Another late night inspiration...
Milo
PostPosted: 13:28 - 30 Sep 2003    Post subject: Another late night inspiration... Reply with quote
How about a twin tuner VCR that can record two programs to the same tape using alternate frames. it'd be the same quality as longplay mode....though obviously you couldn't watch while recording...and a bit less versatile as tivo...and more expensive than getting a second VCR...pah-never mind Rolling Eyes
Shaft drives rule. Razz
Major_Grooves
The Doctor
PostPosted: 13:31 - 30 Sep 2003    Post subject: Reply with quote
Eat less cheese before bed mate! Wink
TiN
Pocket Tin
PostPosted: 13:32 - 30 Sep 2003    Post subject: Reply with quote
CCTV-type VCRs use similar techniques when recording multiple cameras. Unfortunately, because it's only recording alternate frames, the resulting footage won't be totally smooth, and I dread to think what the sound will be like.
You can Mpeg2 encoding hardware that can record multiple channels of full quality footage, but they cost a few quid.
TiN
dotgems.net
Rob
PostPosted: 13:35 - 30 Sep 2003    Post subject: Reply with quote
But if it used alternate frames that means one programme would get allocated 12 frames per second and the other programme would get 13 frames per second, so even if it could work out that, the fact of pictures running at those fps would be pretty unwatchable!
Sky are just about to release an update for the Sky+ box that allows it to record using both its tuners at the same time, so you will be able to record two separate programmes at the same time, but obviously would only be able to watch stuff you had already recorded as it does only have two tuners in it!
I want summat that records the whole digital stream so it is constantly recording all channels, all the time!! Guess I will have to wait for storage capacity to go up first! Laughing Laughing
Long live TiVo! Laughing
Love is 1050cc Smile
PostPosted: 13:36 - 30 Sep 2003    Post subject: Reply with quote
The sound is embedded on VHS not on a seperate track AFAIK so it wouldn't work I don't think.
<<< works in the broadcast industry.
Also I don't think the FPS is a problem as TV is scanned onto the screen as lines, so it would record lines not frames. Thats why you get a blurring on pause unless the VCR is multi head.
Rob
You could get it to record on alternate fields, then you will still get smooth motion but at half resolution!
Laughing Laughing
Rob
PostPosted: 13:38 - 30 Sep 2003    Post subject: Reply with quote
VHS does have seperate audio tracks, its not embedded with the video!
Milo
it'd be the same quality as longplay mode-which aint too shabby so it'd be bearable. there's just no point in developing it!
Don't think it's the cheese, it're more like the gayness of laying in bed knowing that my bike's sitting outside after i've only just gotten off it and there's no point in letting it get cold again...
Rob
Nah, it would be much worse than longplay mode as longplay still runs at 25 fps!
Milo
PostPosted: 13:40 - 30 Sep 2003    Post subject: Reply with quote
i thought it doubled the length of the tape by halfing the speed?
PostPosted: 13:41 - 30 Sep 2003    Post subject: Reply with quote
Oh ok. I'm used to hundreds of formats of DIGI tapes which have embedded audio.
Frame rate still won't be a problem though cos VHS records at 50fps (again a guess) if you can think of it in frames instead of lines. You'll still get 25fps (which is nominally what PAL TV and LP VHS gets anyway) so it might work in that case.
I don't think you can think of it in that way though cos I think VHS fudges some of the lines together to lower the resolution. Damn I wished I'd listened in my VHS training! Very Happy
Demonic69
The Pink Rhino
PostPosted: 13:42 - 30 Sep 2003    Post subject: Reply with quote
Milo, they already make twin tuner VCR's Razz most combination TV/Videos use twin tuners and I've seen a few twin tuner decks out there, mainly used for copying vids but can record 2 chanels at the same time.
Back on a Blade. Just feels so right.
TiN
Pocket Tin
PostPosted: 13:43 - 30 Sep 2003    Post subject: Reply with quote
Yeah, but I think that he only wants to use one tape. The cheapskate. Razz
TiN
dotgems.net
Rob
Yeah it does, but it still records at 25 fps, it just has less space to store the information therefore you get worse quality!
Demonic69
The Pink Rhino
PostPosted: 13:44 - 30 Sep 2003    Post subject: Reply with quote
Ah! Wouldn't know about that then! Tight arse Wink
Rob
PostPosted: 13:45 - 30 Sep 2003    Post subject: Reply with quote
Frame rate still won't be a problem though cos VHS records at 50fps (again a guess) if you can think of it in frames instead of lines. You'll still get 25fps (which is nominally what PAL TV gets anyway) so it might work in that case.
All digi formats can record embedded audio, but the also have seperate audio tracks also..
VHS in this country records at 25fps. In the states it records at 30 fps (shitty NTSC!!)
PostPosted: 13:49 - 30 Sep 2003    Post subject: Reply with quote
Thats what I mean about not being able to think of it in terms of frame rate... cos VHS fudges it by recording so many lines etc... if it was in terms of frame rate then it would be reasonable to assume that long play wouldn't work unless the original frame rate was at least 50fps. Mind you for this purpose there's no reason why you coldn't record at 50fps halving the length of tape. You might as well stick a hard disk in there though... that would be easier.
I think we mostly use embedded audio cos we got some expensive equipment to strip out levels of audio and stuff before it goes to a router.
Like I said we don't really use VHS at work so I'm not that au fait with it. I'm into video servers mainly.
Good taste in bikes btw Rob!!!! Very Happy
Oh and NTSC is something like 29.89999 frames per second or something ridiculous like that... it also records 500 odd lines instead of 600 odd.
Rob
PostPosted: 13:59 - 30 Sep 2003    Post subject: Reply with quote
But its the same on VHS as for all recording formats, they all work at 25fps in this country and images aren't stored on tape in 'lines' they are stored as fields, ok so not like in the conventional way when you look at a film strip, but still everything is stored as a field which a TV then interprets and draws field 1 first then field 2 after. It does that for all 25 frames in a second, hence it works as 50 fields per second. In the future will we do away with the 'field' part of it and TV's will draw whole 'frames' at a time which will result in much better pictures, this is known as progressive and at the moment, only region 1 (ntsc) dvd's offer footage stored in this way (for home use), but again the source footage has to be captured in frames not fields to make it worthwhile (eg film!)!
The advantage of embedded audio is that it all goes down one cable with the video, but obviously if you get a video dropout the audio will go too, so you are much safer taking a seperate digital audio feed from the decks too!
Rob
PostPosted: 14:01 - 30 Sep 2003    Post subject: Reply with quote
3 cylinders is the only way to go in engines!!
NTSC is 525 lines running at 29.97 fps - but dont go there, that opens up a whole can of worms!!
We work at 625 lines here!
PostPosted: 14:03 - 30 Sep 2003    Post subject: Reply with quote
Yeah I know about progressive scan... I assume that you can do away with reference black if you've not got a scanning image...
I though the whole basis of TV transmission was that it was scanned in lines across the screen. DVD's and stuff yeah but even Digital TV is decoded into old fashioned scanlines.
Rob
PostPosted: 14:08 - 30 Sep 2003    Post subject: Reply with quote
Even in progressive, it still scanned in lines but it draws all of them in succession rather than drawing the even number lines first then the odd number lines after, the only reason it happened this way was because originally the technology didnt exist to be able to draw all the lines in one hit fast enough, so they split the picture into two. TV technology is good enough now to allow all 625 lines to be drawn in one hit!
The scan lines are only an artefact of CRT's - if you go down the plasma or lcd route you dont have that problem!!
Kris
PostPosted: 14:11 - 30 Sep 2003    Post subject: Reply with quote
zzzzzzzzz zzzzzzzzzz zzzzzzzzz zzzzzzzzz
www.prisonplanet.com
Rob
PostPosted: 14:14 - 30 Sep 2003    Post subject: Reply with quote
Sorry, discussion ended!!! lol Laughing Laughing Laughing
Wake up Kris!!! Laughing Laughing
Zimma
Wheelie Junkie
PostPosted: 15:58 - 30 Sep 2003    Post subject: Reply with quote
Was about to say NTSC is 29.97... is 625 lines at 30 then?
-Zimma
PostPosted: 16:01 - 30 Sep 2003    Post subject: Reply with quote
we're 625 lines at 25...
The last post was made 22 years, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 132.26 Kb
