Noob: Hi and got a couple of problems
Walshie
PostPosted: 18:24 - 20 Jun 2007    Post subject: Noob: Hi and got a couple of problems Reply with quote
Hi all,
Just bought a 2002 NSR 125 with a few problems. Nothing major as far as I can see, I've took it for a ride and engine performs well and just feels like an all round good solid bike.
I bought this bike expecting to work on it as I wanted a project to do for a few months, will be a change from cars!
Anyway, I have noticed one of the front forks is leaking, and also the 2 stroke oil is leaking, quite badly. I'm not an expert on bikes but looking I can't see the fork seals been hard to replace? and I think the oil is leaking from a gasket, loosing quite a bit, is this a common problem and can anyone share any tips, advise, aprt numbers etc.
Walshie Thumbs Up
....Site seems great btw
hmmmnz
PostPosted: 19:00 - 20 Jun 2007    Post subject: Reply with quote
what gasket is it leaking from?/
pics might help.
fork seals on any bike can be a pain in the arse, but not really too hard, you'll also need new fork oil,
the best thing you can do is buy a haynes manual for it
the humans are dead
I kick arse for the lord
Walshie
PostPosted: 19:36 - 20 Jun 2007    Post subject: Reply with quote
I think its the oil pump, but having another look tonight, it me be running down the pipe from the 2 stroke tank. Think I'll cut a few cm off the pipe this weekend just to see if its split round the edges.
As for the forks, from what i gather from BCF I may need a special tool, I think i might just take the forks off and take them to my local bike shop and get them to do it.
....also been told I can't get a haynes manual for a nsr 125 for some reason
Cheers Thumbs Up
Evo
PostPosted: 19:45 - 20 Jun 2007    Post subject: Reply with quote
Haynes manuals arent available for this bike, so was a pretty useless comment from above.
Take your forks off and take them to your local bike shop, Watch what he does and know for next time ? Will cost bugger all aslong as it isn't a dealer. Fork seals are £6-£8.
OR
Refer To Here
And regarding oil leak. If it's leaking from the oil resovoir as you say, Clean off the leaked oil and check where it leaks from. Could be a split pipe as you say - most probably. Or there may be damage to the resovoir.
Just clean off first unless it's already obvious where it's coming from ?
Bikes owned
1989 VFR 400 RR NC30
Walshie
PostPosted: 19:56 - 20 Jun 2007    Post subject: Reply with quote
Cheers for that, Will give it a good go this weekend. Thanks for the diagram too, will come in handy Thumbs Up
kn76cbr
PostPosted: 20:10 - 20 Jun 2007    Post subject: Reply with quote
Haynes manual is a no no but if you go to a Honda main dealer and for approx. £25 they can order you a re-printed manual which is a lot more use then the shi* haynes produce.
Crashing's proof that your trying
c-m
PostPosted: 20:17 - 20 Jun 2007    Post subject: Reply with quote
isn't the nsr manual available online? i'm sure i downloaded on a while ago by mistake looking a ns125r manual instead
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
Finglonga
PostPosted: 10:38 - 21 Jun 2007    Post subject: Reply with quote
Bit harsh, not everyone is a expert in Haynes manuals.https://img.photobucket.com/albums/v112/finglonga/Finglonga%20Inc/nono.gif
Andy Sez....
F.Y.Y.F.F.
NSR-Rulez
PostPosted: 13:02 - 21 Jun 2007    Post subject: Reply with quote
I've not had any problems with mine, however for parts you want to try these:
Genuine parts : www.davidsilverspares.co.uk
Other sites: https://www.bitzforbikes.co.uk/HONDA/NSR_125/R-1_01_-_03
www.wemoto.com
David silvers is probably the better one to go for as they can get all teh parts and deliver pretty quickly, give them a call and describe what you need and they'll get it.
Past: 1985 Suzuki GS 125 + 2002 Honda NSR 125 R-2 + Ford Fusion
Present: Honda CBR 600 RR-5 + Suzuki SV650S-K4 + Mitsubishi FTO GPX
The last post was made 18 years, 230 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 61.66 Kb
