Anyone use normal engine oil in Scottoilers?
DynaMight
PostPosted: 23:23 - 13 May 2007    Post subject: Anyone use normal engine oil in Scottoilers? Reply with quote
Anyone? I dont want to try if normal 10-40w is gonna be to thick.
PostPosted: 23:32 - 13 May 2007    Post subject: Reply with quote
I used to use old sump oil.
Now I use EP90 but I had to modify it so the valve opened further because EP90 is really thick.
PostPosted: 23:45 - 13 May 2007    Post subject: Reply with quote
I've used old and new engine oil and it seems to work fine.
DynaMight
PostPosted: 23:46 - 13 May 2007    Post subject: Reply with quote
Cool was the flow rate similar? or did it need adjusting higher/lower?
PostPosted: 23:49 - 13 May 2007    Post subject: Reply with quote
Oops, sorry, too tired. Was in a loobman.
PostPosted: 00:12 - 14 May 2007    Post subject: Reply with quote
Never really noticed a difference with the sump oil to be honest.
Give it a try and see what you think, you can always empty it out again if you're not happy.
Jamie S
PostPosted: 00:41 - 14 May 2007    Post subject: Reply with quote
Light gear oil is better if you have it as it is a bit thinner.
Zimbo
PostPosted: 06:38 - 14 May 2007    Post subject: Reply with quote
Chainsaw chain oil, it's about a quarter of the price and is pretty much the same stuff. Other oils will lubricate the chain just as well but you need to consider fling off the chain as well.
Although, the genuine stuff is a fiver a bottle and lasts thousands of miles, I take the view that it isn't going to break the bank . . . .
DynaMight
PostPosted: 09:19 - 14 May 2007    Post subject: Reply with quote
I agree, it's just that I have 1 litre of cheapy car oil which I used for my Loobman and it's never gonna get used for anything else. I'm gonna give it a try, it cant be to far off.
dodsi
Dirty Carny
PostPosted: 09:32 - 14 May 2007    Post subject: Reply with quote
Dont be tight, use the proper stuff. Its not like it costs the earth and it wont fuck your scottoiler up.
Finglonga
PostPosted: 11:10 - 14 May 2007    Post subject: Reply with quote
Old sump oil here again, never had any problems with using it. Thumbs Up
Andy Sez....
F.Y.Y.F.F.
Trixie
PostPosted: 11:22 - 14 May 2007    Post subject: Reply with quote
A mate of mine also uses EP90, especially with the warmer weather here. No reported problems Thumbs Up
Dead nobodies in company cars...
PostPosted: 11:27 - 14 May 2007    Post subject: Reply with quote
You're not going to break your scotoiler.
All it is is a container of oil with a large needle valve at the bottom attached to a rubber diaphragm with a bit of plastic. Absolute worst case, you get a bit of muck in there that blocks the needle valve and you'd need to give it a flush through.
sickpup
Old Timer
PostPosted: 11:36 - 14 May 2007    Post subject: Reply with quote
ATF fluid works well.
The last post was made 19 years, 93 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.32 - MySQL Queries: 13 - Page Size: 79.21 Kb
