| shleppy |
 shleppy Nova Slayer
 Posted: 20:18 - 11 Jun 2007 Post subject: er5, reg.rec problem, can any of you chaps provide me with.. |
a solution:
heres the problem - the kawasaki er5 has a problem, the reg.rec blows, but thats not all, when it goes, and this seems to be a common problem on all years of er5, it bypass' fuses and blows nearly all the electrics, the only way to prevent this at the moment is to spot the signs of it going before it goes.
becuase its the reg.rec im not sure if i could just solder in a fuse or resistor in there, cause i still want it to perform its task, but there must be a solution to this, why dont other bikes have this problem?
aparently the reg.rec malfunctions in the first place becuase of its positioning, under the bike behind the wheel, so it gets covered in road dirt, and then overheats ect, so ive thought about moving it but id really prefer to have the comfort knowing i have some protection for my electrics.
ill post up my bikes haynes circuit diagram and hope one of the more gifted electrically minded people can give me some good ideas. |
| stinkwheel |
 Posted: 21:36 - 11 Jun 2007 Post subject: |
Never heard of this as a problem.
They DO have a problem with corrosion on the wire running from main fuse to the bikes live feed (usually white, as on the attached diagram). It's gone on all three 500 twins I've owned
This causes a bad connection and essentially stops the battery both charging and feeding the electrics. I could see how this intermittantly making and breaking contact could confuse the hell out of the reg/rec and eventually cook it.
The reg/rec feeds in after the main fuse for some reason.
I would imagine fitting an additional 30A fuse where I've marked it in yellow on the attached diagram would protect the loom in the case of the reg/rec spiking the output too high.
If you're having trouble with it eating reg/recs though, check that wire at both ends for signs of corrosion, especially inside the main fuse holder attached to the starter solenoid. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 00:34 - 12 Jun 2007 Post subject: |
as above.
if you still have a problem.
then move the little bastard, contrary to popular belief, motorcycle manufactures don't know it all. place it in a position not too far from the alternator with plenty of air flow around it and away from salt filled muddy road slag.
have fun  ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| Ade |
 Ade Nitrous Nuisance
 Posted: 01:05 - 12 Jun 2007 Post subject: |
or get a hugger
Does seem to be a fairly common problem on the Er-5s, thankfully mine is ok (than agin, with only 6k on the clock, you'd think so )
Ade |
| davidimurray |
 davidimurray Nitrous Nuisance
| kawakid |
 kawakid World Chat Champion
 Posted: 09:51 - 13 Jun 2007 Post subject: |
I've had a regulator go on my ER5 earlier this year.
I noticed after light bulbs blown after just swapping them.
You need a multimeter, to test , I think mine went up to 19v when
it went.
I had lots of problems when I ordered a replacement, because it came with totally different connector than what was on the ER5.
See this post https://www.bikechatforums.com/viewtopic.php?t=105520&highlight=
Basically you need to make sure they supply you with the correct connector, or its a major arse. ie they expected me to cut in to the loom and cut the terminal block of the new rectifier (yeahh right, what if it doesn't work and they didn't supply me with a wiring diagram).
Make sure you get the right connector.
The other issue I had was bolts broke as I tried to take it out and I had to take it to a garage to remove the bolts. (Cost me £20 they used some chemical to get them out).
Remember a fuse only protects you about amps not voltage. So its not going to do anything to help with a rectifier fault. ____________________ I've a twin and a 4. |
| shleppy |
 shleppy Nova Slayer
| bugsy46 |
 bugsy46 Village Idiot
| sickpup |
 sickpup Old Timer
| bugsy46 |
This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
| sickpup |
 sickpup Old Timer
 Posted: 20:14 - 17 Jun 2007 Post subject: |
| bugsy46 wrote: |
Ive never heard such shit in all my life.
I shall give you a lesson in regulator rectifiers my friend
I'm not your friend. I look forward to this.
| bugsy46 wrote: |
The reason for a reg/rec having fins is to disipate heat.
Said that.
| bugsy46 wrote: |
This is because they use semiconductors.
Well yes diodes are semi conductors.
| bugsy46 wrote: |
SINGLE PHASE HALF WAVE RECTIFICATION
Most bikes use a 3 phase Alternator, that's why they have 3 lives off of the alternator, gives a smoothish supply after the half wave rectification..
| bugsy46 wrote: |
Uses a diode to convert AC to DC. Outputs positive half cycles. Used on small bikes with low load
INTERNAL VOLTAGE REGULATION
Current from the coil is regulated through 1 diode, and then fed to the battery. The voltage is regulated by the reg circuit and an SCR. as the RPM increases, the alternator output does as well and is rectified by another diode, this current then goes to a zenor diode. The current flows in the normal direction but not reverse until a certain voltage is applied. When it has, the ZD conducts it in the reverse, thus turning the SCR on. When it turns on, the output from the alternator is shorted to ground through the SCR, this obviously explains why a battery over charges if there is a bad earth.
Now, sickpup, go back to your haynes manual and when you know something about charging systems come back and pour advice to people who need it. Your post had me in stitches because it confirms you know jack shit.
Night x |
Now you are right I didn't mention zenor diodes but I did a pretty simplified version. Also must say I've never known a reg/rec to throw positive to earth either but I'm happy to be wrong.
As to corrosion in the circuit it introduces resistance so the reg/rec pulls more power from the alternator(which has to work harder so produces more heat and as you no doubt know the enemy of all SCR's is heat especially excess heat as well as hot/cold/hot cycling.
Your explanation of what the Zenor Diode does is not very good either. A zenor like all diodes only allows flow in one direction however when the voltage on one side becomes higher than a pre-set value it can reverse flow as well. I will admit I didn't know it dumps it to earth, still don't from your explanation I do know it dissipates excess charge as heat.
You sleep well Bugsy, where do you want me to send the GCSE textbooks to?
<edit>As I write this I realise yes excess power is probably bled to earth creating heat, needs to go somewhere.<edit> |
The last post was made 19 years, 122 days ago. Instead of replying here, would creating a new thread be more useful? |
