| c-m |
 c-m World Chat Champion
 Posted: 15:37 - 08 May 2007 Post subject: Bike wants to take me to vegas |
Either my bike wants to take me to Vegas or its trying to kill me.
Yesterday I had a quick look at the carb and oil pump to make sure any balancing marks were where they should be, and check the cleanliness of the carb.
I covered everything back up as it was and started the bike. All was well, untill I turned the bike around to face the road. Then the bike reved its nuts off. I checked and there was no cable snag nor was excess air getting to the carb.
I didn't have time to mess around so I had to make my journey carefully and turning the engine off when stopped at junctions.
I sorted the problem by playing with the idle speed screw, even though I hadn't changed it from my last ride.
Today I went out on the bike and while in 3rd gear, the throttle stuck open. I had to flick the iginition and pull over.
Luckily I had a screw driver with me, I opened up the carb cover, to notice that the carb throttle valve/piston had got stuck open.
I played around with the top retainer that holds the throttle valve in the carb body. Now i'm unsure how tightly this should screw down as if screwed down well the carb sticks open, if left very very loose the throttle will open and close as intended.
My concern is that the throttle might get stuck again at a more dangerous time. ____________________ Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/ |
| Jamie S |
 Jamie S World Chat Champion
 Posted: 19:30 - 08 May 2007 Post subject: |
Make sure that the cable is well lubed aswell , and as for the bolt ........ Do you have a Haynes manual for the bike ? As there should be a torque setting in there for it.
| c-m |
| Jamie S |
 Posted: 00:09 - 09 May 2007 Post subject: |
Best off posting a picture then mate.  |
| Paddy Blake |
 Paddy Blake World Chat Champion
| c-m |
| Jamie S |
The last post was made 19 years, 56 days ago. Instead of replying here, would creating a new thread be more useful? |
