Highside help!!!!
Dylan
PostPosted: 19:14 - 19 May 2002    Post subject: Highside help!!!! Reply with quote
I just paid £180 for an engine rebuild (new mains and rings). i installed the engine my self and go and test ride it. About 3 miles later (no power whatsoever) the damn thing seizez round a corner highsiding with me skidding along the floor. Big gash on me side, but that dont matter, the poor old bike has a bit of a cracked fairing. Bloke on a gixer (new one) helps me up begrudgeingly. I manage to restart the bike but dont risk it home.
anyway, all i wanna know is what could have caused this???? I know the oil pump was fine and i bled it then used premix on it with the pump on full then riding it. RC valve should make exhaust port larger at higher revs, or is it the other way round???
Sorry to pester you keoth, but could you help me on this one???
Thanks
Dyl
PostPosted: 21:56 - 19 May 2002    Post subject: Reply with quote
The most likely cause of a seizure just after a rebuild is the oil supply. However, you have been careful there so I suspect that should be OK. I presume you filled the gearbox with oil? I would be suspicious that there was a problem with the engine rebuile, either the mains not being fitted properly (unlikely, as they would probably just develope play and wear out if subject to too much side loading) or the piston is oversize (the Honda pistons are available with about 0.02mm between the smallest and the largest)
The power valve should make the exhaust port effectively higher at high revs
Ropehead
PostPosted: 22:22 - 19 May 2002    Post subject: Bla Bla Reply with quote
Check the ring clerance you could be lucky the rings might be slighy to big causing them to stick when the engine heats up, then when it cools down they run as normal on the tzr the clerance is about .002mm check it out with a fela gauge.
While u have the top off have a good feel round for scores!!
Hope this help! Wink
i'm still waiting for my engine back ofter it droped a curclip making a right mess of the piston and bore! FEKING 2 STOKES
Dylan
PostPosted: 07:04 - 20 May 2002    Post subject: Reply with quote
Thanks for the replys. This means that the oil pump nad RC valve were set up corectly. Oil was in the gearbox and filled to the correct level.
Unfortunately this makes it look like wrong sized rings have been put in??? Only the rings were changed and not the piston.
Ive got exams now so i cant be doing with taking cylinder heads off. If it looks like it might be the workmanship of the garage then ill let them sort it out.
WHY DONT THEY MAKE DECENT 125 4'STROKES!!!!!!!!!!!!!!!!!
Thanks again
Dyl
Keen
PostPosted: 18:19 - 20 May 2002    Post subject: Reply with quote
from what I remember of GCSE English that's an oxymoron isn't it? Laughing
GasGas
PostPosted: 18:34 - 20 May 2002    Post subject: unlucky mate Reply with quote
sorry to hear about the bike Dylan. If it makes you feel any better, mine has developed a vibration at 8k but then smoothes out after 10k. sounds a bit rough after mytop end rebuild.... Crying or Very sad guess i shouldnt be spanking it just in case. still, i will enjoy it while it lasts.
hope you get it sorted soon.
Dylan
PostPosted: 18:54 - 20 May 2002    Post subject: Reply with quote
Shouldnt you get that seen to??? Think the main bearings caused a scratched bore in mine. Cant believe they still havnt done an update to the CG125. Big bike manafacturers just arnt interested in us.
Dyl
Doddmaster
PostPosted: 19:21 - 20 May 2002    Post subject: Reply with quote
They should release a CG125 Sport Laughing
Keen
PostPosted: 19:35 - 20 May 2002    Post subject: Reply with quote
they made the cityfly- but that was just cosmetic
WildGoose
White Van Man
PostPosted: 19:50 - 20 May 2002    Post subject: yeah Reply with quote
there is just something about the cityfly that doesnt appeal
i cant but my finger on it, its about the looks
and also 11.4 HP sounds like a bag o' shite, plus its a grand more expensive than the CG
the Varadero 125 is nice, thats a 4 stroke, but its almost as much as an NSR, and i have no idea what the top speed will be
Keen
PostPosted: 19:57 - 20 May 2002    Post subject: Reply with quote
can't see the veradero being much faster than a cityfly- all that plastic as well.....
I know what you mean though- strange mix, not as cheap as the cg but not as aggressive looking as the XLR.
Robby
Dirty Old Man
PostPosted: 21:03 - 20 May 2002    Post subject: Reply with quote
the cityfly exhaust looks like the exhaust off a monkey bike, apart form that it looks ok for a commuter.
PostPosted: 22:40 - 20 May 2002    Post subject: Reply with quote
Doddmaster wrote:
They should release a CG125 Sport :lol:
They used to make the CB125S, which was a single cylinder 4 stroke overhead cam 125. The engine was very closely related to the CG125. Went out of production about 20 years ago. They also make the CB125T, which was a 125 twin. Still dog slow (although the earlier CB125T rather than CB125TDC was claimed to be 15hp or so)
The last post was made 23 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 76.22 Kb
