use "engine oil" I use magnatec, with a grade of 10w40, and it works ok for me.
Some say the wrong oil may cause the clutch to slip, but i have had no problems.
The oil drain plug is just behind the rear brake lever.
Drain until it stops dripping. I even flushed mine out with paraffin before adding the new oil. this ensures that any remaining old oil is removed from the sump.
kart racer
PostPosted: 08:50 - 24 Apr 2007    Post subject: Reply with quote
you can get a good castrol oil specifically for the gearbox - i would avoid anything magnatec etc, althought as demon says he has not had any issues i would not personally take the risk.
Winners never quit, and quitters never win
fuzz
PostPosted: 12:21 - 25 Apr 2007    Post subject: Reply with quote
You can also use a light gear oil, SAE 75w.
biglinds
PostPosted: 09:24 - 08 May 2007    Post subject: Reply with quote
Just a quick note re the above, I use Motul transoil, about £6 for a litre, but it works really well, had absolutely no probs, in fact the clutch response is improved when riding hard over a long period .
Hope this is of use. Thumbs Up Very Happy
I'm having midlife crisis, what the hell!
biglinds
PostPosted: 09:31 - 08 May 2007    Post subject: Reply with quote
biglinds
PostPosted: 09:32 - 08 May 2007    Post subject: Reply with quote
kart racer
PostPosted: 12:18 - 08 May 2007    Post subject: Reply with quote
its that good he told you about it three times - worth a try then Wink
alains
PostPosted: 12:59 - 08 May 2007    Post subject: Reply with quote
hummm.......... a good 10-40W is enough and certainly priceless
demoNSR
PostPosted: 13:47 - 08 May 2007    Post subject: Reply with quote
Magnatec 10w40. Been running with that for over a month now, with not a single problem. Just thought it might be better, as it is supposed to cling better to all parts, so should give your gearbox a longer life. Done that off my own back though, not because of a reccommendation. But it seems to be just fine.
biglinds
PostPosted: 14:35 - 08 May 2007    Post subject: Reply with quote
sorry about telling you three times! new to this forum thang Very Happy
I bow to those with knowlege, I just find Motul transoil works for me.
salty21
PostPosted: 17:02 - 08 May 2007    Post subject: Reply with quote
i use castrol synthetic 4 stroke oil(gps i think its called)but each to there own, im sure most oils will work fine
djneu-trix
PostPosted: 20:20 - 08 May 2007    Post subject: Reply with quote
u the castrol 2 stroke gear oil! (mts) i think! its in the garage and its raining so i aint going to look!
but yes ive used gps 4st oil before and its been fine!
as for running it low, i wouldnt as you can cause some mayjor probs! its only £8 a litre so do it or you might be paying 10 times that l8r on!
pg
The last post was made 19 years, 61 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.67 - MySQL Queries: 13 - Page Size: 83.25 Kb
