im liking results of altering throttle adjuster
colin1
Captain Safety
PostPosted: 00:07 - 03 Jun 2007    Post subject: im liking results of altering throttle adjuster Reply with quote
for a while, i have known that some people take out the slack of the throttle cable.
i know that bikes usually have a bit of slack so when doing a u turn they arent gonna accidentally put too much throttle on
i have adjusted mine to no slack and i love it
in fact i've gone a bit further so its actually increased the idle speed a bit as the throttle doesnt fully close
it feels great
much smoother at low revs
and much easier to whack on full throttle if i want to
makes the bike feel more powerful as less wrist action gets more results
it even has a slight cruise control effect
id recommend ppl try it
there isnt much engine braking now, and i just use clutch and brake if want to slow down
anyone got any thoughts on this ?
words of caution ? etc
At the moment Im thinking i should have done it years ago.
McGee
O RLY?
PostPosted: 00:09 - 03 Jun 2007    Post subject: Reply with quote
So it alters the speed as needed fine now.
Thats good Thumbs Up
Its pronounced Jixxer!
colin1
Captain Safety
PostPosted: 00:20 - 03 Jun 2007    Post subject: Reply with quote
and with only the slightest twist of the throttle too
McGee
O RLY?
PostPosted: 00:23 - 03 Jun 2007    Post subject: Reply with quote
Awesome Laughing Wink
I'm happy with the gix's throttle to be honest.
There doesn't feel like there is any slack.
Which of your bikes did you do it to ?
pwntifex
PostPosted: 00:35 - 03 Jun 2007    Post subject: Reply with quote
Well done Colin
Have this picture of an enormous afro for your troubles
https://ourworld.cs.com/sugdad/0714afro.jpg
Rhys
PostPosted: 00:40 - 03 Jun 2007    Post subject: Reply with quote
kind of like the '98 R1 now then? Wink
Current Bike: '94 RVF 400R
Bike Pics Youtube Myspace
colin1
Captain Safety
PostPosted: 00:43 - 03 Jun 2007    Post subject: Reply with quote
i did it with the triumph tt600
i think its particularly good as the fuel injection is a bit iffy on tt600s at low revs, so my little adjustment makes things much smoother at low revs, aswell as making it easier to get to high revs
veeeffarr
PostPosted: 00:48 - 03 Jun 2007    Post subject: Reply with quote
Only problem with a higher idle is that you lose braking efficiency. I wouldn't do it personally. T
colin1
Captain Safety
PostPosted: 00:49 - 03 Jun 2007    Post subject: Reply with quote
just a little bit
the R1 was a bit much for me tho, i was never gonna thrash it, and so it wd just make my riding lazy
im just growing into the tt600 now, a year later. Ive only just started hitting the rev limiter, and Im only just getting into highish revs clutch release starts.
Maybe by next year I'll be doing race starts, keeping the bike between 11000 rpm and 13000 rpm, and hanging off with max lean and getting my knee down.
Or maybe not.
anyone got any other little tweaks to the bike i could try ?
colin1
Captain Safety
PostPosted: 00:50 - 03 Jun 2007    Post subject: Reply with quote
im not gonna lose braking efficiency if i pull the clutch in every time i brake
MarkJ
PostPosted: 01:46 - 03 Jun 2007    Post subject: Reply with quote
But then you won't be using engine braking Confused
colin1
Captain Safety
PostPosted: 01:55 - 03 Jun 2007    Post subject: Reply with quote
if i want to brake with the back wheel, i can use the back brake, which is gonna brake much more than engine braking
cagiva gezzer
PostPosted: 02:00 - 03 Jun 2007    Post subject: Reply with quote
Threads with colin1 & Toby R always make me chuckle. Laughing
colin1
Captain Safety
and in this one u get us both Smile
cagiva gezzer
PostPosted: 02:04 - 03 Jun 2007    Post subject: Reply with quote
Double chuckles. You never fail to point out the blindingly obvious. Confused
PostPosted: 03:17 - 03 Jun 2007    Post subject: Reply with quote
I have done this to my 675 to try and shorten the throttle action.
As you're not limited by class regulations, I'd definitely recommend a quick action throttle (which I'm not allowed, so I've added some cable ties superglued to the throttle tube to speed it up a bit) - you do have to be a bit more careful, however it can remarkably change the way a bike feels and how punchy it is.
Just adding some light grease under the throttle tube and ensuring the cable is well oiled can make it feel quite a bit more lively.
Cillit-BANG
PostPosted: 08:46 - 03 Jun 2007    Post subject: Reply with quote
What Shocked
veeeffarr
PostPosted: 09:10 - 03 Jun 2007    Post subject: Reply with quote
you will lose your limbs if you do that often, colin.
Huambo81a
PostPosted: 09:21 - 03 Jun 2007    Post subject: Reply with quote
Personally i couldnt be without engine braking, and it does sound a little dangerous. A similar feeling to entering a bend on a false neutral, and having no drive to take you round.
Present: 2017 KTM Super Adventure S
Past: 97 Bandit 600 / 05 Bandit 1200 / 03 ZX6-R / 2006 Tuono R / 2001 VFR 800 / 2010 Street Triple R / 2013 Speed Triple S / 2017 S1000XR
Ariel Badger
PostPosted: 10:11 - 03 Jun 2007    Post subject: Re: im liking results of altering throttle adjuster Reply with quote
Engine breaking is there to be used Shocked
veeeffarr
PostPosted: 10:56 - 03 Jun 2007    Post subject: Reply with quote
What do you think's likely to happen when you take drive away from the rear wheel and then brake it?
Dave McCool
PostPosted: 11:27 - 03 Jun 2007    Post subject: Reply with quote
Surely what he's done isn't that dis-similar to riding with the choke applied?
McGee - "When I go to the mall and see all the high school girls, I have to have DO NOT TOUCH THE GIRLS written on my hand. Every time I go to grope I see it and stop."
K7 GSXR750
Ariel Badger
PostPosted: 11:38 - 03 Jun 2007    Post subject: Reply with quote
Do it in the wet and the effect becomes even more exciting Mr. Green
matthab
PostPosted: 12:13 - 03 Jun 2007    Post subject: Reply with quote
hmmm sounds abit dangerous to me, wouldnt do it to any of my bikes. Enging braking has helped me a few times!
2005 - 2006:Peugeot jet force 50 TDSI (sold)
2006 - Present: Yamaha YBR125 06 (extras:pilot sporty tyres and screen)
PostPosted: 12:17 - 03 Jun 2007    Post subject: Re: im liking results of altering throttle adjuster Reply with quote
Colin, what you have done is VERY dangerous. You should never take all of the slack out of the cable and never never never use the throttle cable adjuster to raise the revs. Use the idle adjustment screw to do that.
The last post was made 18 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 127.74 Kb
