Headlamp Bulbs
mrbluesbox
PostPosted: 11:09 - 24 May 2007    Post subject: Headlamp Bulbs Reply with quote
ello
im looking for some slightly brighter whiter headlamp bulbs for my derbi rather than the orange coloured ones i got on at the mo so i was looking round at some of the xenon ones on ebay.
got a few questions about them.
firstly my bike is supposed to use 12v 35w H11 bulbs - all the xenon ones ive seen are 55w bulbs - would this be a problem?
ive also seen some LED bulbs - does anyone know which are better the xenon ones (https://cgi.ebay.co.uk/H1-H3-H4-H7-H8-H9-H10-H11-H12-HB3-9005-HB4-9006-XENON_W0QQitemZ290120111303QQihZ019QQcategoryZ72235QQrdZ1QQcmdZViewItem) or the LEDS ones (https://cgi.ebay.co.uk/2pcs-H11-Fog-Lamp-1W-High-Power-LED-Xenon-White-Bulb_W0QQitemZ200111616992QQihZ010QQcategoryZ72235QQssPageNameZWDVWQQrdZ1QQcmdZViewItem) - ive never seen either so have no idea.
cheers
Gaz.
I seem to have misplaced my pants...................
hmmmnz
PostPosted: 13:32 - 24 May 2007    Post subject: Reply with quote
it depends on how good your charging system is, and how thick the wiring to the light is,
have you got a manual handy??
have a look in there and see if there is any specs on your alternator,
the humans are dead
I kick arse for the lord
mrbluesbox
PostPosted: 14:42 - 24 May 2007    Post subject: Reply with quote
Hi there
this is all the info i can find on the electrical stuff from the manual that related to lights / alternators:
CHARGING SYSTEM
Type : Magneto
Magneto flywheel Model/Manufacturer Output :
F4FU / YAMAHA
14V 170 W 5000 rpm
Charging coil resistance
(colour of the conductors)
0.6O ohm ± 20% a 20º C W-W
LIGHTING VOLTAGE
(Min) - 12V / 3.000 rpm
(Max) - 15V / 8.000 rpm
RECTIFIER/ REGULATOR
Type : Shortcircuit type semiconductor
Model : SH629B-11/SHINDENGEN
Voltage regulated without charge : 14.1 ~ 14.9 V
Capacity : 25 A
Resistance limit voltage : 200 V
ELECTRICAL SYSTEM
Ignition system : DIU
Charging system : Magneto flywheel
Battery type : Yuasa MF YTX5L-BS
Battery capacity : 12v 4Ah
BULB VOLTAGE AND WATTAGE PER QUANTITY
Headlight : 12v 35W dip H11 / 12v 35W main beam H11
Frontt side-light : 12v 2.3W
Rear side/brake light : 12v 2,3W/16W
Front turn indicators : 12v 10Wx2
Rear turn indicators : 12v 2.3Wx2
Thanks
Gaz.
hmmmnz
PostPosted: 16:33 - 24 May 2007    Post subject: Reply with quote
well you are only using roughly 75odd watts at any one time not including the drain from the coil,
but i would say it will probly be ok as you are only 20watts over standard, roughly the same amount as the indicators when they are running, you may find with the new lamp that when you turn on the indicators, that it will dim,
the only other thing is weather the cable is large enough to take it,
35w = 2.9 amps
55w = 4.5amps
so you will need a at least a 0.5mm2 cable to handle, which i think minium you will have a 0.75mm2 cable
so i think you should be ok
the humans are dead
The last post was made 19 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 41.82 Kb
