2t Exhaust Clogged?
.Chris.
PostPosted: 15:25 - 15 Jun 2007    Post subject: 2t Exhaust Clogged? Reply with quote
Hi,
Does anyone know what sort of symptoms a blocked exhaust will give?
Recently my RXS100 has decided it doesn't like revving to more than about 5.5k in 1st or 2nd gear, but in higher gears it will happily rev all the way up to 9k. When it reaches about 5.5k in 1st and 2nd it sort of splutters until you change up. The amount of throttle doesn't seem to make much of a difference.
My mate who had a 50cc Reiju dirt bike when he was younger said that's the exact same symptoms he got when the exhaust was blocked up with carbon and gunge.
If it is blocked up then how might I go about unblocking it? Would redex in the tank do any good or do I need to burn the carbon off?
Cheers Very Happy
Chris
1985 Kawasaki Z550F
hmmmnz
PostPosted: 15:32 - 15 Jun 2007    Post subject: Reply with quote
take the exhaust off plug the hole and fill with caustic soda..(im sure its caustic soda) let it sit for an hour or 2 and then empty and that should have gotten out all the carbon.
on my old smokey i used to cut the expansion chamber and burn out all the carbon, the reweld it back together, (i never knew there was an easier way) Very Happy
im sure some one will pipe in if its not caustic soda that you are saposed to use
the humans are dead
I kick arse for the lord
BFG
PostPosted: 15:35 - 15 Jun 2007    Post subject: Reply with quote
Only use caustic soda on steel exhausts. It will melt ally exhausts. Smile
If you're not sure what it's made from, try a magnet.
.Chris.
PostPosted: 15:39 - 15 Jun 2007    Post subject: Reply with quote
OK, so if the exhaust is clogged then will both parts be bunged up (i.e. the curved pipe connecting the exhaust port of the engine to the silencer) or just the silencer itself? I've unscrewed and removed the baffle from the rear of the silencer and although obviously blackened it doesn't seem too bad, nothing came out when I bashed it on the ground!
No probs there, this one has a bit of rust showing through so i'm pretty sure it's steel!
Chris
1985 Kawasaki Z550F
hmmmnz
PostPosted: 15:47 - 15 Jun 2007    Post subject: Reply with quote
it doesnt matter about the silencer, its the expansion chamber and the pipes that connect to it.
that need to be cleaned out.
the humans are dead
.Chris.
PostPosted: 15:53 - 15 Jun 2007    Post subject: Reply with quote
Ah. Didn't know that, thought it was the silencer iself that got clogged up. I'll get some caustic soda then and give it a bath!
Cheers Very Happy
Chris
1985 Kawasaki Z550F
DaveW
PostPosted: 15:56 - 15 Jun 2007    Post subject: Reply with quote
On my Kwak AR50 I had a Micron which you could slide the baffles out of the can and used a blow torch and maybe petrol or white spirit - obviously not at the same time!! Although some good flame shooters cleared some of it!! Dishwaher liquid is always good for getting rid of carbon and oil.
When it gets coked up the engine will feel constipated and probably sound it (muffled) and will be slow to rev and feel slightly sluggish.
If it gets coked up alot, maybe try a good brand of 2 stroke oil and/or check the feed isn't too much. I used to clean the AR out every 6 months - I think, can't quite remember, it was 14 years ago. Very Happy
Yamaha R6 '05 model, upside down forks, radial brakes, Blue flame can, dubble bubble and clear turn signals - as they say in America
hmmmnz
PostPosted: 15:59 - 15 Jun 2007    Post subject: Reply with quote
yeah basically all the power is controlled by the expansion chamber,
take that off and your bike will barely run
the silencer is just there to keep the noisy smokeys quiet.
take that off and you wont even notice a difference to the way it runs Very Happy
get a cork from a wine bottle and jam it end where it connects to the bike and fill her up Very Happy
the humans are dead
DaveW
I found it was more the silencer (end can) that was coked the most due to smaller passages. The expansion bit in the middle only usually had a 'coating' of carbon.
.Chris.
PostPosted: 16:08 - 15 Jun 2007    Post subject: Reply with quote
You can take the baffle out of the RXS100 exhaust, and I've cleaned it with petrol but nothing seemed to come off and there was no difference to the performance.
I guess the whole lot is probably gunged up so I'll get some caustic soda at Tesco's this evening!
Thanks Very Happy
Chris
1985 Kawasaki Z550F
hmmmnz
PostPosted: 16:46 - 15 Jun 2007    Post subject: Reply with quote
get some rubber gloves while your there, the shit is nasty on the hands, especially if you have a wee cut,
and try not to breathe it in, oven cleaner has nothing on caustic sodas evilness Very Happy
the humans are dead
.Chris.
PostPosted: 17:53 - 15 Jun 2007    Post subject: Reply with quote
Will do. Very Happy
Chris
1985 Kawasaki Z550F
PostPosted: 19:19 - 15 Jun 2007    Post subject: Reply with quote
Personally I would say the first thing it is likely to be would be the spark plug on its last legs. Bit of a thrash in the first 2 gear cleans it enough to run OK in the higher gears.
.Chris.
PostPosted: 20:20 - 15 Jun 2007    Post subject: Reply with quote
I don't think it can be this as I fitted a new one (of the correct type according to the manual) only two weeks ago.
Come to think of it before I clean the exhaust out I'll check the mixture setting as the old plug was rather black. I'd have thought it would have to be running very rich for it to cause stuttering though, and it seems to run fine otherwise.
If it isn't the mixture then I'll give the exhaust a good clean as I've got the caustic soda now.
Thanks everyone Very Happy
Chris
1985 Kawasaki Z550F
hmmmnz
PostPosted: 11:10 - 16 Jun 2007    Post subject: Reply with quote
how did it go?? chris???
no burnt skin or eyes i hope Wink
the humans are dead
.Chris.
PostPosted: 13:29 - 16 Jun 2007    Post subject: Reply with quote
Haven't done it yet - been in bed most of this morning (got a bit pissed last night Razz).
I'm doing it this afternoon, will let you know how it goes! Very Happy
Chris
1985 Kawasaki Z550F
.Chris.
PostPosted: 18:03 - 16 Jun 2007    Post subject: Reply with quote
Right, cleaned the silencer and baffle with caustic soda, set the carb up as per the manual (it was running a little bit rich beforehand) but none of it seems to have done any good Sad .
I think the next port of call is running with some redex in the tank, after that I'll test all the components of the ignition system, if that doesn't cure it then it's top-end rebuild time.
I have a suspicion that the piston rings might be knackered because when cold it gives off quite a large amount of white smoke, and when warm it still seems to give off a bit. The haynes manual says that if the exhaust is white (and the oil pump properly adjusted, which it is) then it needs a rebore.
Chris
1985 Kawasaki Z550F
SilvaRizla
PostPosted: 10:01 - 17 Jun 2007    Post subject: Reply with quote
Itialian Tune-up Thumbs Up
Worked on my NSR and burnt the stodge off when I got it
(Rag the tits off it on a big ride, get the thing HOT)
I'm Ivan Dobski the Meatsafe Murderer only I never done it, I only said that I done it so they'd take the truncheon out of my bottom
hmmmnz
PostPosted: 11:11 - 17 Jun 2007    Post subject: Reply with quote
its weird that its only the bottom to gears, my guess that its your gear box.
drop the oil from oil from the gear box and replace it,
and do what silva says give it the thrashing it deserves
the humans are dead
.Chris.
PostPosted: 11:54 - 17 Jun 2007    Post subject: Reply with quote
It does seem to improve a bit when it's really hot (say after a 20 mile ride). If the weather holds then I'll give it a good 50 mile run over Dartmoor today with some redex in there and see if that improves things. I'll also be interested to see whether the fact I've now correctly adjusted the mixture makes any difference.
I doubt it's the gearbox as there is plenty of oil in it which looks nice and clear, the box changes fine and also the engine does sound like it's struggling a bit in higher gears, but it's just not anything like as noticeable.
Chris
1985 Kawasaki Z550F
.Chris.
PostPosted: 17:01 - 17 Jun 2007    Post subject: Reply with quote
Well it seems to have done the trick!
Today I filled her up, put a good dose of redex in the tank and took her for a 72-mile ride over Dartmoor. It's like a new bike!
There's now no stuttering in lower gears, the engine sounds much happier and it pulls better at the top-end too. Before the acceleration would level off at about 50-55, now 60mph is obtained with ease and I managed to get 70 out of it.
Not sure what was causing the problem then, but whatever it was has now been cured.
I'm a very happy person at the moment Very Happy
Chris
1985 Kawasaki Z550F
hmmmnz
PostPosted: 20:45 - 17 Jun 2007    Post subject: Reply with quote
nice. those Italian tune ups are great Very Happy
still, pull the carb off, remove the float bowl clean out all the crap, pull each jet and bow it through. then pull the top and make sure the diaphragm is still in good condition.
the humans are dead
.Chris.
PostPosted: 22:01 - 17 Jun 2007    Post subject: Reply with quote
Will do, I may as well do that in the next couple of days as the weather forecast is a bit crap Sad
Chris
1985 Kawasaki Z550F
The last post was made 19 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 133.33 Kb
