Torque wrench
Misc
PostPosted: 16:17 - 23 May 2007    Post subject: Torque wrench Reply with quote
Right, after a torque wrench & have about £40 for one but want one that'll benefit me most as i understand some do lower torquing & others, higher. Basically worried about over doing the sump plug when i'm draining the oil. Will i need £40 for this or will a cheap one do it.
I don't go deep into the bike so this is the only thing i'd be torquing really.
Yes, i know alot of you don't need one for the oil but i've heard that if you do end up stripping it, you need a whole new oil pan.
One other things, will the Halfords 55 piece set suit me, as i don't know if i'd actually use the 150 set?
Quote Me Happy
PostPosted: 16:25 - 23 May 2007    Post subject: Reply with quote
I've never used a torque wrench on a sump plug - just do it up tight then 'nip' it a bit tighter.
I'm about to do an oil change on mine, as well as clean and adjust my chain. Like I said before, you're welcome to come and do yours at the same time.
It sounds like the 150 piece set is a bit of overkill if you're only going to adjust your chain and change your oil. Just get the bits needed for those.
Misc
PostPosted: 16:33 - 23 May 2007    Post subject: Reply with quote
Ah right, can i use some of this Loctite i hear about just incase.
Would like to come over but my waiting on my chain & sprockets so shouldn't really be riding, much Smile. I'll give it a shot anyway.
55 piece it is then, even tho i'll only use a few it'll be nice for the future i suppose, once i start doing more.
Whilst i'm on this topic, what brake fluid would my bike use as i found a link but then it stated if my bike was a dot1,2,3 etc.
It's a 2003 ninja B1
https://www.motorcycle-road-and-race.co.uk/catalog/product_info.php?cPath=258_514&products_id=190067
Would this need to be done anyway, only had it done a couple of months back, the service manual is saying every 2 years?
PostPosted: 19:01 - 23 May 2007    Post subject: Reply with quote
I use it on the sump and rear axle.
You don't want to overtighen your sump plug bolt. Thumbs Up
Misc
PostPosted: 19:20 - 23 May 2007    Post subject: Reply with quote
Cheers fella's, can only get one torque wrench at the moment so looking at a the lower force one which is a Draper.
Reading a bit & it looks as tho i don't need the brake fluid changed, as it's every 2 years.
Ta,
Rookie
PostPosted: 19:30 - 23 May 2007    Post subject: Reply with quote
You might find the higher torque one a bit more useful, for example the rear axle nut is a pretty beefy torque, and that's going to be a common one, for adjusting the chain.
PostPosted: 19:52 - 23 May 2007    Post subject: Reply with quote
On my GIxxer 4 the torque for the rear axle was 90nm Shocked
Misc
PostPosted: 20:53 - 23 May 2007    Post subject: Reply with quote
I'm getting the shop to fit the new chain so won't be adjusting it for a while, i will get the higher torque wrench but for now the lower will do me for servicing the bike.
Does anyone know where i can find a gapping tool for sparkplugs, or anything i can use, pretty hard to judge a 0.8mm gap. Smile
Quote Me Happy
PostPosted: 20:55 - 23 May 2007    Post subject: Reply with quote
https://www.spark-plugs.co.uk/pages/pricing/maintenance_tools.htm
PostPosted: 20:56 - 23 May 2007    Post subject: Reply with quote
A feeler gauge??
Misc
PostPosted: 20:59 - 23 May 2007    Post subject: Reply with quote
Cheers Joe, Big_ham yes, i think it's also called a gapping tool.
Now my coolant level is just getting past 'low', can you top it up with more coolant/anti-freeze even if it's a different brand or will i need to flush the old one out then top up?
Finglonga
PostPosted: 21:04 - 23 May 2007    Post subject: Reply with quote
It will probably need adjusting more in the first few hundred miles than when its settled down. Should be checked every week minimum anyway. Wink
Andy Sez....
F.Y.Y.F.F.
Misc
PostPosted: 21:08 - 23 May 2007    Post subject: Reply with quote
Good point, but i suppose it won't be worse then what my chain was/is, even if it's not adjusted & i dread to think how long i've been riding like that.
The last post was made 19 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 3.52 - MySQL Queries: 15 - Page Size: 77.86 Kb
