How to take a bike off the centre stand?
oriel dave
PostPosted: 10:19 - 19 May 2007    Post subject: How to take a bike off the centre stand? Reply with quote
On two separate occasions I have been told to do this different ways:
a) Left hand on left handlebar grip, right hand on right grip and front brake - push forward off stand and apply front brake
b) Left hand on left handlebar grip, right hand on grab handle beneath seat - pull off stand with no brake control
Is there a right and wrong way? (This is for a 125)
Will Mr Examiner care?
Thanks very much
Dave
kiers
PostPosted: 10:43 - 19 May 2007    Post subject: Reply with quote
as long as you dont drop it, im sure the examiner won't care. just do it however you feel works best for you
'but this wasn't any ordinary clio197.this was the SUPER DUPER version.
ooh i can't wait for the next instalment of superluke and his tales of skullduggery.' - lurker 27 sep 2008
Giffer2
PostPosted: 10:54 - 19 May 2007    Post subject: Reply with quote
I was told never to roll the bike off the centre stand (method a), always lift the bike off (method b).
Basically method b and then when the bike is on it's back wheel but you still have pressure on the stand with your foot and the bike is level then move your right hand to the front brake and then move your foot off the stand.
But for your test, I'd recommend just using the side stand - you'll find it much easier.
Mar 2007 - Varadero XL125v7, May 2007 - SV650S
17/05/07 - A2 Test Passed
PostPosted: 11:01 - 19 May 2007    Post subject: Reply with quote
Well, I was taught to push it off the stand using both hands on the bars and immediately stop it rolling with the front brake (so the examiner sees the forks dive a little bit). Thereby proving you are in control of it and that the bike isn't going to roll off down the street.
colin1
Captain Safety
PostPosted: 11:08 - 19 May 2007    Post subject: Reply with quote
ive no idea if you can do this on other bikes, but on my yp250, you just sit on it , lean back, and drive forward. the centre stand then just flicks up, and you keep moving and ride away
i suspect mr examiner would have some problem with this
teampots
PostPosted: 22:50 - 19 May 2007    Post subject: Reply with quote
i was told to place my left hand on left handle bar with my right hand on the pillion bar then while resting your foot on the stand roll it off, keeping pressure on the stand, then swap your right hand to the front brake then let your foot off the stand and apply the front brake to keep control of the bike
and yes mr examiner will care if you just pull it straight off as it will look as though you dont have control okf the bike
Kurt
PostPosted: 11:31 - 20 May 2007    Post subject: Reply with quote
teampots wrote:
i was told to place my left hand on left handle bar with my right hand on the pillion bar then while resting your foot on the stand roll it off, keeping pressure on the stand, then swap your right hand to the front brake then let your foot off the stand and apply the front brake to keep control of the bike.
Yep, I did my CBT a couple of weeks ago so this is all still fresh in my memory and that's exactly the way I was told to do it. I think the point is that once you've lifted it forward, the stands still i contact with the road keeping the bike stable so that then allows you to switch hands and put your right hand on the front brake.
- Current Bike: Honda Varadero 125 -
timjim
PostPosted: 19:42 - 20 May 2007    Post subject: centre stand Reply with quote
in the opinion of safety and caution,id say to be on the left of the bike,left hand on left bar,right hand on right bar(covering brake),put left foot just in front of centre stand and rock bike forward off of stand.,just practice.tim Thumbs Up
oriel dave
PostPosted: 20:12 - 20 May 2007    Post subject: Reply with quote
Thanks everyone, much appreciated,
Dave
iooi
PostPosted: 21:31 - 20 May 2007    Post subject: Reply with quote
Leg over bike, sit on seat, both hands on bars and push forward with feet.... You can then use front brake to stop bike.
Tend to find that on some bikes standing at the side and pushing can result in a large dent in leg...... Thanks to stand comming up.
c-m
PostPosted: 21:48 - 20 May 2007    Post subject: Reply with quote
method be is all very well but you can only use it if your bike has grab rails. mine doesn't
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
gypsyjackson
PostPosted: 23:09 - 20 May 2007    Post subject: Reply with quote
This is how I do it as it's easy to do once you're kitted up and the engine's started, but I was told specifically not to do it this way on my CBT. Dunno why.
PostPosted: 09:32 - 21 May 2007    Post subject: Reply with quote
Wrong for the test. Tests never reflect the real world.
If you're taking your test, it's the DVLA's ball, play by their rules. Thumbs Up
iooi
PostPosted: 17:14 - 21 May 2007    Post subject: Reply with quote
Mmm, Linky
Strange as to me you have not total control over bike.Especially at the point where you only have one hand on the bars. If it starts to go away from you.... You are stuffed.
Might be Ok on level ground, but any sort of camber....
AcIdBuRnZ
PostPosted: 11:26 - 22 May 2007    Post subject: Reply with quote
That's what I was taught to do too Thumbs Up Smile
krebsy
PostPosted: 15:46 - 22 May 2007    Post subject: Reply with quote
For the test, park your bike facing out of the bay and on the sidestand. Makes it easier to get out and you're not faffing around with the centre stand....
I put the ZZR up onto the centre stand by simply standing on the lever, lift the other foot off the ground and shift my weight towards the back... It just pops up onto the stand with no issues. I tend though to then put the sidestand down as well so when I roll the bike forward off the centre stand I can put it straight down onto the sidestand. I just dab the front brake lever to lower it down so the bike doesn't roll on and lift up the sidestand.
K.
1280 x 1024.
krebsy
PostPosted: 16:02 - 22 May 2007    Post subject: Reply with quote
K.
1280 x 1024.
Opal
PostPosted: 23:16 - 22 May 2007    Post subject: Reply with quote
Let me get this straight, I put my left hand on the left handlebar and my right hand on the right handlebar this leaves my left hand and my right hand in total busy mode, if my right hand is not on the left handlebar and my left hand is not on the right handlebar, this means my left hand is doing the right thing. My right hand must also be right as it's not left out, I carnt see nothing left to say so it must all be right. Confused
maaarcooose
PostPosted: 09:18 - 23 May 2007    Post subject: Reply with quote
Ditto....
Did my CBT last Friday and my instructor described and demonstrated exactly the same method, but I was having trouble with it as I used my own bike (Hyosung Cruise II) so she had a go.
Because of the handlebar position and where the mirror bar comes, it was impossible to do it with the taught method. After this she said I might was well just sit on and rock it forwards.
!m!
AcIdBuRnZ
PostPosted: 10:40 - 23 May 2007    Post subject: Reply with quote
But what if you are parked on a slope and the bike starts to roll away? FAILED Laughing
Trust me here, Use the both hands on the bars method - then all you got to do is push both handlebars and the bike will roll forward off the stand, and thus leaving you in total control as you can immediately apply the front brake.
Easy Thumbs Up
PostPosted: 10:43 - 23 May 2007    Post subject: Reply with quote
It's about what the test wants.
The DVLA method is to dig the stand in to stop the bike and keep it stable, then transfer your stand to the front brake. TBH i wasn't even asked to do it on my test.
matthab
PostPosted: 18:38 - 23 May 2007    Post subject: Reply with quote
I take my ybr off its stand with both hands on the handle bars right hand covering the break and left keeping it steady and straight.
My arguement has always been. Im not a very tall person and find the bike roles abit as it comes off so covering the break stops the role espically on a hill.
2005 - 2006:Peugeot jet force 50 TDSI (sold)
2006 - Present: Yamaha YBR125 06 (extras:pilot sporty tyres and screen)
Louise
PostPosted: 23:08 - 23 May 2007    Post subject: Reply with quote
Is this for the test? I didnt do it, I got told it wasnt part of the test anymore.
I sit on the bike, hover front brake and use all the power I have Embarassed
Getting it on the main stand however, It just no go for me Laughing
thenuttytart
PostPosted: 15:48 - 25 May 2007    Post subject: Reply with quote
You are meant to have one hand on the left handlebar and one hand on the sissy bar/back of bike. The reason being that you are facing the weight straight on and should have more control over the bike than if you are twisted slightly. The rules are a bit like the safety rules about bending your knees, with your back straight to lift something off the floor in the work place. Great in theory but not practical in reality. My old boss was a stickler for health and safety and I always made sure I'd bend my knees when I picked something up off the floor whilst she was about. It was a real struggle to get back up again if I was carrying something heavy though, cos I'm top heavy without extra weight so I looked like a blooming weeble lol! Stick it on the side stand during the test and don't worry too much or you'll get flustered and make mistakes.
Good luck!
Smile! Frown lines are not attractive!!
feef
Energiser Bunny
PostPosted: 16:02 - 25 May 2007    Post subject: Reply with quote
give it a good kick, or push it over... fold up the stand and then pick the bike up. make sure you have good crashbungs Wink Laughing
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
The last post was made 19 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 134.3 Kb
