Derbi gp50r
ugly1
PostPosted: 22:25 - 18 Jun 2007    Post subject: Derbi gp50r Reply with quote
i got a derbi gp50r and got a little problem with it
starts 1st time everytime without choke not matter the weather
in netural it revs spot on and ticks over nice and perfect, but when i shove it in to 1st and open the throtle it stutters until it reach's 6-7000 rpm then it fly's
this happens in every gear except 5th were i can do a steady 30mph no problems but as soon as i wanna open it up and drop it down a few gears it stutters untill reached 6-7000rpm
anyone come across this problem before ?
cheers
tristan
PostPosted: 00:01 - 19 Jun 2007    Post subject: Re: Derbi gp50r Reply with quote
cheers
Hi, I have virtually the same bike as you.
I know what you mean - like the throttle/revs dont want to go until that point, I had the same problem every now and then but mine is usually spluttery around 6-7k rpm lol.
Only thing can offer mate, is check ur jets, they might be the wrong sizes. Thumbs Up
MaybeGuy
PostPosted: 00:03 - 19 Jun 2007    Post subject: Reply with quote
low end lack of power.
bad powerband?
either air or fuel set wrong.
have you been a retard and drilled holes in the airbox to make it sound nice? if so, there you go.
maybe a good carb clean would do the trick though.
ugly1
PostPosted: 00:04 - 19 Jun 2007    Post subject: derbi gp50r Reply with quote
cheers will do that when i get chance
MaybeGuy
PostPosted: 00:06 - 19 Jun 2007    Post subject: Reply with quote
its most likely the jets if you have an aftermarket exhaust on there.
has it been de-restricted? if it has, chances are it wasnt done properly, take it back and go OI BITCH!!! CARB ME!
ugly1
PostPosted: 00:10 - 19 Jun 2007    Post subject: derbi gp50r Reply with quote
there is an aftermarket exhaust on it but it was ok before
MaybeGuy
PostPosted: 00:15 - 19 Jun 2007    Post subject: Reply with quote
in that case, most likely shit in your carbs. take them off and clean them inside. (bottom cover with the nipply thing on it).
concentrate on the tubes an all that.
maybe ur fuel filter is clogged? but that would usually be indicated by high rev chugging rather than low.
ugly1
PostPosted: 00:20 - 19 Jun 2007    Post subject: derbi gp50r Reply with quote
ok cheers for info will let you know
The last post was made 19 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.36 - MySQL Queries: 13 - Page Size: 56.59 Kb
