Honda CG only runs on half choke
netphil79
PostPosted: 13:54 - 18 Jun 2007    Post subject: Honda CG only runs on half choke Reply with quote
Hi,
I have a honda cg125 and just recently it refuses to tick over with the choke off. It seems to run fine on half choke but as soon as you push the choke in it just dies.
I have a spare carbarettor which I put in and it does exactly the same thing. I'm stumped as to what it could be.
Any help would be appreciated
Johnster
PostPosted: 12:27 - 20 Jun 2007    Post subject: Reply with quote
Hi,
Did you manage to get this sorted?
I have the same problem although i have just completed a top end re-build.
When i get a chance im gonna try ajusting the carb. If this still dosent work i will be taking the carb off and giving it a good clean.
Only other thing i could think of is could your fuel / air filter be blocked??
Cheers,
John
netphil79
PostPosted: 13:33 - 20 Jun 2007    Post subject: Reply with quote
Hi,
I've cleaned the carb out and tried a spare one I had and its all the same. Still runs ok on half choke but won't run without it. I've checked the airbox and am kinda out of ideas now. Where is the filter located?
veeeffarr
PostPosted: 13:43 - 20 Jun 2007    Post subject: Reply with quote
netphil79 wrote:
Hi,
Undo right hand side panel, Remove plastic cover (5/6 screws IIRC)
Air filter is clamped in there, foam covered cylinder.
Spoon261
PostPosted: 14:05 - 20 Jun 2007    Post subject: Reply with quote
The info below might be obviouse and not relivent, but some people have got the following info wrong in the past without the user manual.
Choke leaver fully up = full choke
Choke leaver half way = half choke
Choke leaver fully down = no choke
Bike will not idle with full choke, since choke is butterfly type (does not increase the idle speed).
Have you checked the idle mixture screw on the carb?
netphil79
PostPosted: 14:07 - 20 Jun 2007    Post subject: Reply with quote
Really? So black leaver fully down is choke off and fully up is full choke?
I always thought it was the other way round?
Phil
Spoon261
PostPosted: 14:34 - 20 Jun 2007    Post subject: Reply with quote
Phil
Yes really.
I would check with other owners, since I have the new model 2004 onwards (front disc brake). But we both have the same butterfly choke and carb.
If this is the problem, do not forget to adjust the idle mixture screw under the carb to the fastest idle, incase its been set with the choke leaver in the wrong place.
The choke / warming up is totally different on the pre 2004 models, I have read about not needing any choke at all in summer etc.. But best to hear it / read it from someone who has that bike.
All I no is if I leave the choke on for to long, I can smell it.
veeeffarr
PostPosted: 14:39 - 20 Jun 2007    Post subject: Reply with quote
Yes, choke up is on, choke down is off.
netphil79
PostPosted: 14:45 - 20 Jun 2007    Post subject: Reply with quote
LOL well that was an easy fix! I'll give that a go tonight!
Johnster
PostPosted: 09:46 - 21 Jun 2007    Post subject: Choke Reply with quote
Choke up is definatley off on mine!!
Maybe it depends on the model??
I have a 91 Brazil?
Johnster
PostPosted: 09:48 - 21 Jun 2007    Post subject: Choke Reply with quote
I have a 91 Brazil?
The last post was made 18 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 66.08 Kb
