| StottyB |
 StottyB Trackday Trickster
| demoNSR |
 demoNSR Scooby Slapper
 Posted: 23:39 - 08 May 2007 Post subject: |
just had mine done too, but i got an indicated 97mph at 10,000 rpm in 6th, and there was still more to go. I have done everything but fit a new exhaust, and it is sweet as a nut. Accelleration nearly pulls my arms off. I get 40mph in 1st, up to the red line.
this is what i done to de-restrict.
1. Removed baffle from exhaust header
2. Removed baffle from behind carb
3. Up jetted carb
4. New chain and sprockets
5. Fitted carbon reeds
6. Modified the airbox (this mainly makes it sound more gutsy)
But it like a different machine, and really fekking quick. The only reason i did not go any quicker, is because the front end started to feel really light at 97, and i was shitting myself a bit  |
| alains |
 alains World Chat Champion
 Posted: 01:17 - 09 May 2007 Post subject: |
your throttle cable has a spliter in the middle , a part goes to the oil pump the other to the carb . if you cannot adjust your pump it's may be because the cable is too long now . it's not a great expense , try a new one . also your throttle needle is probably on the middle notch and with upjetting it's better to it at the 2nd notch from top . if you're still too rich download my file https://www.geneva-racing.com/~alains/NSRtips.doc apply openning air box (way 3) page 13 ____________________ the worst day fishing is better than the best day working |
| StottyB |
| fuzz |
 fuzz World Chat Champion
 Posted: 12:23 - 09 May 2007 Post subject: |
I used Alain's jet suggestion, and I have to be honest, it didn't work for me. Fully derestricted, but all parts stock. Did a decoke to make sure, but the engine had much less life than it did before. It wouldn't pull in 6th gear anywhere near as good as it did previously.
My advice is to leave the jets as they were - Honda did not design the bike to be rejetted after derestricing. The only time you need to do that is if you start changing the air filter and/or exhaust system.
As for the needle, altaring it's height changes the midrange, whereas the main jet changes the fuel flow at full throttle/high revs. Lowering the needle will reduce fuel flow, much like putting in a smaller 'midrange jet'.
I changed back to stock jets and had the power back as it was, a big improvement.
Here is an excellent guide to carbs and what the different parts do: https://justkdx.dirtrider.net/printcarbtuning.html Always start from stock settings before attempting tuning so you have a reference if you need to revert back. ____________________ https://www.bikepics.com/members/fuzzbcf/
Bikes: '99 NSR125R, '00 SV650S, K1 GSX-R600, '97 CB500, K3 SV1000S, '16 VFR800 |
| alains |
 Posted: 12:49 - 09 May 2007 Post subject: |
i hope you wont seize your engine  ____________________ the worst day fishing is better than the best day working |
| fuzz |
 Posted: 12:51 - 09 May 2007 Post subject: |
The last post was made 19 years, 54 days ago. Instead of replying here, would creating a new thread be more useful? |
