need advice from an electrician please!
gavin
PostPosted: 18:08 - 20 Jun 2007    Post subject: need advice from an electrician please! Reply with quote
whats the going rate (£ per fitting) for fitting GU10 downlights to a plasterboard ceiling to replace a single pendant fitting. wires are in place just need holes cutting, wires looping to the fittings and installing the lights, got about 20 of them to go in 4 rooms.
just need a ball park figure per fitting to check against some quotes.
thanks Thumbs Up Karma
1988 TZR125 : 1990 RD350YPVS/ RGV250 HYBRID : 1982 RD80LC : 1983 RD80LC : 1994 RGV250 : 1991 TZR125 / CR500R HYBRID : 1976 BENELLI 500 QUATTRO : 2006 TRIUMPH 675
squid36
PostPosted: 19:54 - 20 Jun 2007    Post subject: Reply with quote
depends on if you can get to the floorboards above it but without looking at the job, use a rep firm (nic eic registered ,dont use anyone whos not) your looking at 1 1/2 days work at about £150 a day
they say life begins at 40 but i think it begins at 140 !!!!!!!
https://www.mayhem-paintball.co.uk/ essex premier paintball site
gavin
PostPosted: 19:58 - 20 Jun 2007    Post subject: Reply with quote
as i said theres 20 of them, its a house converted into flats, approx 4 per room. no access from above, everything has to be fished through from below, i dont think its half a days work!
im really after a price per fitting.
thanks
gavin
PostPosted: 20:45 - 20 Jun 2007    Post subject: Reply with quote
anyone? Confused
thefallenange...
PostPosted: 06:18 - 21 Jun 2007    Post subject: Reply with quote
Electricians rate will be quite expensive an hour. Try and get someone who knows an Industrial electrican who works on the side to do it because they'll charge less and be a billion times better than a household electrician (but just Part P less).
Past - CG125 ,KR1S, SV650s, Street Triple R - Current - Duke 390
r.bridge1988@gmail.com
thefallenange...
PostPosted: 06:20 - 21 Jun 2007    Post subject: Reply with quote
I'd imagine £25 an hour will be going through a company and it'll be half hour a light if it's a quick 2 minute jobo otherwise it could get expensive. Just get some quotes done or take photos and show them to a eleccy you know.
sickpup
Old Timer
PostPosted: 09:00 - 21 Jun 2007    Post subject: Reply with quote
Depends on what has to be done.
First point is do you have adequate space between the ceiling and floor for cooling? if you are using GU10's at 50w these require something like 30cm+ back space or they tend to burn things.
Are there ceiling joists between the positions where you want the lights to go? If there are part of the ceiling may need to be pulled down.
Are the cables tails long enough to spread the lights around or do longer cables need to be made up?
Not enough information to quote but I would suggest you look at at least 1 days work at around £125-£150 a day.
GU10's are horrible bulbs which have a habit of breaking their fittings when you try to change them.
Stalk
PostPosted: 22:06 - 21 Jun 2007    Post subject: Reply with quote
Don't forget smoke hoods,(for sound insulation and retaining fire rating of ceiling) and part P not needed if its not a kitchen or bathroom. Just a small works certificate.
As for your lights, more work than you think.
Cheers,
Stalk
lozzypop1
Certified MILF!
PostPosted: 14:32 - 22 Jun 2007    Post subject: Reply with quote
Depending on access, laminate flooring or not above etc. I would charge you £160.00 or thereabouts.this providing there's no need for a new board, etc.
Sorry I'm vague - There's so much to take into consideration. It depends on the area you live too.
Best thing you can do is to get plenty of quotes from local electricians (as Stalk says - including Part P certificate is there's any in bathroom/kitchen) and play them off against each other.
Brod122
PostPosted: 22:01 - 22 Jun 2007    Post subject: Reply with quote
£35 per spot Smile
700 quid for the 20 supplied and fitted.
The prices the company I'm at atm is charging - North East.
The last post was made 18 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 66.17 Kb
