| LukeFlegg |
 LukeFlegg Borekit Bruiser
| Marc_Buck |
 Marc_Buck Could Be A Chat Bot
| matthab |
 matthab Crazy Courier
 Posted: 15:32 - 09 Jun 2007 Post subject: |
once past 2nd its possible if done correctly, it can wear your gearbox out quicker as a clutch is a part which is meant to be replaced, wear out and is cheaper to replace than a gearbox
The way ive been told is to rev up to say 8,000 let off the accelerator then change up and put the power back on. The time you change can vary to bike to bike.
Do we get a cut of the £2 ? ____________________ 2005 - 2006:Peugeot jet force 50 TDSI (sold)
2006 - Present: Yamaha YBR125 06 (extras:pilot sporty tyres and screen) |
| Gazdaman |
 Gazdaman I did a trackday!!!
| Modo |
 Modo Spanner Monkey
 Posted: 16:04 - 09 Jun 2007 Post subject: |
I apply a small amout of upward pressre on the gearshift, drop the revs a little and she changes gear like Sharon Stone changes legs,
All sexy like  ____________________ www.bikepics.com/members/modobusadude |
| Matt06 |
 Matt06 World Chat Champion
 Posted: 16:06 - 09 Jun 2007 Post subject: |
| matthab wrote: |
You mean how you change gear anyway? ____________________ Current: MT-10, Bandit, Grom, GPZ500
Previous: YBR125, GSXR400, ZXR400, MT-03, NTV650, R6, z750, ZX6R, MT-09 |
| cc123 |
 cc123 Geez a joab?
 Posted: 16:42 - 09 Jun 2007 Post subject: |
Do it going up, but not going down the gears.
Really only clutch-less upshift if I'm mid bend or don't want to loosen my grip by going for the clutch. ____________________ Old bikes >>> https://www.bikepics.com/members/cc123/ |
| thegubner |
 thegubner World Chat Champion
| Gazdaman |
| hmmmnz |
 hmmmnz Super Spammer
| cc123 |
 cc123 Geez a joab?
| MementoMori |
 MementoMori World Chat Champion
| McGee |
 McGee O RLY?
| LukeFlegg |
| McGee |
 McGee O RLY?
| Finglonga |
 Finglonga World Chat Champion
| california_rookie |
 california_rookie World Chat Champion
| lukamon |
 lukamon World Chat Champion
 Posted: 14:49 - 10 Jun 2007 Post subject: |
well, in the owners manual of my 1960 125 vespa, it says "extensive testing has concluded that no additional wear is caused to the gearbox by changing gears without the clutch"
however, common sense tells me that changing the engine speed from say 9000 to 5000 rpm in a nothingth of a second cant do the crank / gears any good  ____________________ killa wrote: Im an ass man myself |
| Method |
 Method World Chat Champion
 Posted: 15:05 - 10 Jun 2007 Post subject: |
Clutchless shifting is fine.
It is a bit of an art but when mastered it is so much better and easier than the clutch.
I have been clutchless upshifting now for about 2 1/2 years, on both my GS5 and my SV650. Its a lot smoother, its a lot faster, and it does reduce clutch wear too...
Downshifting is a bit harder. This took me a little longer to master but once again i have been doing it for about 2 years. Not every downshift, but most downshifts i now do without the clutch. It takes good timing, and you do need to know your bike quite well to do it safely.
I find that blipping it down without the clutch helps me keep traction on the SV. If i drop it down on the clutch, then i need to slow down with the brakes at the same time otherwise when you release the clutch the rear can lock up slightly and cause you to squirm. With good timing and throttle control you can clutchless down as easy as you can upwards, and i find it helps most of the time.
 ____________________ CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado
My Bikepics.com - No Brakes, No Gears... No Fear. |
| Kara |
 Kara Crazy Courier
| Method |
 Posted: 07:45 - 11 Jun 2007 Post subject: |
| LukeFlegg wrote: | I'm still not sure whether I should come off the gas before shifting.. |
I havent read this entire thread, but if you mean before you shift without the clutch then yes you should.
If sequencial boxes are anything like non sequentials internally (Apart from the obvious), then one of the uses of the clutch is to slow the gearbox down so that the selector can line itself up with the cog it is required to be placed on. So by pulling the clutch you are releiving any power being put through one of your shafts, allowing the selector to slow it down and line itself up for a clean change. You will notice that if you try to change gear with the throttle open, you will get lots of crunches, this is the shaft not being able to line itself up correctly with the selector. So by dipping the throttle (It only has to be a minute amount realy, just enough to take the power away for a second or two), the power will be taken off that shaft and allow it to be slowed down just enough for the selector to slip onto the cog that is required, cleanly and efficiently.
(Obviously there are going to be holes in what i have just said, it was never designed to be an in depth guide to gearbox workings, but it gives people a general idea of what you are trying to acheive, without confusing them too much, before this thread turns into an arguement about my post) ____________________ CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
The last post was made 19 years, 134 days ago. Instead of replying here, would creating a new thread be more useful? |
