| GPZCarlos |
 GPZCarlos Two Stroke Sniffer
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 15:46 - 23 May 2007 Post subject: |
you'll have to pull off the head by removing the cam shaft ect, remove the valves replace or regrind the valve seats, clean up or replace the valves depending on condition.
its a bit of a mission, but if you have a wee work shop and dont mind getting your hand dirty then go for it, but defenitly buy a manual, that will make things a whole lot easier.
if you cant be fuct with all that, then either try and track down a new engine, or just ride it as it is, and just deal with the rough running. ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| Yoshi |
 Yoshi Traffic Copper
 Posted: 17:15 - 23 May 2007 Post subject: |
Assuming you're not a fuckwit, and are able to follow a manual, it shouldn't be too much of a hard job, just take your time, and ask if you're not sure about anything.
Easier if you drop the engine out, have a friend to help with this.
You'll need a bit of space, and somewhere where you can leave stuff without it being disturbed.
Tools required: Torque wrench, Valve spring compressor and Valve seat grinder
Also worth doing the clearances whilst your at it, so you'll need (well this depends on the type of adjustment, if it's shims you will) a Micrometer and Feeler gauges
You'll also need a new head gasket for the engine. ____________________ Present: GS650 Katana - Getting ready for summer touring!
Past: TS50, RS50, ZXR400, LT80, TS250 |
| stinkwheel |
 Posted: 17:18 - 23 May 2007 Post subject: |
Well, a top end gasket set for a GPZ500 costs the thick end of £70. I don't know about the 400 but I'd imagine a bit more, if you can get one at all.
Factor this into your calculations. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Walloper |
 Walloper Super Spammer
 Posted: 21:25 - 23 May 2007 Post subject: |
https://cgi.ebay.com/ebaymotors/SIOUX-Valve-Face-Grinding-Machine-w-Stand-Cylinder-Head_W0QQcmdZViewItemQQcategoryZ63700QQihZ014QQitemZ330122563899QQrdZ1QQsspagenameZWDVW
To repair valve sealing you have to re-cut the valves and seats.
There is no short cut. The garage will use a machine like the one above to grind the proper angle onto each valve then use a profiled stone to grind the opposite angle on each seat.
Each valve is then 'Lapped' into it's very own seat using the grinding paste and the 'Valve Grinder Tool' listed in the earlier post above. This gives the valve the 'Gas Tight Seal' the engine relies on for good compression.
You could take out the valves and lap by hand but this would last about 1000 miles then deteriorate to what you have now and could end up in disaster and burn out the valves/seats.
If you remove a head disassemble valve system and do not use the opportunity to 'Re-Cut' then you are just wasting your time.
Let the garage do it or find a pal with a grinding machine. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| teampots |
 teampots Spanner Monkey
 Posted: 22:11 - 23 May 2007 Post subject: |
Theres a breakers with a GPZ 400r in if thats any help to you might be able to get a top end off them heck they are selling a GPZ 400 so you could just buy that and use yours for spares if you can get to em to pick it up
linkage
https://mcabreakers.com/14.html
https://mcabreakers.com/16.html
phone them on
Tel: 01254 77 77 09
M: 077 22 00 99 68 |
| Odie |
 Odie World Chat Champion
| sickpup |
 sickpup Old Timer
| stinkwheel |
 Posted: 00:30 - 24 May 2007 Post subject: |
I'm not buying any at all. If something goes so badly wrong the top-end needs taking off, the whole engine is going in the bin and another one is being fitted in it's place.
For a kawa 500 twin, you can get a decent second hand engine for a couple of hundred quid. It can be changed out in a day and you're back on the road.
Life's too short to be fucking about in the guts of liquid cooled Japanese engines. Been there, done that, can't be arsed. Certainly not for a saving of maybe £50-100. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| GPZCarlos |
| sickpup |
 sickpup Old Timer
| GPZCarlos |
| Barry_M2 |
 Barry_M2 World Chat Champion
 Posted: 13:02 - 24 May 2007 Post subject: |
Never heard of using liquid in the cylinders to check for leaks!?
I have a leakdown tester, which you screw into the spark plug hole, it then puts in around 100psi of pressure and the losses are shown on a guage on the tester. You dont want any more than 7% leakage really, ldealy none, but you usually see around 2 or 3%.
I dont think the timing is adjustable on the GPZ (although I could be wrong) so it cant go 'out of adjustment'.
You could just get away with lapping in the valves, but that all depends on how badly they are leaking, if at all.
Sickpup advice is good, its a shame you live so far from me as I have all the tools to do this job for you.
 ____________________ ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
https://www.bikechatforums.com/profile.php?mode=viewprofile&u=4332 |
| bugsy46 |
 bugsy46 Village Idiot
| Barry_M2 |
| GPZCarlos |
| Barry_M2 |
| GPZCarlos |
The last post was made 19 years, 85 days ago. Instead of replying here, would creating a new thread be more useful? |
