Deaf in one ear.
steveh
PostPosted: 16:40 - 12 May 2007    Post subject: Deaf in one ear. Reply with quote
I woke up this morning tone deaf in one ear, ive tried cleaning it, it got worse, so i started to use "otex" but its not helping.
anyone got any methods for unblocking ears, ive tried warm water, but it failed too Sad
this sucks ALOT
cheers.
J0Al1
PostPosted: 16:44 - 12 May 2007    Post subject: Reply with quote
You can join my club - only, I am permenatly half deaf in one ear. Used to it now, but I got run over once cos of it - so watch the road.
steveh
PostPosted: 16:46 - 12 May 2007    Post subject: Reply with quote
how did you become deaf may i ask?
steve.
pwntifex
PostPosted: 16:49 - 12 May 2007    Post subject: Reply with quote
Just leave it. Happens to me sometimes when I sleep heavily on one side.
carvell
Scuttler
PostPosted: 16:52 - 12 May 2007    Post subject: Reply with quote
Completely deaf, as in if you rub your finger over and tap your ear, you cant hear anything?
If so, then I imagine that's gotta be fairly serious, and worth seeking proper advice over?
Yamaha TDM 850
st3v3
PostPosted: 16:54 - 12 May 2007    Post subject: Reply with quote
There's a possibility you may have a blockage down a little pipe connecting your ear to your nose/throat, the last thing you want to do is be shoving Otex etc down as this will probably make it worse('boots' told me this when I had a similar issue), water will just get stuck at the blockage etc.. it may be one of those things that will clear over time, consult your GP as it's unlikely anything can be done very soon, unless you:
block up the other ear(stick finger in it or something)
then pinch your nose, take a deep breath, then then close your mouth and gently start blowing as if exhaling through your nose, but keeping it pinched tight, this should force the pressure into the ear you are semi deaf in causing it to somewhat 'pop' and get some hearing back, although it will be very weird/different at first and may take some getting used to but may clear it up but if it don't work, I only advised you to try it, I didn't force you to do it Wink Mr. Green
J0Al1
PostPosted: 16:58 - 12 May 2007    Post subject: Reply with quote
steve.
The specialist said he can not be sure, it was either an ear infection or the grommets operation that I had as a kid. I'll never know.
Finglonga
PostPosted: 17:03 - 12 May 2007    Post subject: Reply with quote
Just go to the doctor and get it syringed, not pleasant but it works. Thumbs Up
Andy Sez....
F.Y.Y.F.F.
carvell
Scuttler
PostPosted: 17:08 - 12 May 2007    Post subject: Reply with quote
Not against deafness it doesn't.
Yamaha TDM 850
Dave McCool
PostPosted: 17:14 - 12 May 2007    Post subject: Reply with quote
Pardon?
McGee - "When I go to the mall and see all the high school girls, I have to have DO NOT TOUCH THE GIRLS written on my hand. Every time I go to grope I see it and stop."
K7 GSXR750
Giffer2
PostPosted: 17:27 - 12 May 2007    Post subject: Reply with quote
Join the club!
I've been like it since birth - have a perforated ear drum on that side too!
Mar 2007 - Varadero XL125v7, May 2007 - SV650S
17/05/07 - A2 Test Passed
PostPosted: 18:26 - 12 May 2007    Post subject: Reply with quote
It happened to me when I was at university. It was an excess of wax in that case.
My doctor suggested heating up some olive oil so its warm then using an eye dropper to drop it into my ear, this would melt the wax.
If it isn't that then you definately need to go to casualty or see a doctor!
Valentino Mossy
PostPosted: 19:20 - 12 May 2007    Post subject: Reply with quote
Have one ear done is weird, esp if its really sore already...
Have the both done and try walking straight away Thumbs Up Very Happy
I did that and ended up almost falling over every time !....... screws up your balance something wicked.
I used ear drops for about a week before seeing the doctor,as it gives time for any wax to soften up a bit.
Go see a doctor !
techierob
PostPosted: 19:32 - 12 May 2007    Post subject: Reply with quote
I had a similar thing about twelve years ago. I was cycling to uni every day and kept getting dirty water in my ears which caused an infection, and the left ear completely sealed up with wax and blood.
I booked myself in to get my ears syringed but got sick of waiting after a couple of months, so I eventually shifted it with some otex. I squeezed some in my ear and leaned my head to one side to let it get right down. When it stopped fizzing, I chucked in more otex and after about 45 minutes of that my ear popped and I was able to pour all the muck out.
It specifically advises against doing that on the packaging, but I haven't noticed any long term damage.
NinaMarie
PostPosted: 20:38 - 12 May 2007    Post subject: Reply with quote
Was probably my fault xD
Sym Fiddle: SOLD
Gilera Coguar 125: Written off!!
CBR125R
plugger147
PostPosted: 20:43 - 12 May 2007    Post subject: Reply with quote
I didn't realise there where so many defo's around, I've lost most of the hearing in my left ear too, gotta acoustic neuroma . It's a right pain in the arse trying to have a conversation when theres a bit of background noise all sounds like one big noise.
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
kiers
PostPosted: 21:18 - 12 May 2007    Post subject: Reply with quote
happened to me a couple of times, just woke up and hadnt been able to hear properly, i did what st3v3 said. worked a treat.
'but this wasn't any ordinary clio197.this was the SUPER DUPER version.
ooh i can't wait for the next instalment of superluke and his tales of skullduggery.' - lurker 27 sep 2008
Graham88
PostPosted: 21:48 - 12 May 2007    Post subject: Reply with quote
Try it for life Thumbs Down
bostonshirede...
PostPosted: 10:22 - 13 May 2007    Post subject: Reply with quote
Im training to be a Audiologist, going to go into the NHS when i finish so know a fair bit about ears
Do the olive oil thing, about 3 or 4 drops before u go to bed at night, if that doesn't clear it, go to see ure GP and ask for a referal to the aural toilet clinc, or some GP's will clean it themselves
Failing that, it could be something more serious but ure GP will pass you in the right direction
A note also, 3 or 4 times is fine to do the 'blow air through the ears trick' but its very risky as can cause your ear drum to perferate if you do it too hard or to often, just a word of warning
Sorry for the thread hijack but plugger, what they doing about your neuroma?
Eat well, Stay fit, Die anyway - By the time u make ends meet, they move the ends
Giffer2
PostPosted: 10:32 - 13 May 2007    Post subject: Reply with quote
The last time I went to the GP was when I had an infection in my bad ear, he said he'd send me to the ENT people and that it would take 6 weeks for an appointment................kinda true
6 months later I get a card saying to call them up to arrange my appointment which would be 6 weeks after receiving the card!! Oddly enough though, after the 6 months the infection had long healed!
craigie b
Citizen Smith
It sounds like you have wax in your ear....a very common complaint and one which is quite unpleasant.
As said, put some warn olive oil in your ears twice a day. Tilt your head, pour the oil in (just a little) and keep your head tilted for a minute to give it time to break down the wax. Then tilt the other way to empty the ear.
You'll want to do this for about a week before going to see your doctor who will then syringe the rest out. Before, you could just turn up and they would syringe it there and then but now they only do it once you've been treating the blockage first to soften it (as syringing on rare occassions can cause damage, if the wax is too hard).
Steve H
PostPosted: 11:08 - 13 May 2007    Post subject: Reply with quote
The BCF Blocked Ear Thread
Mellow Yellow
steveh
PostPosted: 11:35 - 13 May 2007    Post subject: Reply with quote
talking me to deaf?
went out round town last night, was a right pain when the bar woman said somthing too me, just nodded :/
Its still no better, and its bugging the shit out of me, feel like getting one of those toilet plunger on my ears (big red one, like the cartoons) Wink
Steve.
bostonshirede...
PostPosted: 11:52 - 13 May 2007    Post subject: Reply with quote
dont suppose your anywhere nottingham Steve?
If so i'll have a look at it for ya
Giffer2
PostPosted: 12:39 - 13 May 2007    Post subject: Reply with quote
steveh wrote:
talking me to deaf?
Steve.
Of course there is the obvious thing that you have an ear infection.
The last post was made 19 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 130.24 Kb
