Is the clutch necessary for shifting up gears? (FZ6)
LukeFlegg
PostPosted: 15:26 - 09 Jun 2007    Post subject: Is the clutch necessary for shifting up gears? (FZ6) Reply with quote
A debate I've got £2 riding on! -
Is it bad for vehicles (in this case my Yamaha FZ6) to shift up gears without using the clutch?
cheers
Marc_Buck
PostPosted: 15:29 - 09 Jun 2007    Post subject: Reply with quote
If done correctly i think its ok to go UP. Search it mate been mentioned many times.
matthab
PostPosted: 15:32 - 09 Jun 2007    Post subject: Reply with quote
once past 2nd its possible if done correctly, it can wear your gearbox out quicker as a clutch is a part which is meant to be replaced, wear out and is cheaper to replace than a gearbox
The way ive been told is to rev up to say 8,000 let off the accelerator then change up and put the power back on. The time you change can vary to bike to bike.
Do we get a cut of the £2 Very Happy Laughing ?
2005 - 2006:Peugeot jet force 50 TDSI (sold)
2006 - Present: Yamaha YBR125 06 (extras:pilot sporty tyres and screen)
Gazdaman
I did a trackday!!!
PostPosted: 15:40 - 09 Jun 2007    Post subject: Reply with quote
Clutchless shifting is fine, it causes barely any more gearbox wear than using the clutch if it is done well.
It is often much smoother, and it saves clutch wear too.
Shifting down it can also be done but takes a bit more precise timing.
Gaz
Modo
PostPosted: 16:04 - 09 Jun 2007    Post subject: Reply with quote
I apply a small amout of upward pressre on the gearshift, drop the revs a little and she changes gear like Sharon Stone changes legs,
All sexy like Laughing
www.bikepics.com/members/modobusadude
Matt06
PostPosted: 16:06 - 09 Jun 2007    Post subject: Reply with quote
You mean how you change gear anyway?
Current: MT-10, Bandit, Grom, GPZ500
Previous: YBR125, GSXR400, ZXR400, MT-03, NTV650, R6, z750, ZX6R, MT-09
cc123
Geez a joab?
PostPosted: 16:42 - 09 Jun 2007    Post subject: Reply with quote
Do it going up, but not going down the gears.
Really only clutch-less upshift if I'm mid bend or don't want to loosen my grip by going for the clutch.
Old bikes >>> https://www.bikepics.com/members/cc123/
thegubner
PostPosted: 17:31 - 09 Jun 2007    Post subject: Reply with quote
personal choice like, but i use the clutch, that is why its there.
Gazdaman
I did a trackday!!!
PostPosted: 17:36 - 09 Jun 2007    Post subject: Reply with quote
I'd say the jolt of a poor clutchless upshift mid bend is far more likely to make you lose grip than using the clutch.
Gaz
hmmmnz
PostPosted: 18:22 - 09 Jun 2007    Post subject: Reply with quote
its fine, if done right, but its a pointless thing to do,
i dont recommend doing it, as others have said it saves no real time and could wear the gear box faster
the humans are dead
I kick arse for the lord
cc123
Geez a joab?
PostPosted: 19:23 - 09 Jun 2007    Post subject: Reply with quote
Gaz
My shifting is perfect though! Wink
MementoMori
PostPosted: 20:02 - 09 Jun 2007    Post subject: Reply with quote
My NC30 feels like it's made for clutchless upshifts. Just smoothly slots in so I always do this at higher speeds when out of town. Never ever changed down without the clutch however.
The tiger who came for a pint
McGee
O RLY?
PostPosted: 21:35 - 09 Jun 2007    Post subject: Reply with quote
Its easy, just get it in the right spot like going up.
I love the sound you get from clutchless shifting the engine just keeps screaming.
Cool
Its pronounced Jixxer!
LukeFlegg
PostPosted: 22:55 - 09 Jun 2007    Post subject: Reply with quote
You're all beautiful, cheers. (Any more opinions- do keep them coming)
I'm still not sure whether I should come off the gas before shifting..
McGee
O RLY?
PostPosted: 22:57 - 09 Jun 2007    Post subject: Reply with quote
Ride how you feel comfortable if you find it easier to close the throttle shift then back on the gas do it like that.
Or while riding just try pushing it up a gear while still on the gas.
Just play with it Wink
Finglonga
PostPosted: 22:59 - 09 Jun 2007    Post subject: Reply with quote
Do it all the time, I only use the clutch to start off and change from 1st to 2nd. Been doing it years with no problems.
You wont damage the gearbox if you do it correctly and also when you get the hang of it its smoother than using the clutch.
Andy Sez....
F.Y.Y.F.F.
california_rookie
PostPosted: 03:53 - 10 Jun 2007    Post subject: Reply with quote
I almost always ignore the clutch when upshifting. Also, clutchless downshifting is just as simple. Instead of rolling off the throttle slightly, you just roll on it a tad. As little as you possibly can.
It comes in quite handy when holding a lidded beverage on the way back to work. As an added bonus it confuses the fu*k out of Harley riders. Thumbs Up
Note: If it feels like it's damaging the gearbox, it probably is. If it doesn't, it probably isn't.
https://www.bikepics.com/members/californiarookie/04gsxr600/
https://www.myspace.com/spapadillion
https://steamcommunity.com/id/spapadillion
lukamon
PostPosted: 14:49 - 10 Jun 2007    Post subject: Reply with quote
well, in the owners manual of my 1960 125 vespa, it says "extensive testing has concluded that no additional wear is caused to the gearbox by changing gears without the clutch" Cool
however, common sense tells me that changing the engine speed from say 9000 to 5000 rpm in a nothingth of a second cant do the crank / gears any good Confused
killa wrote: Im an ass man myself
Method
PostPosted: 15:05 - 10 Jun 2007    Post subject: Reply with quote
Clutchless shifting is fine.
It is a bit of an art but when mastered it is so much better and easier than the clutch.
I have been clutchless upshifting now for about 2 1/2 years, on both my GS5 and my SV650. Its a lot smoother, its a lot faster, and it does reduce clutch wear too...
Downshifting is a bit harder. This took me a little longer to master but once again i have been doing it for about 2 years. Not every downshift, but most downshifts i now do without the clutch. It takes good timing, and you do need to know your bike quite well to do it safely.
I find that blipping it down without the clutch helps me keep traction on the SV. If i drop it down on the clutch, then i need to slow down with the brakes at the same time otherwise when you release the clutch the rear can lock up slightly and cause you to squirm. With good timing and throttle control you can clutchless down as easy as you can upwards, and i find it helps most of the time.
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
Kara
PostPosted: 16:39 - 10 Jun 2007    Post subject: Reply with quote
You should get a licence before you shift anything buddy! hahahaha
NC30 + Bandit 6
www.eabikers.co.uk
Method
PostPosted: 07:45 - 11 Jun 2007    Post subject: Reply with quote
I havent read this entire thread, but if you mean before you shift without the clutch then yes you should.
If sequencial boxes are anything like non sequentials internally (Apart from the obvious), then one of the uses of the clutch is to slow the gearbox down so that the selector can line itself up with the cog it is required to be placed on. So by pulling the clutch you are releiving any power being put through one of your shafts, allowing the selector to slow it down and line itself up for a clean change. You will notice that if you try to change gear with the throttle open, you will get lots of crunches, this is the shaft not being able to line itself up correctly with the selector. So by dipping the throttle (It only has to be a minute amount realy, just enough to take the power away for a second or two), the power will be taken off that shaft and allow it to be slowed down just enough for the selector to slip onto the cog that is required, cleanly and efficiently.
(Obviously there are going to be holes in what i have just said, it was never designed to be an in depth guide to gearbox workings, but it gives people a general idea of what you are trying to acheive, without confusing them too much, before this thread turns into an arguement about my post)
The last post was made 19 years, 131 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 118.61 Kb
