| Misc |
 Misc World Chat Champion
 Posted: 16:17 - 23 May 2007 Post subject: Torque wrench |
Right, after a torque wrench & have about £40 for one but want one that'll benefit me most as i understand some do lower torquing & others, higher. Basically worried about over doing the sump plug when i'm draining the oil. Will i need £40 for this or will a cheap one do it.
I don't go deep into the bike so this is the only thing i'd be torquing really.
Yes, i know alot of you don't need one for the oil but i've heard that if you do end up stripping it, you need a whole new oil pan.
One other things, will the Halfords 55 piece set suit me, as i don't know if i'd actually use the 150 set?
 ..... Quote Me Happy
| Misc |
 Posted: 16:33 - 23 May 2007 Post subject: |
| Joe wrote: | I've never used a torque wrench on a sump plug - just do it up tight then 'nip' it a bit tighter.
I'm about to do an oil change on mine, as well as clean and adjust my chain. Like I said before, you're welcome to come and do yours at the same time.
It sounds like the 150 piece set is a bit of overkill if you're only going to adjust your chain and change your oil. Just get the bits needed for those. |
Ah right, can i use some of this Loctite i hear about just incase.
Would like to come over but my waiting on my chain & sprockets so shouldn't really be riding, much . I'll give it a shot anyway.
55 piece it is then, even tho i'll only use a few it'll be nice for the future i suppose, once i start doing more.
Whilst i'm on this topic, what brake fluid would my bike use as i found a link but then it stated if my bike was a dot1,2,3 etc.
It's a 2003 ninja B1
https://www.motorcycle-road-and-race.co.uk/catalog/product_info.php?cPath=258_514&products_id=190067
Would this need to be done anyway, only had it done a couple of months back, the service manual is saying every 2 years?
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 19:01 - 23 May 2007 Post subject: |
I use it on the sump and rear axle.
You don't want to overtighen your sump plug bolt.  ____________________ My Flickr |
| Misc |
 Posted: 19:20 - 23 May 2007 Post subject: |
Cheers fella's, can only get one torque wrench at the moment so looking at a the lower force one which is a Draper.
Reading a bit & it looks as tho i don't need the brake fluid changed, as it's every 2 years.
Ta,
| Rookie |
 Rookie World Chat Champion
| Wafer_Thin_Ham |
 Posted: 19:52 - 23 May 2007 Post subject: |
On my GIxxer 4 the torque for the rear axle was 90nm  ____________________ My Flickr |
| Misc |
 Posted: 20:53 - 23 May 2007 Post subject: |
I'm getting the shop to fit the new chain so won't be adjusting it for a while, i will get the higher torque wrench but for now the lower will do me for servicing the bike.
Does anyone know where i can find a gapping tool for sparkplugs, or anything i can use, pretty hard to judge a 0.8mm gap.  |
| Wafer_Thin_Ham |
| Misc |
 Posted: 20:59 - 23 May 2007 Post subject: |
Cheers Joe, Big_ham yes, i think it's also called a gapping tool.
Now my coolant level is just getting past 'low', can you top it up with more coolant/anti-freeze even if it's a different brand or will i need to flush the old one out then top up?
| Finglonga |
 Finglonga World Chat Champion
| Misc |
The last post was made 19 years, 55 days ago. Instead of replying here, would creating a new thread be more useful? |
