| MADDMAN |
 MADDMAN Two Stroke Sniffer
 Posted: 12:25 - 18 Jun 2007 Post subject: Reiju rs1 electrics |
hi... i have just bought a rieju rs1 year 2000 off eBay for £150... the bike its self is pritty fu**ed tbh... gone into back of a car... have been told engine is fine...
Question
the bike will not start... there is nothing... replaced battery as other 1 was no good, and still nothing... stripped bike down completely, and starter motor is disconnected. there is no kick start and it wont bump.. at the back where the fuse box is there is a broken wire hanging out of it.. it is same colour as starter motor cable but too thin.. if some one could post a pic of whats men't to happen it would be very helpful....
hope that makes sense^^ lol
n e help appreciated
will try and post a pic another time... no website is uploading them.. ____________________ Current Bikes: Kawasaki zx6 g2 (my everyday transport), vfr400 project, honda crf250 (currentely with smashed crank cases) projects: 720cc 2stroke jetski engine, mini moto engined push bike  |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 13:42 - 18 Jun 2007 Post subject: |
upload to photobucket.
i can only assume that the cable that has been pulled out is the wire for the starter solenoid.
by the sound of what you have said about the starter motor being disconnected, i would assume its been chucked in 50cc class racing and possibly is running a total loss system, ?(alternator disconnected)?
with out actually seeing the bike myself this is all just pie in the sky stuff,
best bet is contact your dealer and see if you can get a wiring diagram and a manual from them.
i have a diagram for a rs50 which i think is very similar to the reijus wiring if you want that.
where are you based??
someone with a bit of knowledge might be able to pay you a visit  ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| MADDMAN |
 Posted: 13:55 - 18 Jun 2007 Post subject: |
for some reason none of my pics are uploading to any website atm (not even photo bucket ) alternator is still connected, there is only 1 wire from the startor motor, and there is no where it can be connected, so i can only assume it is this one. i can email you pics if this helps. based in Cornwall UK... kinda need to try and do it myself, don't have money or transportation to get it to a dealer.
RS1 wiring diagrams would be very helpful, thanks..
Sam ____________________ Current Bikes: Kawasaki zx6 g2 (my everyday transport), vfr400 project, honda crf250 (currentely with smashed crank cases) projects: 720cc 2stroke jetski engine, mini moto engined push bike  |
| hmmmnz |
| MADDMAN |
 Posted: 15:38 - 18 Jun 2007 Post subject: |
cheers for diagrams... still no joy rele, still confused....lol
still cant upload any pics for some reason.. can i email them to you or something, to see if you can help me out...
thanks for all your help so far.. very quick to respond too, thought i would be waiting for days to receive an answer.
cheers Sam ____________________ Current Bikes: Kawasaki zx6 g2 (my everyday transport), vfr400 project, honda crf250 (currentely with smashed crank cases) projects: 720cc 2stroke jetski engine, mini moto engined push bike  |
| hmmmnz |
| hmmmnz |
| MADDMAN |
 Posted: 22:18 - 18 Jun 2007 Post subject: |
ideal..cheers mate.. will get hold of a multimeter..
n e more info would be appreciated
| hmmmnz |
| hmmmnz |
 Posted: 23:51 - 18 Jun 2007 Post subject: |
as you can see the only red wire is from the battery to the regulator
(and a seperate wire to the starter motor)
if the wire to the regulator isnt connected, you wont get power to any where on the bike. so thats your first goal
good luck  ____________________ the humans are dead
| MADDMAN |
 Posted: 09:00 - 19 Jun 2007 Post subject: |
brilliant... that has really helped alot... will try and get a multimeter later on to day to test power... from looking at diagrams looks like a fair bit of wire has been pulled from my bike, can i just get any wire to make up the broken stuff?
thanks alot for your help..
sam ____________________ Current Bikes: Kawasaki zx6 g2 (my everyday transport), vfr400 project, honda crf250 (currentely with smashed crank cases) projects: 720cc 2stroke jetski engine, mini moto engined push bike  |
| hmmmnz |
 Posted: 10:07 - 19 Jun 2007 Post subject: |
kind of, i would get a selection of cable sizes to do it, eg .5mm2 and .75mm2
get a soldiering iron, some solder, and some heat shrink, (or insulation tape)
dont use strip connectors as they will be another weak point, in the system and easily get corroided with all the shit that comes up from the road.
bear in mind that diagram might not be exactly the same as yours as its from a rs2, but for the life of me i couldnt find a rs1 diagram./
it should be fairly close
the first thing to check is continuity (a complete peice of wire for the electricity to pass through)
1. the red wire between the battery and the regulator
and the battery and the ignition switch
2. battery and starter relay (solenoid)
3. strater relay and starter motor
4. all 3 wires from the magneto/alternator to the coil
5. the red/white wire from the coil to the ignition switch
6. the green wire between the ignition and the starter switch
7. the green and white wire from the starter switch to the starter relay.
8 and the black wire on the starter relay to earth
if you get continuity between all those points and none of the switches or relays them selves are broken.
then the bike will turn over and possibly start if all the engine components are fine
lol fun times aye  ____________________ the humans are dead
| MADDMAN |
 Posted: 12:37 - 19 Jun 2007 Post subject: |
ideal.. just bought multi meter.. will have a go later on when it stops raining... cheers for all your help...
sam
EDIT
just wired bike up, and it turns over... very very happy now... going to put bike back together and get some fuel in it... diagrams are a bit different but easy to work out... thanks for all your help..
| hmmmnz |
 Posted: 15:06 - 19 Jun 2007 Post subject: |
| MADDMAN |
 Posted: 15:16 - 19 Jun 2007 Post subject: |
no spark
and carb is leaking...
multi meter is reading 0 from battery and the regulator and the battery and the ignition switch..
n e ideas?
cheers sam ____________________ Current Bikes: Kawasaki zx6 g2 (my everyday transport), vfr400 project, honda crf250 (currentely with smashed crank cases) projects: 720cc 2stroke jetski engine, mini moto engined push bike  |
| hmmmnz |
| MADDMAN |
 Posted: 15:58 - 19 Jun 2007 Post subject: |
will do... gonna leave it till morning now, as its raining again and about 2 get dark...
after i write down and measure reading, what shall i do then?
measured them briefly earlier and most showed 0
n e ideas... cheers
| hmmmnz |
| MADDMAN |
 Posted: 13:17 - 20 Jun 2007 Post subject: |
yeah i know.. could probably do with a bit of help lol... but getting there thanks to u...
got half way there checking the wires.. but going to be staying else where for a few days so wont be able to do anything for a bit...
so far
and the battery and the ignition switch is 0
2. battery and starter relay (solenoid) is 0
3. strater relay and starter motor is 0 .. but works?!?!
and thats as far as ive got so far..
for the magneto to coil do i have to take off engine casing as i cannot get to end of wires? of am i looking in totally the wrong place??
im pritty crap with bikes and hopeless with electrics so any help would be appreciated.
| hmmmnz |
 Posted: 16:05 - 20 Jun 2007 Post subject: |
0 ohms is no resistance thats what your after,
but i doubt your meter is that accurate, touch the leads together,
that will give you the error of the meter, that should be the result that you are trying to find when you are testing.
have you got the meter set to ohms and not volts?? ____________________ the humans are dead
| MADDMAN |
 Posted: 18:03 - 20 Jun 2007 Post subject: |
ummm possibly.... but i dont think so... never used 1 before so dont no what im rele looking for... it occasionly went up to 0.01 for a second but soon went down.. does this meant n e thing?
cheers for your help.. sam
EDIT
just spotted CDI unit adn coil on ebay
https://cgi.ebay.co.uk/Rieju-RS1-50cc-Coil-HT-Lead-cdi-Unit-rs-1_W0QQitemZ120098260971QQihZ002QQcategoryZ9946QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
recon its worth going for?
or will this not be to much of a problem to sort out?
| hmmmnz |
| MADDMAN |
 Posted: 10:44 - 22 Jun 2007 Post subject: |
alright.. i will be going back home later on today and have a bit of time on my hands, so i will be able to check the currents...
don't think i'm going to buy CDI and Coil off eBay as i don't rele have any money to play with atm...
will let you know how i get on and tell you what i find...
The last post was made 18 years, 199 days ago. Instead of replying here, would creating a new thread be more useful? |
