| P_J |
 P_J Nearly there...
 Posted: 20:56 - 04 Oct 2003 Post subject: Clutch / Gears ... probably the clutch |
If i try and start my NSR in first gear with the clutch in, the bike jerks forward.
Perhaps your not supposed to start like this but id have thought if the clutch was in, the gears would be in neutral and it wouldn't make that much difference.
I've also found if i start in neutral and pop it into first, it will still jerk forward.
Is this a normal thing or is there something wrong. ____________________ Dreams will get you nowhere, a good kick up the arse will take you a long way.
Only1PJ.co.uk |
| Ian (GPX) |
 Ian (GPX) Brolly Dolly
| Dusty |
 Dusty King of the Rim
 Posted: 21:28 - 04 Oct 2003 Post subject: |
I don't have much experience on nsr's, but I'm sure it shouldn't jump forward when you start it with the clutch in, the engine should be disengaged. However, it may afaik jump forward when you put it into first, but only very slightly. My R6 does this, don't ask me why, but it does.
Might be worth having a play with the adjusters on your clutch and if that doesn't help, maybe have a look at the actual clutch. ____________________ Gallery |
| carvell |
 carvell Scuttler
| P_J |
 P_J Nearly there...
| carvell |
 carvell Scuttler
| bonceunounce |
 bonceunounce Banned
| P_J |
 P_J Nearly there...
| one1895 |
 one1895 I liked BCF so much I made my own copy
| Shaun |
 Shaun Likes 'em bent
| bonceunounce |
 bonceunounce Banned
 Posted: 06:29 - 05 Oct 2003 Post subject: |
| Highlander_PJ wrote: | | bonceunounce wrote: | The cable is loose.
Hold the clutch lever in, get down at the wheel and look for two nuts, tighten them up hand tight, let go of the lever and try tighening them a bit more hand tight, that should do it. |
erm, Im not trying to be funny but, where am i looking for the two nuts? |
You might have to take the fairing off yours, mine you dont need to (or just chop my cable ties :p)
On the right hand side, it goes onto the engine casing, you will see it if you pull the lever in and out, its like a bracket about a inch long, and the 2 nuts are at the top of the bracket.
This is hard to explain, follow your clutch cable from the clutch lever and you wil find what im on about.
Somoene might be able to explain it better.  ____________________ 1 baby motrax diamond indicator wanted |
| P_J |
 P_J Nearly there...
 Posted: 09:25 - 05 Oct 2003 Post subject: |
| bonceunounce wrote: | | Highlander_PJ wrote: | | bonceunounce wrote: | The cable is loose... |
Somoene might be able to explain it better.  |
Cheers mate, ill have a look, see whats what.
and ill adjust the chain too while in on my knees, i know it needs doing, didnt think it would affect that though. Cheers McJam. ____________________ Dreams will get you nowhere, a good kick up the arse will take you a long way.
Only1PJ.co.uk |
| cagiva gezzer |
| Racer X |
 Racer X Scooby Slapper
| Kickstart@Work |
 Kickstart@Work Scooby Slapper
The last post was made 23 years, 13 days ago. Instead of replying here, would creating a new thread be more useful? |
