Outlook express taking ages to open..
Misc
PostPosted: 23:12 - 12 May 2007    Post subject: Outlook express taking ages to open.. Reply with quote
..I've just installed a fresh Windows Xp Pro & my Outlook Express takes about 20 secounds to open, looked around the net but can't see why other then being clogged up which mine obviously isn't, any guesses as to why?
Thanks.
lllN30lll
PostPosted: 09:27 - 13 May 2007    Post subject: Reply with quote
Switch to Windows Live Mail Beta instead Thumbs Up
Turbo R1
CRF450R
Misc
PostPosted: 14:40 - 13 May 2007    Post subject: Reply with quote
Not letting me install for some reason, says it failed.
Anyone else know what could be up with Outlook?
trevoriv
PostPosted: 20:55 - 13 May 2007    Post subject: Reply with quote
Use thunderbird Thumbs Up
Misc
PostPosted: 21:17 - 13 May 2007    Post subject: Reply with quote
I'll give it a try, cheers.
Can't use it with hotmail....Bugger.
Back to Outlook, does anyone know what's wrong with it & why it's taking ages to load of a fresh install?
techierob
PostPosted: 13:07 - 14 May 2007    Post subject: Reply with quote
I'm guessing that it's stuck in send/receive when you open it up. If that's the case, then it might just be having trouble connecting to your pop/imap/smtp servers. Double check all your mail profiles and make sure that the listed servers are spelled correctly and are contactable. Also make sure that your computer is actually online when you launch the application.
Another possibility is that you've got a message stuck in your outbox that's trying to send whenever you start up. If that's the case, then removing the message should fix the problem.
If it's still giving you grief, then launching it from the command prompt with the /safe flag should force it to open without trying to connect to any servers straight away. It's not a permanent fix, but it'd at least determine whether the problem's being caused by the mail client timing out a connection on startup.
Lastly, as just about everybody else here as mentioned, I'd strongly recommend using a different mail client if you have the option.
Misc
PostPosted: 15:32 - 14 May 2007    Post subject: Reply with quote
Cheers techierob, but just had another search & found the problom & the fix. Post it up incase anyone else has the same problom.
Here is the reason and the fix.........
Sometimes removing or disabling Windows (or MSN) Messenger causes OE to open slowly. This will be shown by an entry in the system error log:
The server {FB7199AB-79BF-11D2-8D94-0000F875C541} did not register with DCOM within the required timeout.
To fix this, open Regedit and navigate to this key:
HKEY_CLASSES_ROOT
\CLSID
\{FB7199AB-79BF-11d2-8D94-0000F875C541}
\InProcServer32
In the right-hand pane, double-click on the (Default) value and delete whatever is entered there, leaving it blank. Click OK. Now perform exactly the same step with the key directly underneath, namely
HKEY_CLASSES_ROOT
\CLSID
\LocalServer32
Once both (Default) values are empty, OE will open normally
I hope this fix makes a few people happy
Phil-Magik
The last post was made 19 years, 98 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.16 - MySQL Queries: 13 - Page Size: 51.11 Kb
