MOT.. Does my bike need to be able to start?
element
PostPosted: 17:29 - 31 May 2007    Post subject: MOT.. Does my bike need to be able to start? Reply with quote
It does start but I got to bump it. Starter has gone and I dont have a kickstart (WTF where yamaha thinking then they took the kickstart off the newer DT's?!).
Just wondering because my first MOT is next month and I dont wanna spend out getting the starter sorted when Ive lived with bumping it for a while now. Anyhow I need a new front tyre anyway Sad
cheers Thumbs Up
also can bumpstarting damage the crank? ive heard of bending crankarms etc..
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
carvell
Scuttler
PostPosted: 17:32 - 31 May 2007    Post subject: Reply with quote
Is it the battery that's dead? Not sure what on Earth a yamaha DT is doing with an electric starter anyway!
As far as I can remember, as long as all of your lights etc work without it being started, then it doesn't have to be started, no.
Yamaha TDM 850
PostPosted: 17:38 - 31 May 2007    Post subject: Reply with quote
I've certainly MOTed bikes that won't start before. As said, providing the lights all work with the engine off it shouldn't be a problem.
element
PostPosted: 17:54 - 31 May 2007    Post subject: Reply with quote
Nah deffo the starter because occasionally it will start and Ive tried another battery which I know is good and it doesnt sort the problem.
There happens to be a slight problem then.. My front lights are those UFO/Acerbis twin spots. I have the dipped beam wired to original parking/pilot light wire and the spot beam is wired to the switched full beam (which only works when the engine is running). So even with the original front light the engine would need to be running to check full beam?.. I do have the original front light but the glass is cracked and I guessed that was a MOT failure?
I can however, kill the engine and the full beam can still be switched on and off aslong as I do no turn off the ignition.
PostPosted: 18:13 - 31 May 2007    Post subject: Reply with quote
Or you could bump start it and get them to check the lights.
Ask about it at the MOT station before you book it in.
carvell
Scuttler
PostPosted: 18:30 - 31 May 2007    Post subject: Reply with quote
Yes and probably.
Yamaha TDM 850
PostPosted: 19:13 - 31 May 2007    Post subject: Reply with quote
Think now the bike must be capable of running to check the exhaust (think this changed a couple of years ago). But yes the engine will also need to be started to check the lights.
When the bike refuses to start, are there any noises or just silence?
Jack_Cheese
PostPosted: 19:32 - 31 May 2007    Post subject: Reply with quote
as long as it starts it should be ok. However, there may be an issue with the electric start. A lot of things are "if fitted, must work" so i think if you whipped the start switch off you would get away with it, but im not 100% sure. I will do some digging...
EDIT: according to this link the starting ststem will not be tested, but the bike will have to be running for the exhaust to be tested for noise, however this is at the tester's discretion, ie. it's up to him whether or not it gets tested. So you may have to start it, you may not, but it shouldnt fail on the starter system.
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
PostPosted: 19:41 - 31 May 2007    Post subject: Reply with quote
Unfortunatly that MOT manual is 6 years old and it has changed quite a bit since then. There used to be a newer one online but it disappeared (suspect VOSA got a bit tetchy over copyright, but let the out of date one be copied).
element
PostPosted: 20:08 - 31 May 2007    Post subject: Reply with quote
sometimes tries to start and fails, other times you just hear the solenoid clicking. Rare occasions will it start off the button. Think Ive tried pretty much everything... original thread here.
Cheers for the replies so far Thumbs Up
PostPosted: 20:27 - 31 May 2007    Post subject: Reply with quote
Reading that it sounds like when you roll the bike backin gear you might be disengaging the starter. And normally it is staying engaged. This will damage the starter, but probably also means it doesn't have any momentum behind it when it tries to crank the engine (would probably have turned a few times before it engaged otherwise).
Jack_Cheese
PostPosted: 19:51 - 01 Jun 2007    Post subject: Reply with quote
bendix drive?
element
PostPosted: 13:05 - 02 Jun 2007    Post subject: Reply with quote
Jack_Cheese wrote:
bendix drive?
sticking...? Expensive little things to replace too I belive. I just gotta wait till I got some money together and then I'll get the dodgy bolt, holding the starter, removed. I think its gonna need heating up cos an impact driver was starting to mess the posi drive. God knows why they insist on using posi drive bolts for the left hand engine casing (which needs to be removed to reveal the 2nd bolt holding the starter motor Rolling Eyes ). The right hand engine casing uses normal bolts.
In the near future im hoping to stick an older DTR engine in so I'll have an RE with a kickstart and revcounter Very Happy ......and it'll be faster..
Jack_Cheese
PostPosted: 13:20 - 02 Jun 2007    Post subject: Reply with quote
get a bag of stainless socket heads and switch them over Thumbs Up
Colin G
PostPosted: 15:16 - 02 Jun 2007    Post subject: Reply with quote
could be a dodgy earth connection.
Speed doesn't kill. The sudden stopping does.
Current Bike: Honda CBR1100XX Super Blackbird
Previous Bikes: 1989 Honda Vision(Sold), 1983 Honda H100 (Sold), 2000 Kymco Stryker 125 (Sold), 1991 Suzuki GS500E (Blown Up), 1994 Suzuki GS500E (Blown Up), 1993 Kawasaki ZZR600 E1 (written off), 1999 Suzuki GSXR750 SRAD (Sold), 2003 Aprilia RSV1000 Mille (Sold)
The last post was made 18 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 90.06 Kb
