| mattjs895 |
 mattjs895 Spanner Monkey
| Finglonga |
 Finglonga World Chat Champion
 Posted: 19:27 - 10 May 2007 Post subject: |
You must run it from the battery as the extra load will fry your loom. You can switch it using the wire from the headlight so that it only comes on when the lights are on or from a live feed when the ignition is on.
Also you must use a fuse and placed as close to the battery as possible, as if anything goes wrong, again you will fry your loom.
Also use a BMW type socket and plugs as they have waterproof covers.  ____________________ Andy Sez....
F.Y.Y.F.F. |
| mattjs895 |
| Finglonga |
 Posted: 20:25 - 10 May 2007 Post subject: |
Replace the spotlights with a 12v socket on the pic below and just tap into the feed for the headlight where is says "main beam switch" if you do go from the main beam switch then it will only come on with the main beam. I would suggest the sidelight would be the best option
https://www.offroaders.com/images/projects/lightforce/wiring-diag.gif ____________________ Andy Sez....
F.Y.Y.F.F. |
| Hairy Ben |
 Hairy Ben Scooby Slapper
| JGY6000 |
 JGY6000 Trackday Trickster
 Posted: 22:31 - 10 May 2007 Post subject: |
| Jammy-R6 |
 Jammy-R6 Scooby Slapper
| kawakid |
 kawakid World Chat Champion
| mr.z |
 mr.z World Chat Champion
| iooi |
 iooi Super Spammer
 Posted: 23:21 - 10 May 2007 Post subject: |
Why not use the horn circuit.
It's switched, does not get used that much, so should you have problems its not vital in the dark. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Finglonga |
| feef |
 feef Energiser Bunny
| Demonic69 |
 Demonic69 The Pink Rhino
 Posted: 11:48 - 11 May 2007 Post subject: |
Good plan, running a lighter socket while your lights are on...
Why would you want all that drain on such a small battery?
My lighter socket cost £3.50 for socket, wire, switch and in-line fuse. I had one switch that turned on/off when the seat was removed too but I liked having the phone on charge while I rode  ____________________ Back on a Blade. Just feels so right. |
| Finglonga |
| R1stu |
 R1stu Shrek!
| mattjs895 |
| Molly |
 Molly Two Stroke Sniffer
 Posted: 20:35 - 11 May 2007 Post subject: |
I've done this. . If I remember correctly I wired it directly to the battery via a fuse. I did it this way because I wanted to be able to plug an Optimate type charger into it. ____________________ These are not necessarily the opinions of all Mollys..
Kneedowns? It's what women's knees were made for |
| Gazdaman |
 Gazdaman I did a trackday!!!
| Finglonga |
| Syx |
 Syx World Chat Champion
| Walloper |
 Walloper Super Spammer
The last post was made 19 years, 134 days ago. Instead of replying here, would creating a new thread be more useful? |
