nc24 vfr loss of charge
noosarabbit
PostPosted: 19:30 - 16 Jun 2007    Post subject: nc24 vfr loss of charge Reply with quote
New to biking so would appreciate help with a problem I have. Put new battery on my bike after buying it and although it has stood for 3 weeks without running, would have expected it to start- but no. Jump started and ran for 5 miles, pulled into get petrol and....nothing. Do not have problems once engine is going but this is really getting to me. HELP! Confused
bugsy46
Village Idiot
PostPosted: 19:32 - 16 Jun 2007    Post subject: Reply with quote
did you give the battery an initial charge?
Laura - "And where did looks come into this and bugsy leave steven alone. You are not gods gift to women you may think you are but you're not."
Keith - "All the best"
noosarabbit
PostPosted: 19:36 - 16 Jun 2007    Post subject: Reply with quote
Yeah, charged by Honda when I picked it up couple of months ago. Worked fine (starting a couple of times a week) until this weekend. Suspect regulator/rectifier but should I be looking for anything else?
PostPosted: 19:40 - 16 Jun 2007    Post subject: Reply with quote
Reg Rec?
bugsy46
Village Idiot
PostPosted: 19:43 - 16 Jun 2007    Post subject: Reply with quote
mmmm no, the reg/rec wouldnt of given out enough charge just starting it up. Charge the batt to 12.4 V or higher, then carry out a load test either at the charger or whilst on the bike, as i suspect the battery could be at fault.
noosarabbit
PostPosted: 19:51 - 16 Jun 2007    Post subject: Reply with quote
Okay, ta. Is it normal for bike batteries to run down so quickly?
bugsy46
Village Idiot
PostPosted: 19:53 - 16 Jun 2007    Post subject: Reply with quote
what brand is it?
sickpup
Old Timer
PostPosted: 13:36 - 17 Jun 2007    Post subject: Reply with quote
Batteries come dry charged, fill with acid leave to settle for an hour and you're away. The latest maintenance free sealed batteries I've been knocking out have a shelf life of around 9 months before they start to discharge before use.
It takes about 20-30 mins of riding to recharge a battery to the level it was at before starting, NC24's are notorious for poor starting and fouling their plugs if not used. You may have just discharged the battery if you were only starting the bike and not actually riding it.
If you have been riding the bike my first suspect would be the reg/rec if it hasn't been changed for a finned one. Try a jump start and check the voltage at the battery at around 4000rpm, if that doesn't work I would be checking the plugs.
The last post was made 19 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 55.04 Kb
