How do you tell if the speedo has been adjusted ??
Taz69
PostPosted: 15:47 - 06 Jun 2007    Post subject: How do you tell if the speedo has been adjusted ?? Reply with quote
Hi all, having just got my lovely Firestorm,
Is there a way of telling if the bike is an Import, its not a problem if it is, just would like to know, can you tell on the Log Book for example, does it say New at First Registration by Honda etc or independent dealer ?
Thanks in advance
Mark
EDIT, update, got the logbook back today Friday, it says on the bottom, Declared New in GB by Independent Importer, so I guess that means its an import ? am I correct.
Now the question is how do I tell if the speedo has been corrected for miles etc, any ideas ?
Mark
Honda Firestorm VTR 1000 in Yellow, Lubbly Jubbly
Hetzer
PostPosted: 15:54 - 06 Jun 2007    Post subject: Reply with quote
Check the VIN plate (on the frame near the head-stock usually). If it's an import it should be in a foreign language.
Taz69
PostPosted: 16:02 - 06 Jun 2007    Post subject: Reply with quote
Hi mate, the Vin plate says
HONDA MOTOR CO LTD then the number etc, underneath the number is says HOMOLOGACION TIPO
A plate on the other side, left side as your sat on the bike has :
MESURE DE BRUT A LARRET
then some more foreign text basically saying about the decebels at 4500 rpm 90db etc.
I guess this means its an import so what the guy said is a lie but also 40k miles is now 40k kilometers, around 25k miles, so not too bad for the price I got it at.
Mark
teampots
PostPosted: 16:24 - 06 Jun 2007    Post subject: Reply with quote
not really as he could of fitted a converter onto it, there should be more stickers on your bike if they are all foreign then yes it could be an import just check your log book it will say if it was used in another country
Current - Fazer 600
Prev - Bandit x2 (Killed) CB400 (Superfour) CBR125
Currently Restoring - Kawasaki S1 250 Triple (Slowly but surely)
Hetzer
PostPosted: 16:31 - 06 Jun 2007    Post subject: Reply with quote
Mark
That's a Spanish or Portugese (most likely Portugese) import.
Taz69
PostPosted: 17:04 - 06 Jun 2007    Post subject: Reply with quote
I havent got the logbook back yet, but will check, how do you tell if there is a converter fitted, where would it be ?
Mark
ZRX61
Victor Meldrew
PostPosted: 17:40 - 06 Jun 2007    Post subject: Re: How do you tell if the Bike is an Import?? Reply with quote
Simple: It won't say "Triumph" on it.... Wink
Taz69
PostPosted: 22:18 - 06 Jun 2007    Post subject: Reply with quote
lol, hahaha, very good mate.
Mark
veeeffarr
PostPosted: 22:59 - 06 Jun 2007    Post subject: Reply with quote
Underneath the fuel tank where the frame meets the headstock is a sticker with an "E" on it and then a number?
EDIT: I don't mean UNDER the fuel tank, I mean the frame that runs underneath it on the right hand side of the bike.
Taz69
PostPosted: 23:24 - 06 Jun 2007    Post subject: Reply with quote
Toby, do you mean the right side as your sitting on the bike ?
Also if there is an E on it, its an Import ?
Will have a look in the morning.
Thanks
Mark
veeeffarr
PostPosted: 23:48 - 06 Jun 2007    Post subject: Reply with quote
Thanks
Mark
Theres an E and a number afterwards, I'm not sure if this is the same on all bikes but I remember someone saying that that's a way to check on Suzukis
I'm not sure which numbers denote which country, but if you're still stuck tomorrow I'll go and look at mine Smile or my mates Sp-1
T
Taz69
PostPosted: 23:54 - 06 Jun 2007    Post subject: Reply with quote
Cheers Toby,
Will have a look in the morning and reply.
Thanks
Mark
Swipe
PostPosted: 05:15 - 07 Jun 2007    Post subject: Reply with quote
Mine says the date imported on the log book.
FS1E (73) -> RD125LC (86) -> Honda Bros 650 (88)
Honda Hawk GT Forum - A forum dedicated to the Hawk GT/Bros/RC31
www.staffordshireriders.co.uk
iloveriding
PostPosted: 11:13 - 07 Jun 2007    Post subject: Reply with quote
you are all silly billys, The easiest way to tell if your bike is a import is, If it is a import it will be a Left hand drive
Tony
iloveriding
PostPosted: 11:14 - 07 Jun 2007    Post subject: Reply with quote
Ha Ha HA HA , MMM ok then
ken
PostPosted: 11:44 - 07 Jun 2007    Post subject: Reply with quote
It will not have an engine number on the v5c / log book, tip for you all when buying used cars and bikes Wink .
latest bike 03 R1 in zee red and black
NSR Mick
PostPosted: 11:58 - 07 Jun 2007    Post subject: Reply with quote
Near the bottom of the log book it will say previously registered overseas.
ken
PostPosted: 14:11 - 07 Jun 2007    Post subject: Reply with quote
it dosen't have to be registered in another country to be an import, they are uk spec imported to this country then registered.
if that's the question you are asking
Taz69
Taz69
PostPosted: 20:02 - 07 Jun 2007    Post subject: Reply with quote
Ken, yes mate, that is what I am asking, how to tell if its a Honda UK or a Parallel Import.
Not had chance to look today, will have a look in a mo about the sticker etc.
Regards
Mark
Taz69
PostPosted: 20:47 - 07 Jun 2007    Post subject: Reply with quote
Hi all, right, not sure how I missed this label last night, however above the VIN Plate there is a while label with some numbers on, the first one is in a circle and says E13.
Does this mean its a UK or a Parallel import, also is there any way of telling if there is a mile/kmh adjuster on the bike, the clock dial is UK.
Thanks
Mark
KTM Gordo
PostPosted: 20:56 - 07 Jun 2007    Post subject: Reply with quote
E13 means that it's a European approved vehicle - officially imported 'bikes will have that too.
But anyway, I assume by imported you mean a 'bike that's been brought in other than by the official importer (Honda UK)?
You could take it to a Honda dealer and ask them - they'll be able to check the VIN against Honda UK's records.
The manufacturer plates don't necessarily mean it's an unofficial import as it's not unknown for 'bikes to be re-routed from one country to another if there's an unexpected demand. To use a car example, Volkswagen have been known to bring in South Africa spec. cars because there weren't enough UK spec. ones available.
On your V5C it will normally have something like "Declared new at first registration" - or at least that's what it says on my KTM's V5C.
HTH Smile
Change is inevitable - except from a vending machine.
KTM 990 Adventure | KTM EXC 250 Racing | Land Rover Freelander SE Td4
Taz69
PostPosted: 21:03 - 07 Jun 2007    Post subject: Reply with quote
Hi mate, yes by Import I mean other than Honda UK, I am not that concerned by it, just would like to know, as if when I come to sell I don't want to look a liar by telling the prospected buyer its a UK bike when its not or saying its done 40k when it has not, etc.
Mark
treble
PostPosted: 21:29 - 07 Jun 2007    Post subject: Reply with quote
The text you quoted sounded like french to me.
Taz69
PostPosted: 08:02 - 08 Jun 2007    Post subject: Reply with quote
Also guys is there a way of telling if there is a mod on the speedo etc.
Mark
Taz69
PostPosted: 08:20 - 08 Jun 2007    Post subject: Reply with quote
update, got the logbook back today, it says on the bottom =
Mark
The last post was made 18 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 127.61 Kb
