Rear slide when dropping down
SilvaRizla
PostPosted: 14:11 - 20 Jun 2007    Post subject: Rear slide when dropping down Reply with quote
Hi,
I've noticed recently that when I drop it in to 2nd at high-ish revs (agressive corner or whatever) the rear slides to the right.
Bike: NSR125
Tyres: Rear has developed a few "nicks" between my chicken strips but the tread is still deep
Is this normal?
Silva
I'm Ivan Dobski the Meatsafe Murderer only I never done it, I only said that I done it so they'd take the truncheon out of my bottom
Walloper
PostPosted: 14:22 - 20 Jun 2007    Post subject: Reply with quote
You are probably running out of RPMs
Changing down too fast.
10000 in third then dropping into 2nd could send the engine into orbit.
Use the brakes until you can match the enging to the road speed.
Crazy B'stad...... Wink
SilvaRizla
PostPosted: 14:24 - 20 Jun 2007    Post subject: Reply with quote
Its not that bad, maybe up to 5-6000
I use the breaks too but like to get near the powerband when conrnering
Do you think that's high enough to cause it
Walloper
PostPosted: 14:29 - 20 Jun 2007    Post subject: Reply with quote
You could check wheel frame alignment too.
You may have a bias to one side of the tyre causing the bike to track right when the weight is off when 'driven' by the road against the engine.
I don't drive like that all the time anyway as I tend to fall off Embarassed
ncrn
PostPosted: 14:45 - 20 Jun 2007    Post subject: Reply with quote
Are you revving the engine up before changing down, or just changing down a gear and dumping the clutch?
Really you should try match the engine revs before you change down a gear, for 5-6000 revs in 3rd you'd be doing around 7-8000 revs in 2nd, so clutch in, rev and kick gear down, let out clutch, start riding again.
SilvaRizla
PostPosted: 15:27 - 20 Jun 2007    Post subject: Reply with quote
Changing down whilst breaking, dumping, slight slide right before power on as I start leaning in
Keir
PostPosted: 15:37 - 20 Jun 2007    Post subject: Reply with quote
yep, as per the above post. Blip the throttle to match the revs before letting the clutch out.
Current : '08 Yamaha FZ1s
ncrn
PostPosted: 15:39 - 20 Jun 2007    Post subject: Reply with quote
Yeh you really need to blip the throttle before you change down, all you need to do is just twist the throttle before you let the clutch out again, it will make the change so much smoother, and it will speed you up a bit.
SilvaRizla
PostPosted: 16:00 - 20 Jun 2007    Post subject: Reply with quote
I did this on my CBT as it came naturally and was told that this wasn't the correct way to ride. I do it by accident sometimes as it does feel smoother and more natural. Is this how I should be changing gear then?
Dazbo666
PostPosted: 16:44 - 20 Jun 2007    Post subject: Reply with quote
IMO you probably shouldn't be doing it on your CBT, lessons or test, but I'd have thought the majority of bikers do it in "the real world" because it smooths out your gear changes and your riding generally, it's kinder to the bike... and it sounds great!
...In my opinion, occifer Rolling Eyes Wink
Word of the day : DILLIGAF
kart racer
PostPosted: 17:15 - 20 Jun 2007    Post subject: Reply with quote
I had this when i was too agressive on the drown shift and hadn't matched the revs and mentioned.
Either blip the throttle a bit more or shift down a bit later/more progressively.
Winners never quit, and quitters never win
mr jamez
PostPosted: 17:23 - 20 Jun 2007    Post subject: Reply with quote
I prefer to use the clutch and throttle when changing down at higher revs, rather than dumping it use it progressively to feed the power in like you would when pulling away quickly.
Hairy Ben
PostPosted: 17:25 - 20 Jun 2007    Post subject: Reply with quote
Yes... Very much so.
I'm stunned you were told not to, test or not. Shocked
Is this something taught across the board on CBT's these days? Surely not?
Downright dangerous if it is. Sad
...and thus true enlightenment is achieved.
I think, therefore I am... I ride a BMW, therefore I smell of wee...
ncrn
PostPosted: 17:29 - 20 Jun 2007    Post subject: Reply with quote
A friend of mines dad was told that he'd fail his cbt if he continued to ride using the throttle and covering the front brake at the same time.
I ride like that in town because there are a lot of situations where you need to use the front brake very quickly and the time between you moving your hand from the throttle to brake could be wasted time..
Hairy Ben
PostPosted: 17:38 - 20 Jun 2007    Post subject: Reply with quote
Crazy..
That's a skill worth knowing from the get go.
Sad
Jack_Cheese
PostPosted: 09:31 - 21 Jun 2007    Post subject: Reply with quote
Hairy Ben wrote:
Crazy..
Sad
It is one of those things that will help you be safer, but is deemed dangerous to learn. Go figure...
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
Skudd
PostPosted: 09:56 - 21 Jun 2007    Post subject: Reply with quote
It is fun letting the back slide though. Very Happy
SilvaRizla
PostPosted: 18:11 - 21 Jun 2007    Post subject: Reply with quote
well yeah it is, as long as you know its not caused by a mechanical fault!
Hairy Ben
PostPosted: 18:16 - 21 Jun 2007    Post subject: Reply with quote
It's all fun and games until someone loses an eye... Sad
MattHirst
PostPosted: 18:37 - 21 Jun 2007    Post subject: Reply with quote
I blip the throttle all the time on downshifts...do get some funny looks as though to say 'what the bloody hell you doing...weirdo' but nevermind.
I did it on my test (well, i do it all the time....without thinking about it) and although i did fail (u turn) he didn't say anything about it at all.
ilovensr
PostPosted: 20:25 - 21 Jun 2007    Post subject: Reply with quote
iv done it a few time on my NSR, its quite scary if your on a roundabout with cars on your outside, but i think it is normal, if you really dont like the feeling just corner slower, otherwise i dont think theres much you can do about it
Current Bikes:
Honda NSR125 >>> Garaged
Kawasaki ER5 >>> Excellent commuter
MattHirst
PostPosted: 21:32 - 21 Jun 2007    Post subject: Reply with quote
I was always taught not to change down mid corner.
I rarely change up mid corner (unless its like a sweeper type) but if it is a medium to tight corner than i just keep a steady throttle all the way round (unless a sheep decides to play sheep with you!)
The last post was made 18 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.37 - MySQL Queries: 16 - Page Size: 124.72 Kb
