Adjusting chain properley
Huambo81a
PostPosted: 14:44 - 14 May 2007    Post subject: Adjusting chain properley Reply with quote
Ok, i know this is fundemental but . . . .
What is the best way to setup the back wheel exactly the same on both sides, because the marker on the axel seems to be incredibly innaccurate, i.e depending on where you are looking from, it can be on 1.5 notches, or 1.9 notches. do you see what i mean?
So whats the best way of alligning the back wheel, a foolproof way?
I had it setup perfect i thought, but looked again and it was different on both sides depending on where i was looking, i tried to be at exactly the same spot on both sides, but how do you know? without some kind of marker lol am i going to have to mathmatically divide up my garage.
Thanks
Present: 2017 KTM Super Adventure S
Past: 97 Bandit 600 / 05 Bandit 1200 / 03 ZX6-R / 2006 Tuono R / 2001 VFR 800 / 2010 Street Triple R / 2013 Speed Triple S / 2017 S1000XR
PostPosted: 14:48 - 14 May 2007    Post subject: Reply with quote
You can get a laser thingey from Demon Tweeks for about 50 quid.
phill_sumner
PostPosted: 15:29 - 14 May 2007    Post subject: Reply with quote
get a piece of string twice the length of the bike.
straighten up the front wheel and wrap the string around the front of the wheel, so the string is along either side of the bike
bring the ends of the string to the back of the back wheel on either side of the tyre and pull tight
look at the gap between the string and the back of the front tyre and adjust the back wheel until this gap is equal either side of the front tyre
crap description but its cheap and works
parting the A1 like moses parted the red sea
Trixie
PostPosted: 15:32 - 14 May 2007    Post subject: Reply with quote
And when you've got your wheel alignment sorted, when you adjust the chain, just adjust using equal turns on both sides, thereby keeping the wheel in alignment. The markers on the swingarm are generally not very accurate.
Dead nobodies in company cars...
PostPosted: 15:35 - 14 May 2007    Post subject: Reply with quote
https://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MCYCLE&pcode=PFIPCAT
I don't see why this wouldn't work....
phill_sumner
PostPosted: 21:30 - 14 May 2007    Post subject: Reply with quote
it would mate but its 50 quid
SoND
PostPosted: 21:33 - 14 May 2007    Post subject: Reply with quote
https://www.triginstruments.co.nz/catalog/images/caliper_digvernier.jpg
Get a vernier caliper. You can get a cheap digital one between £20-30 and it will be more accurate than you need.
Hold a scaffold pole against the side of the rear wheel and compare its position at the front of the bike with the front wheel. Then do the same on the other side of the rear wheel. And fiddle with the adjusters to get it even. The marks on the swinging arm are not likely to be at all accurate.
Once it is in like I just make certain I turn the adjusters on each side the same number of flats.
Huambo81a
PostPosted: 22:45 - 14 May 2007    Post subject: Reply with quote
Thanks for the replies people, i have adjusted the chain before, but only today realised how completely innacurate the marks on the swingarm are, i`ll try the string thing tomorrow.
Kal
PostPosted: 11:08 - 15 May 2007    Post subject: Reply with quote
Worlds most boring adjustment.
Push wheel all the way to the back of the slot.
For every sixth of a turn on the left make a sixth of a turn on the right (so the flat of the nut is always at the top!)
Takes forever the first time you do it and its tempting to cut corners but once its done its not a big problem to keep adjusted.
Kal...
The last post was made 19 years, 125 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 65.02 Kb
