MOT questions
Resurrection
Ballast Boy
PostPosted: 00:11 - 22 May 2007    Post subject: MOT questions Reply with quote
First off.
I had a load of electircal problems a while back and i never bothered putting bulbs back into my sidelights.
Is this going to be an MOT fail or will i need to go get some bulbs?
https://i115.photobucket.com/albums/n290/benus_maximus/DSC00007.jpg
The main bulb and headlight works and has high beam setting.
Secondly my speedo cable snapped a while ago.
Is this a fail?
Res
ZX9r
thegubner
PostPosted: 00:13 - 22 May 2007    Post subject: Reply with quote
I think they say ALL lights that are fitted have to work, cant you just take the side lights off for MOT, not sure about your speedo cable, but you have that digital one on there don't you?
alien.46.uk
PostPosted: 00:14 - 22 May 2007    Post subject: Reply with quote
I think your sidelights are fine as long as your main light has normal light and high beam.
As to Speedo cable, i think a working speedo is required, not 100% on that but im pretty sure.
2007 Kawasaki ZX10R :: 1998 Kawasaki ZX-9R - SOLD
1998 Yamaha FZS600 Fazer - SOLD :: 1994 Aprilia Pegaso 125 - SOLD
Resurrection
Ballast Boy
PostPosted: 00:15 - 22 May 2007    Post subject: Reply with quote
Yeah i keep hearing conflicting stuff so thats why i thought i'd ask the masses
Oh well yet more money
Res
ZX9r
stu_m
PostPosted: 00:18 - 22 May 2007    Post subject: Reply with quote
if lights are fitted the must work Very Happy
think the speedo it a failure too as its fitted it has to work
but not many places actually check the speedo
its a weird some of the rules they have i know its not bikes but my dads landrover had seat belts fitted and 1 of them didnt work so it failed even though they dont have to be fitted as its ancient he took them out and it passed crazy eh Confused
might be worth just taking the lights off for mot if you can Confused
Stu
thegubner
But what about your digital one, that works, dont spend more money her, get the GSX back Thumbs Up
Resurrection
Ballast Boy
PostPosted: 00:27 - 22 May 2007    Post subject: Reply with quote
The digital one is off a push bike Embarassed
I'll just bang lights back in. I'm just REALLY lazy
Bulbs are just abit hard to get hold of
Oh well best get shopping
Res
ZX9r
thegubner
PostPosted: 00:56 - 22 May 2007    Post subject: Reply with quote
push bike?
pikey Laughing
thegubner
PostPosted: 01:44 - 22 May 2007    Post subject: Reply with quote
I think I may have a selection of bulbs in the shed
Resurrection
Ballast Boy
PostPosted: 01:48 - 22 May 2007    Post subject: Reply with quote
I've got one bulb
I doubt you'll have one
I'll post a picture of it tomorrow when my cam is charged
Its an odd one with a big lip under the glass
Res
ZX9r
thegubner
PostPosted: 01:51 - 22 May 2007    Post subject: Reply with quote
i don't have any odd bulbs, mine are normal, some have lips some don't
But as i said no odd one's.
PostPosted: 11:48 - 22 May 2007    Post subject: Reply with quote
No requirement for a working speedo. It's not tested on the MOT. I specifically asked the guy who MOTs my bikes this and it has been MOTed for the last three years without a working speedo (there isn't even a speedo drive on the wheel).
The light's will fail if they aren't working. You should get away with taping them up for the MOT (stick gaffa tape or similar over the lens) because it does have a proper light anyway. Asking your MOT tester beforehand is the best bet though because in my experience, many of them make up non-existant rules to suit themselves.
DaveH
PostPosted: 12:03 - 22 May 2007    Post subject: Reply with quote
My bike failed for not having sidelights, just got a couple of white LED's and used them instead as I didn't have the original bulb holders. Wedged in place usinga couple of rubber grommets and some insulating tape.
https://www.timhastingsracing.co.uk/
ZX7R & ER6F
PostPosted: 12:35 - 22 May 2007    Post subject: Reply with quote
I was working on the assumption that there is a position light in the 'main' headlamp unit on that bike. There is certainly a space for one. That'll have to have a working bulb in it.
The two additional lights are surplus to requirements but if they are fitted and unmasked they will be expected to work.
Resurrection
Ballast Boy
PostPosted: 13:50 - 22 May 2007    Post subject: Reply with quote
Right thankyou very much
Just gotta mess about finding a matching bulb now
Res
ZX9r
DrJustice
PostPosted: 19:48 - 23 May 2007    Post subject: Reply with quote
Seems odd I would have thought not knowing what speed your doing would be considerd a safety issue ,handy though as mine dose not work either Very Happy
Non Omnis Moriar
carvell
Scuttler
PostPosted: 19:49 - 23 May 2007    Post subject: Reply with quote
Why?
Yamaha TDM 850
DrJustice
PostPosted: 19:55 - 23 May 2007    Post subject: Reply with quote
carvell wrote:
Why?
Because you won't know if you exceeding the speed limit which could be considerd as dangerous Confused
Non Omnis Moriar
MattEMulsion
PostPosted: 14:33 - 24 May 2007    Post subject: Reply with quote
A working speedo has never been part of the MOT test. It is not classed as dangerous because the rider/driver should always drive to the conditions regardless and the speed limit is only a limit, it doesn't mean that it is safe to drive at that speed at that time anyway. Dangerous is things like bolts missing out of brake calipers, tyre worn down to its cords etc, things that are likely to cause danger to yourself or others that you have no direct control over.
Yamaha YZF-R6
Resurrection
Ballast Boy
PostPosted: 16:01 - 24 May 2007    Post subject: Reply with quote
I'm quite certain i know my speed by the gears and revs.
Plus i go through the speed boards telling you your speed under the limit or on it etc when i want.
Res
ZX9r
big.bee.time
PostPosted: 16:32 - 24 May 2007    Post subject: look at this Reply with quote
Hi there try having a wee look at this think it should tell you all you need to know https://www.ukmot.com/bike/index.asp
DrJustice
PostPosted: 15:54 - 25 May 2007    Post subject: Reply with quote
Make's sence Thumbs Up
However I'm surprised its legal to have a speedo thats not working because the bike then stops clocking up the miles and if you get it working at a later date and sell it on the milage would not be genuine !
Non Omnis Moriar
PostPosted: 17:15 - 25 May 2007    Post subject: Reply with quote
It's illegal to misrepresent the mileage when selling a bike. You would be required to make the buyer aware of any discrepancy between what the odometer reads and what the true mileage is.
This is usually done by putting a sticker reading "Mileage not garaunteed accurate" over the odometer. It is also worth writing this into the bill of sale which you both sign.
crazymotorbik...
PostPosted: 17:18 - 25 May 2007    Post subject: Reply with quote
Hey,
My gpz400r has a sidelight switch but no sidelights fitted. Its passed all 3 MOTS ive put it in for with no problems and no recomendation.
Cheers,
Shaun.
PostPosted: 17:23 - 25 May 2007    Post subject: Reply with quote
Aye, the trouble is you can clearly see the hole in the reflector for the sidelight bulb when you look at the headlamp on that bike.
The last post was made 19 years, 85 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 126.77 Kb
