Help with Gears
cbrrider
PostPosted: 22:51 - 20 Jun 2007    Post subject: Help with Gears Reply with quote
I just want to ask if anyone can give me tips on changing down gears, as if you going to take a junction the bike always seems to jolt forward i just want to do it so it changes smoothly. thanks to anyone who posts with advice.
kiers
PostPosted: 23:07 - 20 Jun 2007    Post subject: Reply with quote
after you kick the gear thingy down to a lower gear, open the throttle a bit, then close it before releasing the clutch/going down to the next gear. lets the engine speed get closer to the speed of the wheel or some other such balls.
'but this wasn't any ordinary clio197.this was the SUPER DUPER version.
ooh i can't wait for the next instalment of superluke and his tales of skullduggery.' - lurker 27 sep 2008
GeorgeCBR
PostPosted: 23:22 - 20 Jun 2007    Post subject: Reply with quote
alternatively, let the revs die out in each gear, so change down at say 3,000rpm, and let the clutch out smoothly, personal choice though.
|| Ride - Kawasaki Z1000 & Honda Bali 50 || Theory - Passed || Practical - Passed ||
Previous || Suzuki Bandit 600N - Honda CBR 125 - Gilera Runner 50
rocket_richie
PostPosted: 01:49 - 21 Jun 2007    Post subject: Reply with quote
sounds like ur going down too many gears mate.also blip the throtle wen u down shift Thumbs Up
rs50 x2 rs125 zx6r f3 gs500e gsxr 400 zx6r f3
st3v3
PostPosted: 08:41 - 21 Jun 2007    Post subject: Reply with quote
Or coast a bit and wait Til you stop, then change all at once.
I usually do a taj of engine braking but too much isn't good for a 2stroke..
Catalyst
PostPosted: 12:06 - 21 Jun 2007    Post subject: Reply with quote
oops... I engine brake all the time on my 2t. I try not to but most of the time i go to around 4,000 revs and drop down.
Otherwise i just coast and pull the clutch in and kick all the way down to first.
Jack
|--Previous--|:2007 Aprilia SX50...Neutral--Current--|: 2007 Kawasaki ER-6N
SlimRick - I can cook really well - but it's a useless skill, as I'm not a woman and it's their fucking job!
Graprilia
PostPosted: 16:30 - 24 Jun 2007    Post subject: Reply with quote
you could be letting the clutch out to quickly try a more smooth release.
carlmalibu
PostPosted: 17:55 - 24 Jun 2007    Post subject: Reply with quote
any riding of a 2t without any throttle can cause problems because the 2stroke oil isn't getting around the system, can seize the bike up. So i've been told anyway.
Shine on, you crazy diamond
CB500, woop.
ncrn
PostPosted: 19:23 - 24 Jun 2007    Post subject: Reply with quote
It only causes problems if you do it for a long time, ie going down a massive hill and not using the throttle at all on the way down. If your in that situation blip the throttle a bit.
Also if say you are engine braking at 10,000 revs, your bike will only be getting fuel for about 1500 revs (average idle speed), so obviously it won't be getting enough oil.
I do engine braking and my bike isn't suffering from it, I always rev when changing down gears, so the bike gets a bit of fuel/oil from my revving Smile.
The Tot
PostPosted: 19:26 - 24 Jun 2007    Post subject: Reply with quote
I always blip my throttle between changing each gear and releasing the clutch. It results in a very smooth movement on the deceleration.
Never argue with autism
alun111
PostPosted: 20:58 - 24 Jun 2007    Post subject: Reply with quote
I'd say definately a combination between you letting the clutch out too fast and/or changing down too many gears.
faddius
PostPosted: 22:31 - 24 Jun 2007    Post subject: Reply with quote
Feather the clutch when you downshift, clutch in, downshift let it out to the biting point. That way you can feel if the bike is going to jolt forwards and you can always pull it in before it does, try again and again till itll come out smoothly as every time you let it out to the biting point itll engine brake partly anyway.
The last post was made 19 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 72.48 Kb
