| .Chris. |
 .Chris. World Chat Champion
 Posted: 15:25 - 15 Jun 2007 Post subject: 2t Exhaust Clogged? |
Hi,
Does anyone know what sort of symptoms a blocked exhaust will give?
Recently my RXS100 has decided it doesn't like revving to more than about 5.5k in 1st or 2nd gear, but in higher gears it will happily rev all the way up to 9k. When it reaches about 5.5k in 1st and 2nd it sort of splutters until you change up. The amount of throttle doesn't seem to make much of a difference.
My mate who had a 50cc Reiju dirt bike when he was younger said that's the exact same symptoms he got when the exhaust was blocked up with carbon and gunge.
If it is blocked up then how might I go about unblocking it? Would redex in the tank do any good or do I need to burn the carbon off?
Cheers  ____________________ Chris
1985 Kawasaki Z550F |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 15:32 - 15 Jun 2007 Post subject: |
take the exhaust off plug the hole and fill with caustic soda..(im sure its caustic soda) let it sit for an hour or 2 and then empty and that should have gotten out all the carbon.
on my old smokey i used to cut the expansion chamber and burn out all the carbon, the reweld it back together, (i never knew there was an easier way)
im sure some one will pipe in if its not caustic soda that you are saposed to use ____________________ the humans are dead
I kick arse for the lord
| BFG |
 BFG Brolly Dolly
| .Chris. |
| hmmmnz |
| .Chris. |
| DaveW |
 DaveW Renault 5 Driver
 Posted: 15:56 - 15 Jun 2007 Post subject: |
On my Kwak AR50 I had a Micron which you could slide the baffles out of the can and used a blow torch and maybe petrol or white spirit - obviously not at the same time!! Although some good flame shooters cleared some of it!! Dishwaher liquid is always good for getting rid of carbon and oil.
When it gets coked up the engine will feel constipated and probably sound it (muffled) and will be slow to rev and feel slightly sluggish.
If it gets coked up alot, maybe try a good brand of 2 stroke oil and/or check the feed isn't too much. I used to clean the AR out every 6 months - I think, can't quite remember, it was 14 years ago.  ____________________ Yamaha R6 '05 model, upside down forks, radial brakes, Blue flame can, dubble bubble and clear turn signals - as they say in America |
| hmmmnz |
 Posted: 15:59 - 15 Jun 2007 Post subject: |
yeah basically all the power is controlled by the expansion chamber,
take that off and your bike will barely run
the silencer is just there to keep the noisy smokeys quiet.
take that off and you wont even notice a difference to the way it runs
get a cork from a wine bottle and jam it end where it connects to the bike and fill her up  ____________________ the humans are dead
| DaveW |
| .Chris. |
| hmmmnz |
| .Chris. |
 Posted: 17:53 - 15 Jun 2007 Post subject: |
Will do.  ____________________ Chris
| .Chris. |
| Blau Zedong |
 Blau Zedong Banned
| hmmmnz |
| .Chris. |
 Posted: 13:29 - 16 Jun 2007 Post subject: |
Haven't done it yet - been in bed most of this morning (got a bit pissed last night ).
I'm doing it this afternoon, will let you know how it goes!  ____________________ Chris
| .Chris. |
 Posted: 18:03 - 16 Jun 2007 Post subject: |
Right, cleaned the silencer and baffle with caustic soda, set the carb up as per the manual (it was running a little bit rich beforehand) but none of it seems to have done any good .
I think the next port of call is running with some redex in the tank, after that I'll test all the components of the ignition system, if that doesn't cure it then it's top-end rebuild time.
I have a suspicion that the piston rings might be knackered because when cold it gives off quite a large amount of white smoke, and when warm it still seems to give off a bit. The haynes manual says that if the exhaust is white (and the oil pump properly adjusted, which it is) then it needs a rebore. ____________________ Chris
| SilvaRizla |
 SilvaRizla Spanner Monkey
 Posted: 10:01 - 17 Jun 2007 Post subject: |
Itialian Tune-up
Worked on my NSR and burnt the stodge off when I got it
(Rag the tits off it on a big ride, get the thing HOT) ____________________ I'm Ivan Dobski the Meatsafe Murderer only I never done it, I only said that I done it so they'd take the truncheon out of my bottom |
| hmmmnz |
| .Chris. |
| Blau Zedong |
 Blau Zedong Banned
| .Chris. |
 Posted: 17:01 - 17 Jun 2007 Post subject: |
Well it seems to have done the trick!
Today I filled her up, put a good dose of redex in the tank and took her for a 72-mile ride over Dartmoor. It's like a new bike!
There's now no stuttering in lower gears, the engine sounds much happier and it pulls better at the top-end too. Before the acceleration would level off at about 50-55, now 60mph is obtained with ease and I managed to get 70 out of it.
Not sure what was causing the problem then, but whatever it was has now been cured.
I'm a very happy person at the moment  ____________________ Chris
| hmmmnz |
| .Chris. |
 Posted: 22:01 - 17 Jun 2007 Post subject: |
Will do, I may as well do that in the next couple of days as the weather forecast is a bit crap  ____________________ Chris
The last post was made 19 years, 19 days ago. Instead of replying here, would creating a new thread be more useful? |
