Throttle rubber grip sliding off
Nicky-Jano
PostPosted: 18:09 - 16 Jun 2007    Post subject: Throttle rubber grip sliding off Reply with quote
I'll be honest I know hardly anything about bikes other than how to make them go, and can only do it properly on my bike Rolling Eyes .
My problem is that my throttle slid off a bit, only about half an inch.
This has never happened before and it scared the heck out of me.
Is this normal?
I could actually take it off and put it back on Confused
Is my bike rideable now?
I haven't tried and I'm doing the ostrich thing of burying my head in the sand.
I know with the left hand grip you can change it but I have no clue about the throttle or what you have to do with it.
If anyone can help thanks.
This happened about half an hour ago by the way.
fazza59
PostPosted: 18:24 - 16 Jun 2007    Post subject: Reply with quote
Only ever had this problem on the old pushrod! It was due to water getting in under the grip. Best thing is to try to twist is of, if it wont twist then try to lift an edge with a small screwdriver and allow some air to get under it. When you have got it off then dry the bar and use some white spirit to clean the bar end and dry it. Make sure the inside of the grip is dry, use some spirit on the grip and allow to dry then twist the grip back on.
Current - Yamaha R1 - Yamaha XJ600N - Kawasaki GPZ 500S (project? Maybe )
Pics of my bikes
Nicky-Jano
PostPosted: 18:28 - 16 Jun 2007    Post subject: Reply with quote
So it's not broken then?
Also if you can take the grip on and off can you change them too? (throttle).
Have been thinking about getting pink grips Whistle .
I didn't know it was possible though, well for me to do anyway.
bugsy46
Village Idiot
PostPosted: 18:33 - 16 Jun 2007    Post subject: Reply with quote
your best bet is to lift up the rubber with a screwdriver and fire in some wd40 whilst working the screwdriver in a circle releasing its grip all over then slide it off. Clean up the bar so it is dry then apply hand grip cement or super glue before placing it back on
Laura - "And where did looks come into this and bugsy leave steven alone. You are not gods gift to women you may think you are but you're not."
Keith - "All the best"
ncrn
PostPosted: 18:38 - 16 Jun 2007    Post subject: Reply with quote
But how will she twist the throttle if its glued to the bar? :/
bugsy46
Village Idiot
PostPosted: 18:39 - 16 Jun 2007    Post subject: Reply with quote
are you taking the piss?!
Nicky-Jano
PostPosted: 18:44 - 16 Jun 2007    Post subject: Reply with quote
I don't have any cement or super glue here.
Have got to ride about 5 or so miles in an hour (I'm babysitting).
Is it safe for me to do this and I can glue the grip tomorrow?
Bomberman
PostPosted: 18:46 - 16 Jun 2007    Post subject: Reply with quote
I use hair spray. Lubricates till it dries, then acts as a light glue. Works fine for me Smile
Nicky-Jano
PostPosted: 18:48 - 16 Jun 2007    Post subject: Reply with quote
lol I don't have hair spray either!
I'm not the most girly of girls, bit of wax to make it bed head and I'm away to go Neutral
Are you from BW by any chance?
Oh would double sided scellotape work?
Jamie S
PostPosted: 18:51 - 16 Jun 2007    Post subject: Reply with quote
No it won't work , just drain a bit of petrol and take the grip off , dry the bar , put petrol on the inside of the grip , ram it on to the bar , leave to dry for 2 mins , and away you go.
Thinners is better if you have it but petrol will do for now.
Nicky-Jano
PostPosted: 18:54 - 16 Jun 2007    Post subject: Reply with quote
Thanks Smile
How do I drain the petrol out fo the bike though?
My tank opening is at the top and unless I tip the bike side ways Neutral .
Jamie S
PostPosted: 18:57 - 16 Jun 2007    Post subject: Reply with quote
Best bet is to turn the petrol tap off , take the rubber hose off , turn petrol tap on and then there will be a stream of petrol every were , stick the grip under it , turn petrol off when the grip is wet , slide the grip on to the bars , put fuel pipe back on , turn petrol tap to on.
Simple. Very Happy
Nicky-Jano
PostPosted: 19:01 - 16 Jun 2007    Post subject: Reply with quote
Thanks Jamie Thumbs Up .
Think I'll let the boyfriend do it.
If he mucks up I can at least shout at him Laughing
Jamie S
PostPosted: 19:04 - 16 Jun 2007    Post subject: Reply with quote
Just another note :
Make sure you have got enough petrol before trying this , the last thing you want to do is run out , if you do it correctly it will only use a camera film case full.
( Thats not much btw Very Happy)
Nicky-Jano
PostPosted: 19:05 - 16 Jun 2007    Post subject: Reply with quote
Lol I am ditz I know.
I actually topped up yesterday after running out of petrol Embarassed, so I should be fine Smile.
Jamie S
PostPosted: 23:46 - 16 Jun 2007    Post subject: Reply with quote
Did you manage to sort it out ?
Nicky-Jano
PostPosted: 09:30 - 17 Jun 2007    Post subject: Reply with quote
I had no problems getting there and back home, so thanks again.
truslack
PostPosted: 10:53 - 17 Jun 2007    Post subject: Reply with quote
Couldnt see it mentioned anywhere else in the thread, so yes - you could get pink grips
https://cgi.ebay.com/ebaymotors/NEW-OURY-PINK-MX-GRIPS-motorcycle-motocross-dirtbike_W0QQitemZ190123631440QQihZ009QQcategoryZ43967QQcmdZViewItem
They are for MX bikes though.
Nicky-Jano
PostPosted: 15:56 - 17 Jun 2007    Post subject: Reply with quote
I got the pink grips today Mr. Green .
Did a thread with pics of them in the general bike pics.
My boyfriend keeps calling me barbie now though Neutral .
Good thing is if my bike ever gets pinched it's easily recognisable!
If anyone wants to pinch it with those grips anyway Laughing .
Walloper
PostPosted: 20:03 - 17 Jun 2007    Post subject: Reply with quote
Soon as I read PINK GRIPS further up this thread I about turned and marched off in the opposite direction. Laughing
There are some dodgey blokes on here who KNOW about pink grips?
Grip Glue works best, but if you are ever stuck (Pardon the Pun) A wee slabberin' of nail polish will do. Colour co-ordinated of course..... Wink
Nicky-Jano
PostPosted: 21:05 - 17 Jun 2007    Post subject: Reply with quote
lol nothing wrong with a bit of pink Wink .
Was fed up of looking like a bloke Rolling Eyes Razz .
The last post was made 19 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 110.45 Kb
